I want to take a Business Object(WTDocument) through a approval process.
The Process is simple with only three stages InWork,Review,Approved.
So Which approach to prefer...?
1.Call a promotion request on Document
2. Use a Workflow in the Object LC .
Avinash,
PR for at least 3 reasons:
Avinash,
Hi Ben,
Thanks for the detailed explanation.
And I have decided to use PR .
Avinash, sounds like you should mark Ben's answer as "Correct Answer" then ![]()
