What is the diffrence between PersistanceHelper vs PersistanceServerHelper ?
vuchekar
Hi All,
Can you please expalin the diffrence between "PersistanceHelper" and "PersistanceServerHelper" ?
and how these classes helps to modify/store object in Windchill , what exactly happens behind, how it make changes in database ?
glv
(To:vuchekar)
PersistenceServerHelper
  • This class implements helper methods for server side PersistenceManagerSvr operations. It is running in the Method Server.
  • The methods of PersistenceManagerSvr provide low level access to the database and bypassed access control operations.
  • PersistenceHelper
  • The class contains utility methods associated with the PersistenceManager. It is running in client application.
  • The methods of PersistenceManager use access control to determine if the user is allowed to operate the business object.
