WVS Job Monitor Popup Notifications UX Enhancement
vishal_wahi
7-Bedrock
The yellow Notification Pop-up stays persistent for longer duration and appears over the necessary buttons like Actions, and Search filters.
The popup must not overlap on the buttons because this behaviour reduces the user's experience & efficiency, delays the work of the admin and is sometimes annoying. It looks like very legacy user interface.
PTC should work on enhancing the user interface of WVS Job Monitor. Especially the notifications.
They are and this banner message timeout is controllable.
https://www.ptc.com/cn/support/article/CS46987?art_lang=en
From the conference, they are looking at replacing this with popups in lower right corner of UI. This post should go into to Windchill Ideas section.
Hi @Vibrant,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina
PTC Community Moderator
PTC
