What is Difference between part and part master ?
Hi Sandeep,
In windchill a Part Master is the reference point for the revisioned Part.
The Part contains version specific information, whereas the Part Master contains the information shared among all the revisions.
If you are referring to Master Rep Vs Default Rep This may help with that:
If anything is unclear about this feel free to ask some follow up questions as I am sure others may feel the same.
Jarrett
There are no "parts" and "part masters" in Integrity's standard solutions.
Are you referring to a custom solution or a different PTC product?
Hi Sandeep,
Jarrett
Hi Jarrett Colin,
Thank you so much for answering.I am new this windchill.Recently i have been started working on this windchill java api.i have very basic knowledge.Can u please help how to learn this windchill.is there any documention is avilable for how to use this java api,Means Like how to update the attributes and set the values,get the values,retriving sing java api.
Can u please help me out
Sandeep
Sandeep, this is a discussion board for the product called "Integrity". You need to switch to the "Windchill" discussion.
This thread has been moved from the Integrity Community to the Windchill Community.
Kael
