Windchill 10 installation error:ORA-04030: out of process memory when trying to allocate 1012 bytes (kxs-heap-c,kghsstk)
VivekUchekar
7-Bedrock
Hi All,
I am installing Windchill 10 on Windows XP 32 bit machine.
Oracle: Oracle 11g
All services are runing, while in the last stage of installtion method server gives this error while loading data.
ethod server log as below.
Fri 3/16/12 16:17:23: main:java.sql.SQLException: ORA-04030: out of process memory when trying to allocate 1012 bytes (kxs-heap-c,kghsstk)
Fri 3/16/12 16:17:23: main: Nested exception is: (wt.pom.pomResource/0) wt.pom.PersistenceException: A persistence error occurred. System message follows:
Fri 3/16/12 16:17:23: main: Nested exception is: wt.pom.DatastoreException: A SQL error has occurred for the statement "SELECT 'com.ptc.core.meta.type.mgmt.server.impl.association.DefaultAssociationConstraintItem' FROM (SELECT 'com.ptc.core.meta.type.mgmt.server.impl.association.DefaultAssociationConstraintItem' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DefaultAssociationConstraintIt B0)))) A0 UNION SELECT 'wt.access.AccessPolicyRule' FROM (SELECT 'wt.access.AccessPolicyRule' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AccessPolicyRule B0)))) A0 UNION SELECT 'wt.access.AccessControlSurrogate' FROM (SELECT 'wt.access.AccessControlSurrogate' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AccessControlSurrogate B0)))) A0 UNION SELECT 'wt.admin.AdministrativeDomain' FROM (SELECT 'wt.admin.AdministrativeDomain' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AdministrativeDomain B0)))) A0 UNION SELECT 'com.ptc.core.managedcollection.ManagedCollectionImpl' FROM (SELECT 'com.ptc.core.managedcollection.ManagedCollectionImpl' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ManagedCollection B0)))) A0 UNION SELECT 'wt.folder.Cabinet' FROM (SELECT 'wt.folder.Cabinet' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM Cabinet B0)))) A0 UNION SELECT 'wt.folder.SubFolder' FROM (SELECT 'wt.folder.SubFolder' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM SubFolder B0)))) A0 UNION SELECT 'wt.inf.container.ExchangeContainer' FROM (SELECT 'wt.inf.container.ExchangeContainer' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ExchangeContainer B0)))) A0 UNION SELECT 'wt.inf.container.OrgContainer' FROM (SELECT 'wt.inf.container.OrgContainer' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM OrgContainer B0)))) A0 UNION SELECT 'wt.inf.library.WTLibrary' FROM (SELECT 'wt.inf.library.WTLibrary' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTLibrary B0)))) A0 UNION SELECT 'wt.pdmlink.PDMLinkProduct' FROM (SELECT 'wt.pdmlink.PDMLinkProduct' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PDMLinkProduct B0)))) A0 UNION SELECT 'wt.projmgmt.admin.Project2' FROM (SELECT 'wt.projmgmt.admin.Project2' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM Project2 B0)))) A0 UNION SELECT 'wt.inf.sharing.SharedContainerMap' FROM (SELECT 'wt.inf.sharing.SharedContainerMap' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM SharedContainerMap B0)))) A0 UNION SELECT 'wt.inf.team.ContainerTeam' FROM (SELECT 'wt.inf.team.ContainerTeam' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ContainerTeam B0)))) A0 UNION SELECT 'wt.annotation.AnnotationSet' FROM (SELECT 'wt.annotation.AnnotationSet' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AnnotationSet B0)))) A0 UNION SELECT 'wt.annotation.StructuredAnnotationSet' FROM (SELECT 'wt.annotation.StructuredAnnotationSet' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM StructuredAnnotationSet B0)))) A0 UNION SELECT 'wt.change2.WTChangeDirective' FROM (SELECT 'wt.change2.WTChangeDirective' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTChangeDirective B0)))) A0 UNION SELECT 'wt.effectivity.ConfigurationItem' FROM (SELECT 'wt.effectivity.ConfigurationItem' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ConfigurationItem B0)))) A0 UNION SELECT 'wt.maturity.PromotionNotice' FROM (SELECT 'wt.maturity.PromotionNotice' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PromotionNotice B0)))) A0 UNION SELECT 'wt.vc.baseline.ManagedBaseline' FROM (SELECT 'wt.vc.baseline.ManagedBaseline' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ManagedBaseline B0)))) A0 UNION SELECT 'wt.change2.WTAnalysisActivity' FROM (SELECT 'wt.change2.WTAnalysisActivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTAnalysisActivity B0)))) A0 UNION SELECT 'wt.change2.WTChangeActivity2' FROM (SELECT 'wt.change2.WTChangeActivity2' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTChangeActivity2 B0)))) A0 UNION SELECT 'wt.change2.WTChangeInvestigation' FROM (SELECT 'wt.change2.WTChangeInvestigation' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTChangeInvestigation