What is the difference between PersistenceHelper and PersistenceServerHelper Bean. Is there any recommended use of these Beans under specific use cases to Create Windchill Business objects.?
nmahajan-2
Trying to understand the difference between these API's from implementation point of view. Java Doc does not provide much information on when to use Store and When to use Save and Insert functions that are provided by PersistenceHelper and PersistenceServerHelper. The end result is same to create Objects in Windchill. Is there any recommended uses cases to use these API's?
0 REPLIES 0
