Even in the CAD environment, WTparts can be usefull. The images of the earlier postings disregard drawings, skeletons, flat states etc. We use WTparts to combine CADdocuments that should or could be considered together.
E.g. the ProE-assembly is coupled to it's proper WTpart together with its drawing and its skeleton.
E.g. the family table instance is coupled to it's WTpart together with its drawing and the upper generic.
Regards, Hugo.
<< ProE WF3 M190 - PDMLink 8.00 M040 >>
Is there any way to use WTParts to get an accurate where used report in family table instances?
Right now, for example, we have a generic and instances of a custom rivet. The generic describes the stock rivet, and the instances describe the assembled or staked rivet. Since we use the instances in the assemblies, we can't get an accurate where used report without manually going through each instance.
Any suggestions?
-marc
