In Reply to David Graham:
I found the answer to my own question.
Don't specify parameter lifecycle and it will default ot OIR lifecycle.
Windchill 8.0 M020
I'm using create-objects webject.
I need to set the lifecycle to the lifeccycle determined by OIR
I'm aware of webject parameter:
<ie:param name="FIELD" data="lifeCycle=<what" is=" the=" syntax=" here=">"/>
example in documentation simply list
<ie:param name="FIELD" data="lifeCycle=Default"/">
this does not yield the lifecycle determined by the OIR however.
If it is not possible to set it to the OIR lifecycle what would the syntax
be to set it to a specific lifecycle that is at a context level?
Any thoughts on this?
David Graham
Windchill Administrator
Pro|ENGINEER Administrator
CAx Administrator
Emhart Glass Manufacturing Inc.
Emhart Glass Research Center
123 Great Pond Drive | Windsor, CT 06095 | USA
Telephone +1 (203) 376-3144 | Telefax +1 (860) 298 7397
Mobile +1 (203) 376-3144 | http://www.emhartglass.com
Hello ,
Can you share any related doc on using create- Webjects.
Sriram