B0)))) A0 UNION SELECT 'wt.change2.WTChangeProposal' FROM (SELECT 'wt.change2.WTChangeProposal' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTChangeProposal B0)))) A0 UNION SELECT 'wt.change2.WTChangeIssue' FROM (SELECT 'wt.change2.WTChangeIssue' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTChangeIssue B0)))) A0 UNION SELECT 'wt.change2.WTVariance' FROM (SELECT 'wt.change2.WTVariance' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTVariance B0)))) A0 UNION SELECT 'wt.change2.WTChangeOrder2' FROM (SELECT 'wt.change2.WTChangeOrder2' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTChangeOrder2 B0)))) A0 UNION SELECT 'wt.change2.WTChangeRequest2' FROM (SELECT 'wt.change2.WTChangeRequest2' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTChangeRequest2 B0)))) A0 UNION SELECT 'wt.access.agreement.AuthorizationAgreement' FROM (SELECT 'wt.access.agreement.AuthorizationAgreement' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AuthorizationAgreement B0)))) A0 UNION SELECT 'wt.doc.WTDocument' FROM (SELECT 'wt.doc.WTDocument' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTDocument B0)))) A0 UNION SELECT 'wt.federation.ProxyDocument' FROM (SELECT 'wt.federation.ProxyDocument' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProxyDocument B0)))) A0 UNION SELECT 'wt.epm.EPMDocument' FROM (SELECT 'wt.epm.EPMDocument' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMDocument B0)))) A0 UNION SELECT 'wt.part.WTPart' FROM (SELECT 'wt.part.WTPart' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTPart B0)))) A0 UNION SELECT 'com.ptc.windchill.option.model.Choice' FROM (SELECT 'com.ptc.windchill.option.model.Choice' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ATOChoice B0)))) A0 UNION SELECT 'com.ptc.windchill.option.model.OptionSet' FROM (SELECT 'com.ptc.windchill.option.model.OptionSet' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM OptionSet B0)))) A0 UNION SELECT 'wt.part.alternaterep.WTPartAlternateRep' FROM (SELECT 'wt.part.alternaterep.WTPartAlternateRep' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTPartAlternateRep B0)))) A0 UNION SELECT 'wt.replication.unit.WTUnit' FROM (SELECT 'wt.replication.unit.WTUnit' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTUnit B0)))) A0 UNION SELECT 'com.ptc.wpcfg.doc.VariantSpec' FROM (SELECT 'com.ptc.wpcfg.doc.VariantSpec' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM VariantSpec B0)))) A0 UNION SELECT 'wt.part.WTProductConfiguration' FROM (SELECT 'wt.part.WTProductConfiguration' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTProductConfiguration B0)))) A0 UNION SELECT 'wt.part.WTProductInstance2' FROM (SELECT 'wt.part.WTProductInstance2' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTProductInstance2 B0)))) A0 UNION SELECT 'wt.change2.workset.WTWorkSet' FROM (SELECT 'wt.change2.workset.WTWorkSet' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTWorkSet B0)))) A0 UNION SELECT 'com.ptc.windchill.wp.WorkPackage' FROM (SELECT 'com.ptc.windchill.wp.WorkPackage' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WorkPackage B0)))) A0 UNION SELECT 'com.ptc.windchill.wp.tdp.TechnicalDataPackage' FROM (SELECT 'com.ptc.windchill.wp.tdp.TechnicalDataPackage' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM TechnicalDataPackage B0)))) A0 UNION SELECT 'wt.meeting.actionitem.DiscreteActionItem' FROM (SELECT 'wt.meeting.actionitem.DiscreteActionItem' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DiscreteActionItem B0)))) A0 UNION SELECT 'wt.viewmarkup.LifeCycleManagedWtMarkUp' FROM (SELECT 'wt.viewmarkup.LifeCycleManagedWtMarkUp' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM LifeCycleManagedWtMarkUp B0)))) A0 UNION SELECT 'wt.replication.sender.UnitSendRecord' FROM (SELECT 'wt.replication.sender.UnitSendRecord' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM UnitSendRecord B0)))) A0 UNION SELECT 'com.ptc.wpcfg.family.EngineState' FROM (SELECT 'com.ptc.wpcfg.family.EngineState' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EngineState B0)))) A0 UNION SELECT 'wt.meeting.MeetingCenterMeeting' FROM (SELECT 'wt.meeting.MeetingCenterMeeting' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM MeetingCenterMeeting B0)))) A0 UNION SELECT 'wt.meeting.TraditionalMeeting' FROM (SELECT 'wt.meeting.TraditionalMeeting' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM TraditionalMeeting B0)))) A0 UNION SELECT 'wt.notify.NotificationSubscription' FROM (SELECT 'wt.notify.NotificationSubscription' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM NotificationSubscription B0)))) A0 UNION SELECT 'wt.notify.ObjectSubscription' FROM (SELECT 'wt.notify.ObjectSubscription' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ObjectSubscription