Ideas on the attached error message "wt.util.WTException: org....."it's the return I get after step one.
Any assistance would be greatly appreciated.
Greg
Hello Greg,
I cleared the cache and restarted windchill to get past this error once.
Do you see anything in the MS logs other than this?
Thank you
Binesh Kumar
Barry Wehmiller
I checked the MS logs and found that upper/lower case matters when pointing to a folder to create the parts in....now I am at step three with LC issues. PTC is on it, but the initial TSE knew very little about this utility.
Hi Greg, were you able to get past the LC issues and get your parts created? If not, what kinds of errors are you running into?
Not yet...still working with TS on a few issues.
