Pro/E, Creo and ProductView all have a 'View Server Properties' command in the tool. I cannot seem to find it in Autodesk Inventor 2011 with WGM 9.1 M060. It is available, just hiding form me?
This would not be available unless it is installed. The WGM must be installed using the windchill PSI for each product/version that you want to be able to register.
