WVS
BT_10759757
7-Bedrock
WVS
Version: Windchill 12.0
Use Case: We have AEM for Windchill Prod. For certain specific lifecycle state, I am getting below error in Job log while publishing the document Return value of the configured LiveCycle delegate contained a DDX that is NULL. Must have a DDX in order to call the Adobe Experience Manager Assembler service. If the intent is to not have this particular PDF to be processed, then the delegate should return NULL.
Description:
Hey, Thanks for the Article. I have gone through this already and validated that all the settings are correct. Still having the same issues. Also, would like highlight that, issues is occuring specifically in one of the lifecycle states called Superseded
Hi @BT_10759757
If so, please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina
PTC Community Moderator
PTC
