Win7 not allowing me to install to network drive
davehaigh
I'm trying to install ProE onto a network drive. The remote server is running 2003 server. I have admin rights on that machine. The server has a share that I have assigned to a drive letter on the local machine.
The local machine is Windows 7, I'm an admin here also.
When I try to install Pro/E on the mapped drive, I get an error that says: (I ran as administrator)
[cid:image001.jpg@01CC9966.2DCB3DB0]
However I can browse to the P: drive and create a new text document, so I do have write access.
If I log into a remote machine that is running XP or Windows 2003, I can install on the mapped drive no problems.
Anyone know how I can make Windows 7 let me install on the mapped drive?
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
Need to select "run as Administrator" on the executable.
I did.
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Livermore, CA 94550
I found the solution. It's a windows 7 thing.
Go to control panel, User Accounts, Change User Account Control settings, and move the slider to the bottom Never Notify.
[cid:image002.jpg@01CC9988.BA9DD690]
Then reboot the machine.
Now you can install onto a networked drive.
David Haigh
