Ensure you have backups running on the database. Its only going to touch what is in the database. If never concerned myself with un-uploaded work with WinRU. Do you do much work with family tables?
Thank you for your reply. Yes we do need to run WCTK to address the errors reported in WinDU's 'ValidateEPMFamilyTable' section. That's why I'm concerned about whether Creo users need to upload/check in their Creo files.
