Win7 ProE crashes on register after setting cache loc
davehaigh
I'm having another Windows 7 issue.
I have an existing startup script for testing new maintenance builds of ProE. Because I don't want to stomp all over my Production cache, I redirect the cache to another folder. All of this worked on XP. Now on Window 7, ProE crashes when I try to register the server.
My startup script looks like this:
set PTC_WF_ROOT="%USERPROFILE%\pro\WF4_test\PDMLink_Cache\PTC\ProENGINEER"
"P:\wf4-m200-64\proeWildfire 4.0\bin\proe.exe"
The windows short cut has the start in dir set to %USERPROFILE%\pro\WF4_test
After crashing, something is still active, because I can't delete the start in directory because Windows says "The action can't be completed because the folder or a file in it is open in another program. Close the folder or file and try again."
If I log out and log back in I can delete the folder. Not sure what process was left hanging by the crash because xtop is not running.
Stumped.
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
0 REPLIES 0
