Windchill 10 -- Method Server getting aborted on fresh installation
praghuram
Dear,
I installed new Windchill 10 PDMLink on my machine yesterday. After the completion of installation, the server started properly and I was able to access the GUI. After restarting the machine, I tried starting the server again but no luck. Every time the MethodServer aborts and stops. I am attaching the Method server logs file here with. Please do help me. Its bit urgent and I need to deliver some important tasks by weekend.\
Raghu
9 REPLIES 9
Windchill DS is not running, hence the reference to port 389.
Tyler
Oracle and/or Windchill DS not started
Raghu,
There might be a couple of things at play here. First, you need to make sure that your JNDI adapters are not using the port 389 which is the port for WindchillDS. If so, you need to change that to point to a different port, the property you are looking for is com.ptc.ptcnet.Ldap.java.naming.provider.url. The value of this should be your server name : <port_number>.
Check this and see what it says.
Alexius C. Chukwuka
IT Analyst, Global SAP Basis
Technical Change Management (TCM)
Deere & Company World Headquarters
400 19th St, Moline, IL 61265
Office: (309) 765-3133
Mobile: (319) 429-5336
Raghu,
Tyler's point was my second point which I forgot to mention. If you your JNDI adapters are point to a different port number, check to make sure that WIndchillDS is started and running on your server.
@Tyler: Good point.
Alexius C. Chukwuka
Hi Raghu,
Looks like your WindchillDS server is either not up or not
responding. Restart it once and see if it resolves the issue.
Prathap <">http://www.linkedin.com/in/prathapyalavarthi>
Hi Raghu,
There seems to be an issue with the LDAP. That is after installing PDMlink
10 the LDAP does not run as service, which is started automatically by
Windchill Installation.
So after installing PDMLink goto <windchill home=">\WindchillDS\Server\bat\
and run the file controlpanal.bat and login to the Windchill DS
controlpanel by providing the password that you specified while installing
PDMLink
Now Goto Windows Services section and enable the services for DS. Now goto
services.msc and set the Windchill Directory Server service to automatic
After this all should be fine
Let me know if this has fixed the issue
Cheers!!!
Kals A
Dear Kalidhas,
I am thankful to you for your kind reply. I am able to start the server now. Thanks for giving the steps in detail. Will explore more on this and get back to you if I need any help.
Raghu
Dear Tyler,
Thanks for your kind reply. It helped me a lot to explore the options.
Raghu
Dear Alexius,
Thanks for your kind reply. Appreciate your help.
Raghu
