object query exception
AntonBagryanov
Hi!
I want to query PromotionTarget objects by two parameters:
String str = obj.toString();
  HashMap<String, String> objSpec = getObjSpec(str);
  QuerySpec qs = new QuerySpec(PromotionTarget.class);
  qs.setAdvancedQueryEnabled (true);
  SearchCondition sc1 = new SearchCondition(PromotionTarget.class, "roleBObjectRef.key.classname", SearchCondition.EQUAL, objSpec.get("objClass"));
  qs.appendWhere(sc1, new int[]{0});
  qs.appendAnd();
  SearchCondition sc2 = new SearchCondition(PromotionTarget.class, "roleBObjectRef.key.id", SearchCondition.EQUAL, Long.getLong(objSpec.get("objId")));
  qs.appendWhere(sc2, new int[]{0});
  QueryResult qr =  PersistenceHelper.manager.find(qs);
  Persistable[] per = null;
  while (qr.hasMoreElements())
  per = (Persistable[])qr.nextElement();
  list.add((PromotionTarget)per[0]);
But I have an exception like this:
wt.pom.DatastoreException: Ошибка SQL при выполнении инструкции "SELECT 'wt.maturity.PromotionTarget',A0.createLCTemplateIsNull,A0.classnamekeyA6,A0.idA3A6,A0.createState,A0.description,A0.classnamekeyroleAObjectRef,A0.idA3A5,A0.classnamekeyroleBObjectRef,A0.idA3B5,CONVERT(varchar,A0.createStampA2,120),A0.markForDeleteA2,CONVERT(varchar,A0.modifyStampA2,120),A0.idA2A2,A0.updateCountA2,CONVERT(varchar,A0.updateStampA2,120) FROM PromotionTarget A0 WHERE ((A0.classnamekeyroleBObjectRef = ?) AND (A0.idA3B5 = )) AND (A0.markForDeleteA2 = 0); Bind Parameters=[wt.doc.WTDocument]". Сообщение системы базы данных:
2015-11-13 16:31:16,075 INFO  [ajp-bio-8010-exec-4] wt.system.out nadmin - Вложенное исключение: com.microsoft.sqlserver.jdbc.SQLServerException: Incorrect syntax near ')'.
This code working fine:
try
  SearchCondition sc1 = new SearchCondition(PromotionTarget.class, "roleBObjectRef.key.classname", SearchCondition.EQUAL, getObjClass(str));
  qs.appendAnd();
  SearchCondition sc2 = new SearchCondition(PromotionTarget.class, "roleBObjectRef.key.id", SearchCondition.EQUAL, PersistenceHelper.getObjectIdentifier(obj).getId());
  PromotionTarget per = null;
  per = (PromotionTarget)qr.nextElement();
  list.add(per);
  catch (QueryException e) {e.printStackTrace();}
  catch (WTException e) {e.printStackTrace();}
try
  qs.appendAnd();
  list.add(per);
Hi Anton,
I guess your code was failing to get the value of long. I have seen instances where Long.getLong returns null and the logs indicates the same, there is only one parameter passed to the query. You can try Long.parseLong instead in your code to get it working.
Bhushan
Hi Bhushan!
Thank's for your reply! I'll check it later.
