All -
I have a user who reports that after using a Creo (2.0, M110) session for a while (the amount of time varies), his internal Windchill session (mozilla-based browser) will stop working, and the browser window goes blank/white. Is there some weird config setting for Windchill timeout that he may need or that he has and needs to get rid of? Or does this sound like a machine/network problem (in which case, this is getting chucked over to I.T.....)
Thanks in advance -
Chrystal Johnstone
Seattle, WA
Chrystal Johnstone wrote:
All -I have a user who reports that after using a Creo (2.0, M110) session for a while (the amount of time varies), his internal Windchill session (mozilla-based browser) will stop working, and the browser window goes blank/white. Is there some weird config setting for Windchill timeout that he may need or that he has and needs to get rid of? Or does this sound like a machine/network problem (in which case, this is getting chucked over to I.T.....)
Sounds more like the internal web browser has crashed. Has you tried opening a new tab to see if that works?
We have tried that for sessions that won't open on the first try, but not for one that crashes in mid-use. I'll give it a shot.
Thanks!
Chrystal
