Version: Windchill 11.1
Use Case: We are trying to Extract Windchill As-stored BOM Information from Windchill DB and Staging DB, We are not finding the BOM Child As-stored Revision in the both database.
Description:
From the Windchill Database we are not able to find Child Relation between EPMASSTOREDMEMBER and EPMMEMBERLINK.
As far as I know, only EPMDocument structure is by default always have a "As Stored" configuration. For BOM, there must a Baseline defined, or a Promotion Request snap shot or "As Matured" configuration (In case of Release by ECN), only if any of the 3 are there in the system , you can extract the BOM configuration as per your intent.
We can wait for other experts reply on this.
There may be some workaround through the CAD-Part link somehow.
Cheers
Hari
Hi @Hari_Vara
@DK_10304222 talking about the CAD BOM Structure not about the WTPart structure.
So the CAD Structure have the as stored definition.
It is really not good practice to collect information directly from DB.
If the information is not in the database then the as stored configuration does not exists.
PetrH
Thank you!!
I need a relation between EPMASSTOREDMEMBER and EPMMEMBERLINK in database.
Deepa
Hi @DK_10304222
It is litle but complicated 😄 there is a table where is a configuration and it is linked by child CADName
here is the sql that returns the child IDA2A2 and parent IDA2A2
With this select you find the specific as stored child.
select asstored.idA3B5 as CHILDEPMIDA2A,link.idA3A5 as PARRENTIDA2a2,epmMaster.documentNumber as CHILDNUMBER,* from wcuser.EPMMemberLink link
inner join wcuser.EPMDocumentMaster epmMaster on epmMaster.idA2A2=link.idA3B5
inner join wcuser.EPMAsStoredMember asstored on link.asStoredChildName=epmMaster.CADName
inner join wcuser.EPMAsStoredConfig config on asstored.idA3A5=config.idA2A2
Select with revision/iteration info from child EPMDocument
select asstored.idA3B5 as CHILDEPMIDA2A,epmDoc.versionIdA2versionInfo as REVISION,epmDoc.iterationIdA2iterationInfo as ITERATION,link.idA3A5 as PARRENTIDA2a2,epmMaster.documentNumber as CHILDNUMBER,* from wcuser.EPMMemberLink link
inner join wcuser.EPMDocument epmDoc on epmDoc.idA2A2=asstored.idA3B5
Hope this help you to solve your issue.
PetrH
Thanks for the query!!
I don't see any relation between EPMMemberLink and EPMAsStoredMember in the above query.
I tried above query for one object, it's not giving any result.
Hi @DK_10304222
What is the inner join wcuser.EPMAsStoredMember asstored on link.asStoredChildName=epmMaster.CADName ?
If you don't see any results, then you do not have as stored configuration.
btw, only assembly can have as stored config.
PetrH
I checked for assembly only which has AsStored configuration but it's not giving any result.
Deepa
Below is the query which I tried
epmMaster.documentNumber as CHILDNUMBER from EPMMemberLink link
inner join EPMDocumentMaster epmMaster on epmMaster.idA2A2=link.idA3B5
inner join EPMAsStoredMember asstored on link.asStoredChildName=epmMaster.CADName
inner join EPMAsStoredConfig config on asstored.idA3A5=config.idA2A2
inner join EPMDocument epmDoc on epmDoc.idA2A2=asstored.idA3B5
and epmMaster.documentNumber = 'FA0225.ASM'
and epmDoc.versionIdA2versionInfo = '00'
and epmDoc.iterationIda2iterationInfo = '1'
Hi @DK_10304222
The point is that the epmMaster is a child part not the assembly so your condition is wrong.
If you want to search by parent part, you have to join link.idA3A5 with EPMDocument ida2a2 and then reference to EPMDocumentMaster
PetrH
Hello @DK_10304222,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
