What to expect from a VAR PLM Consultant
Hello
Imagine you are an end users (maybe you are....) you are working on a project to make big changes on your business system (let be it PLM 🙂 ) You work with your consultant, he develops tools, testing are organized and you start implementing the change.
You find a few bizarre things happening. you check on your test server and you can reproduce. Of course, one can say testing was not done properly. Alright but can you really test everything in everything details ? Especially when it is about moving data from one context to another one in the same organisation.
Now, you investigate further and the consultant says that there is a bug in PDMLink 9.1 M050 (exactly the version you use !!!)
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS12557
Would you expect your consultant to know all the bugs or check if there are any bugs related to Move before ?
Especially that the project is actually only about Moving data (ok create new contexts and ACL).
In other words, should your consultant knows areas of issues in PDMLink that could impact your system and inform you early on in the project by saying. Hold on, you want to do that but beware there are such and such bugs.....
What is your view ?
