From the -other- forum there's a question about where Creo will look for a format. The user has the pro_format_dir set to point to a local disk directory and wants to know if a connected windchill session will use that setting.
I've only used setups that don't link outside of the Windchill environment for formats, but am interested to know.
x
We are migrating into Windchill, from having no prior PDM, or any real structure. Our formats are all over the place, but as we migrate in we are updating the formats. Here is the instruction I wrote for my users:
Please note that drawing formats are available in Libraries/Templates/CAD Templates. Please do not check in any other formats. Use "Sheet Setup" in the Layout tab to replace the format with the library version before saving it into your workspace.
To fix this, in the PDM workspace, right-click the format (e.g. “a_size_drw.frm”) and choose “Rename.” Change the name and file name to something else (e.g. a-old-format.frm).
Open each of those drawings into Creo, and use Sheet Setup to load the new format via “Browse.”
These are a few issues:
1. You
