Has anybody had issues with tomcat ports using multi method servers and backgroundmethod servers in Windchill 10.1 M040?
Do you have multiple BGMS configured?
Even if you are using a Windchill cluster, with SOLR enabled, only ONE BGMS can have embedded Tomcat enabled.
There are many KB articles related to this, here is a good one to start with:
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS74622
While wt.tomcat.embeddedMode.solr seems to provide more fine grained configuration choices (YES, NO, ONLY), I have seen issues with this andrecommendusing the wt.manager.cmd.<bgms>.param.12=<null>to disable embedded Tomcat onall non-SOLR instances.
