How to fetch custom IBA on Change Request using SQL Query?
11025060
I have a custom IBA on a change request. I need to write a SQL query to fetch all ChangeRequests which have a non-null value for that attribute.
Have you tried creating a report query builder first and then using it to generate the SQL query?
How to get the SQL statement of the Query Builder Report
Marco
HelesicPetr
(To:Marco_Tosin)
Hi @Marco_Tosin
Good idea. Just create a report for ChangeRequests add a IBA attribute to the select table and then just check the resulted SQL
PetrH
