When running a workflow, the message "Not submitted. Cannot perform 'Promote'" is displayed and the
MS_10999987
3-Newcomer
Translated by the Community Moderation using Google Translate
Promotion request: Promotion request for reputation management
Lifecycle name:HYOUKA_PR_LC
Open - Under 1st evaluation - Under 2nd evaluation - Approved
Workflow name:HYOKA_WF
With the settings, create a lifecycle and workflow, and use the document created in the product.
Start the workflow process from "New Promotion Request".
First, the first task will be created, so select the created task and check "Promote".
When you click the "Task Complete" button, an error message like the one attached appears and the task is terminated.
Unable to complete.
Thank you for your question.
I encourage you to bring more details and context to your initial inquiry. This will make it easier for you to receive meaningful help from other Community members.
Andra
