partlist
jreze
7-Bedrock
partlist
I Would like to load a partlist object but it is not working. Here is a sample of my xml file:
<?xml version="1.0" ?><!DOCTYPE NmLoader SYSTEM "standardX24.dtd">
<NmLoader>
<csvPartList handler="com.ptc.arbortext.windchill.partlist.LoadPartList.createPartList" >
<csvuser></csvuser>
<csvname>720A00</csvname>
<csvnumber>0000000002</csvnumber>
<csvfolder>/Default/Planche Catalogue - POC</csvfolder>
<csvlifecycle></csvlifecycle>
<csvview></csvview>
<csvteamTemplate></csvteamTemplate>
<csvlifecyclestate>RELEASED</csvlifecyclestate>
<csvtypedef>WCTYPE|com.ptc.arbortext.windchill.partlist.PartList</csvtypedef>
<csvversion>A</csvversion>
<csviteration>1</csviteration>
<csvdescription />
<csvinformationType />
<csvpartListItemType />
<csvparentContainerPath></csvparentContainerPath>
<csvorganizationName></csvorganizationName>
<csvorganizationID></csvorganizationID>
<csvcreateTimestamp></csvcreateTimestamp>
<csvmodifyTimestamp></csvmodifyTimestamp>
<csvauthoringLanguage>en</csvauthoringLanguage>
</csvPartList>
<csvendIBAHolder handler="wt.iba.value.service.LoadValue.endIBAHolder" />
</NmLoader>
Here is the stack trace:
(wt.ixb.publicforhandlers.ixbResource/18) wt.ixb.publicforhandlers.LogHelper$IxbException: Error in XML input file
at wt.ixb.publicforhandlers.LogHelper.userError(LogHelper.java:230)
at wt.ixb.publicforhandlers.LogHelper.userError(LogHelper.java:566)
at wt.ixb.impl.doc.IxbDomDocument.initialize(IxbDomDocument.java:169)
at wt.ixb.publicforapps.IxbDomDocumentDelegate.newIxbDocument(IxbDomDocumentDelegate.java:39)
at wt.ixb.publicforapps.IxbHelper.newIxbDocument(IxbHelper.java:282)
at wt.load.StandardLoadService.importData(StandardLoadService.java:776)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at wt.method.MethodResultWriter.writeExternal(MethodResultWriter.java:152)
at wt.method.MethodResult.writeExternal(MethodResult.java:228)
at java.io.ObjectOutputStream.writeExternalData(ObjectOutputStream.java:1455)
at java.io.ObjectOutputStream.writeOrdinaryObject(ObjectOutputStream.java:1429)
at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1177)
at java.io.ObjectOutputStream.writeObject(ObjectOutputStream.java:347)
at sun.rmi.server.UnicastRef.marshalValue(UnicastRef.java:293)
at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:332)
at sun.rmi.transport.Transport$1.run(Transport.java:177)
at sun.rmi.transport.Transport$1.run(Transport.java:174)
at java.security.AccessController.doPrivileged(Native Method)
at sun.rmi.transport.Transport.serviceCall(Transport.java:173)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:556)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:811)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:670)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
Julien
jreze
7-Bedrock
(To:jreze)
I fixed my problem.
To load a part List, i need to load also the related WTPart object and the partToPartList link.
The use empty was not a problem fyi
ngiacom
(To:jreze)
In my opinion csvuser is the problem. You have to put a user.
I usually use "wcadmin".
LoriSood
23-Emerald I
(To:jreze)
That stack trace is pretty generic and usually there is another error(s) that shows up in the logs along with that. Do you still have the log? If so, can you attach it to the thread?
jreze
7-Bedrock
(To:jreze)
I fixed my problem.
