WfPropagationQueue错误wt.workflow.WfException: wt.util.WTException: java.lang.NullPointerException
YZ_10291617
2-Explorer
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS22
汇聚队列 - WfPropagationQueue出现失败条目,错误信息:
嵌套异常是: java.lang.NullPointerException
嵌套异常是: wt.util.WTException: java.lang.NullPointerException
Here are the errors that I faced
2024-05-08 13:11:36,864 INFO [WfPropagationQueue.PoolQueueThread-152] wt.system.out Administrator -
2024-05-08 13:11:37,014 INFO [WfPropagationQueue.PoolQueueThread-152] wt.system.err Administrator - java.lang.reflect.InvocationTargetException
2024-05-08 13:11:37,014 INFO [WfPropagationQueue.PoolQueueThread-152] wt.system.err Administrator - at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
2024-05-08 13:11:37,014 INFO [WfPropagationQueue.PoolQueueThread-152] wt.system.err Administrator - at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
2024-05-08 13:11:37,014 INFO [WfPropagationQueue.PoolQueueThread-152] wt.system.err Administrator - at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
2024-05-08 13:11:37,014 INFO [WfPropagationQueue.PoolQueueThread-152] wt.system.err Administrator - at java.lang.reflect.Method.invoke(Method.java:498)
2024-05-08 13:11:37,014 INFO [WfPropagationQueue.PoolQueueThread-152] wt.system.err Administrator - at wt.workflow.definer.WfExpression.invokeByReflection(WfExpression.java:1408)
2024-05-08 13:11:37,014 INFO [WfPropagationQueue.PoolQueueThread-152] wt.system.err Administrator - at wt.workflow.definer.WfExpression.executeRouter(WfExpression.java:1565)
2024-05-08 13:11:37,014 INFO [WfPropagationQueue.PoolQueueThread-152] wt.system.err Administrator - at wt.workflow.definer.WfExpression.execute(WfExpression.java:465)
2024-05-08 13:11:37,014 INFO [WfPropagationQueue.PoolQueueThread-152] wt.system.err Administrator - at wt.workflow.engine.WfConnector.evaluateRouterExpression(WfConnector.java:641)
2024-05-08 13:11:37,014 INFO [WfPropagationQueue.PoolQueueThread-152] wt.system.err Administrator - at wt.workflow.engine.WfConnector.fire(WfConnector.java:374)
2024-05-08 13:11:37,014 INFO [WfPropagationQueue.PoolQueueThread-152] wt.system.err Administrator - at wt.workflow.engine.WfConnector.fireInput(WfConnector.java:338)
2024-05-08 13:11:37,014 INFO [WfPropagationQueue.PoolQueueThread-152] wt.system.err Administrator - at wt.workflow.engine.ConnectorConnectorLink.receiveEvent(ConnectorConnectorLink.java:150)
2024-05-08 13:11:37,014 INFO [WfPropagationQueue.PoolQueueThread-152] wt.system.err Administrator - at wt.workflow.engine.StandardWfEngineService.propagateEvent(StandardWfEngineService.java:1120)
2024-05-08 13:11:37,014 INFO [WfPropagationQueue.PoolQueueThread-152] wt.system.err Administrator - at sun.reflect.GeneratedMethodAccessor2062.invoke(Unknown Source)
2024-05-08 13:11:37,014 INFO [WfPropagationQueue.PoolQueueThread-152] wt.system.err Administrator - at wt.queue.QueueEntry.execute(QueueEntry.java:231)
2024-05-08 13:11:37,014 INFO [WfPropagationQueue.PoolQueueThread-152] wt.system.err Administrator - at wt.queue.QueueRunnable.run(QueueRunnable.java:159)
2024-05-08 13:11:37,014 INFO [WfPropagationQueue.PoolQueueThread-152] wt.system.err Administrator - at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
2024-05-08 13:11:37,014 INFO [WfPropagationQueue.PoolQueueThread-152] wt.system.err Administrator - at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
2024-05-08 13:11:37,014 INFO [WfPropagationQueue.PoolQueueThread-152] wt.system.err Administrator - at java.lang.Thread.run(Thread.java:748)
2024-05-08 13:11:37,015 INFO [WfPropagationQueue.PoolQueueThread-152] wt.system.err Administrator - Caused by: java.lang.NullPointerException
2024-05-08 13:11:37,015 INFO [WfPropagationQueue.PoolQueueThread-152] wt.system.err Administrator - at wt.workflow.expr.WfExpression17387048.executemethod_1(WfExpression17387048.java:32)
2024-05-08 13:11:37,015 INFO [WfPropagationQueue.PoolQueueThread-152] wt.system.err Administrator - ... 20 more
2024-05-08 13:11:37,033 ERROR [WfPropagationQueue.PoolQueueThread-152] root Administrator - Queue entry number: 748427
My apologies. What you posted is very generic type of error. What I can tell only is that you had a NullPointerException in a workflow expression. What is more useful is which job failed in what workflow. You should be able to tell this by looking at the WTPropagationQueue and there should be a failed entry. It should lead you to the workflow and the step that failed. Then you need to look at the code expression in that step for what could have cause the error. This could be data related or some case that was not handled. Workflow code should be very robust and handle as many exception as possible gracefully so the workflow remains running.
Hello @YZ_10291617
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Community Moderation Team.
