WIndchill 10.1 M040
HerbertMiller
WIndchill 10.1 M040
Has anybody had issues with tomcat ports using multi method servers and backgroundmethod servers in Windchill 10.1 M040?
If you accidentally configure to run more than one Solr instance, then
you will run into such issues.
Otherwise you shouldn't.
Jess,
Here is what I configured to install
New Installation
Windchill PDMLink
Windchill ProjectLink
Enable Remote File Server Support
- Windchill Index Search (Solr)
- Enable Windchill Index Search
Windchill Index Search Host Name
LMWC3.LawlerManufacturing.local
Directory to store Index Search Data
C:\apps\ptc\wc10_1\Windchill\solr\data
Windchill Index Search Port Number
8085
Default Indexing Language
English
Index Search Language List
- English
- Creo View
- Thumbnail Generator and Viewable Compression Utilities
Installing To: C:\apps\ptc\wc10_1\Windchill
Disk Space Required: 7.42 GB
Herb Miller
TWeatherford, Inc.
herbm@tweatherford.com
3148 Beach Blvd
Cicero, IN 46034
competitor"
Do you have multiple BGMS configured?
Even if you are using a Windchill cluster, with SOLR enabled, only ONE BGMS can have embedded Tomcat enabled.
There are many KB articles related to this, here is a good one to start with:
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS74622
While wt.tomcat.embeddedMode.solr seems to provide more fine grained configuration choices (YES, NO, ONLY), I have seen issues with this andrecommendusing the wt.manager.cmd.<bgms>.param.12=<null>to disable embedded Tomcat onall non-SOLR instances.