B0)))) A0 UNION SELECT 'wt.org.WTGroup' FROM (SELECT 'wt.org.WTGroup' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTGroup B0)))) A0 UNION SELECT 'wt.federation.ProxyGroup' FROM (SELECT 'wt.federation.ProxyGroup' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProxyGroup B0)))) A0 UNION SELECT 'wt.org.WTOrganization' FROM (SELECT 'wt.org.WTOrganization' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTOrganization B0)))) A0 UNION SELECT 'wt.org.WTUser' FROM (SELECT 'wt.org.WTUser' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTUser B0)))) A0 UNION SELECT 'wt.federation.ProxyUser' FROM (SELECT 'wt.federation.ProxyUser' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProxyUser B0)))) A0 UNION SELECT 'wt.project.Project' FROM (SELECT 'wt.project.Project' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM Project B0)))) A0 UNION SELECT 'wt.team.Team' FROM (SELECT 'wt.team.Team' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM Team B0)))) A0 UNION SELECT 'wt.team.TeamDistributionList' FROM (SELECT 'wt.team.TeamDistributionList' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM TeamDistributionList B0)))) A0 UNION SELECT 'wt.team.TeamTemplate' FROM (SELECT 'wt.team.TeamTemplate' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM TeamTemplate B0)))) A0 UNION SELECT 'wt.viewmarkup.DerivedImage' FROM (SELECT 'wt.viewmarkup.DerivedImage' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DerivedImage B0)))) A0 UNION SELECT 'wt.viewmarkup.WTMarkUp' FROM (SELECT 'wt.viewmarkup.WTMarkUp' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTMarkUp B0)))) A0 UNION SELECT 'com.ptc.windchill.wp.delivery.DeliveryRecord' FROM (SELECT 'com.ptc.windchill.wp.delivery.DeliveryRecord' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DeliveryRecord B0)))) A0 UNION SELECT 'com.ptc.core.percol.PersistedCollection' FROM (SELECT 'com.ptc.core.percol.PersistedCollection' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PersistedCollection B0)))) A0 UNION SELECT 'wt.access.WTAclEntry' FROM (SELECT 'wt.access.WTAclEntry' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTAclEntry B0)))) A0 UNION SELECT 'wt.access.agreement.AgreementAuthorizedObject' FROM (SELECT 'wt.access.agreement.AgreementAuthorizedObject' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AgreementAuthorizedObject B0)))) A0 UNION SELECT 'wt.access.agreement.AgreementAuthorizedProxy' FROM (SELECT 'wt.access.agreement.AgreementAuthorizedProxy' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AgreementAuthorizedProxy B0)))) A0 UNION SELECT 'wt.epm.alternaterep.EPMDefinitionRule' FROM (SELECT 'wt.epm.alternaterep.EPMDefinitionRule' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMDefinitionRule B0)))) A0 UNION SELECT 'wt.part.alternaterep.SimpleStructFilterRule' FROM (SELECT 'wt.part.alternaterep.SimpleStructFilterRule' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM SimpleStructFilterRule B0)))) A0 UNION SELECT 'wt.structfilter.rule.attribute.AttributeStructFilterRule' FROM (SELECT 'wt.structfilter.rule.attribute.AttributeStructFilterRule' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AttributeStructFilterRule B0)))) A0 UNION SELECT 'wt.spatial.SpatialStructFilterRule' FROM (SELECT 'wt.spatial.SpatialStructFilterRule' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM SpatialStructFilterRule B0)))) A0 UNION SELECT 'wt.part.WTPartMaster' FROM (SELECT 'wt.part.WTPartMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTPartMaster B0)))) A0 UNION SELECT 'wt.federation.ProxyPartMaster' FROM (SELECT 'wt.federation.ProxyPartMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProxyPartMaster B0)))) A0 UNION SELECT 'wt.audit.eventinfo.AssociateDisassociateEventInfo' FROM (SELECT 'wt.audit.eventinfo.AssociateDisassociateEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AssociateDisassociateEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.CSRFEventInfo' FROM (SELECT 'wt.audit.eventinfo.CSRFEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM CSRFEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.ChangeIdentityEventInfo' FROM (SELECT 'wt.audit.eventinfo.ChangeIdentityEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ChangeIdentityEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.ChangeLifecycleStateEventInfo' FROM (SELECT 'wt.audit.eventinfo.ChangeLifecycleStateEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ChangeLifecycleStateEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.CheckInEventInfo' FROM (SELECT 'wt.audit.eventinfo.CheckInEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM CheckInEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.CheckoutEventInfo' FROM (SELECT 'wt.audit.eventinfo.CheckoutEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM CheckoutEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.CopyEventInfo' FROM (SELECT 'wt.audit.eventinfo.CopyEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM CopyEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.DownloadEventInfo' FROM (SELECT 'wt.audit.eventinfo.DownloadEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DownloadEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.MarkupAnnotateEventInfo' FROM (SELECT 'wt.audit.eventinfo.MarkupAnnotateEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM MarkupAnnotateEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.ModifyAccessPolicyEventInfo' FROM (SELECT 'wt.audit.eventinfo.ModifyAccessPolicyEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ModifyAccessPolicyEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.ModifyContentEventInfo' FROM (SELECT 'wt.audit.eventinfo.ModifyContentEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ModifyContentEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.ModifyGroupEventInfo' FROM (SELECT 'wt.audit.eventinfo.ModifyGroupEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ModifyGroupEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.ModifyObjectAccessEventInfo' FROM (SELECT 'wt.audit.eventinfo.ModifyObjectAccessEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ModifyObjectAccessEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.ModifyOrgRoleEventInfo' FROM (SELECT 'wt.audit.eventinfo.ModifyOrgRoleEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ModifyOrgRoleEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.ModifyProdStructureEventInfo' FROM (SELECT 'wt.audit.eventinfo.ModifyProdStructureEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ModifyProdStructureEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.ModifySecurityLabelsEventInfo' FROM (SELECT 'wt.audit.eventinfo.ModifySecurityLabelsEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ModifySecurityLabelsEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.ModifyTeamEventInfo' FROM (SELECT 'wt.audit.eventinfo.ModifyTeamEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ModifyTeamEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.ModifyTeamRoleEventInfo' FROM (SELECT 'wt.audit.eventinfo.ModifyTeamRoleEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ModifyTeamRoleEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.MoveEventInfo' FROM (SELECT 'wt.audit.eventinfo.MoveEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM MoveEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.NotAuthorizedAccessEventInfo' FROM (SELECT 'wt.audit.eventinfo.NotAuthorizedAccessEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM NotAuthorizedAccessEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.SLDownloadAckEventInfo' FROM (SELECT 'wt.audit.eventinfo.SLDownloadAckEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM SLDownloadAckEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.SearchEventInfo' FROM (SELECT 'wt.audit.eventinfo.SearchEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM SearchEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.ShareEventInfo' FROM (SELECT 'wt.audit.eventinfo.ShareEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ShareEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.UserSessionEventInfo' FROM (SELECT 'wt.audit.eventinfo.UserSessionEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM UserSessionEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.VersionEventInfo' FROM (SELECT 'wt.audit.eventinfo.VersionEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM VersionEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.ViewRepresentationsEventInfo' FROM (SELECT 'wt.audit.eventinfo.ViewRepresentationsEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ViewRepresentationsEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.WorkflowVariableEventInfo' FROM (SELECT 'wt.audit.eventinfo.WorkflowVariableEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WorkflowVariableEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.CADNameChangeEventInfo' FROM (SELECT 'wt.audit.eventinfo.CADNameChangeEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM CADNameChangeEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.LocationChangeEventInfo' FROM (SELECT 'wt.audit.eventinfo.LocationChangeEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM LocationChangeEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.RenameEventInfo' FROM (SELECT 'wt.audit.eventinfo.RenameEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RenameEventInfo B0)))) A0 UNION SELECT 'wt.esi.ERPPartSpecificPlantData' FROM (SELECT 'wt.esi.ERPPartSpecificPlantData' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ERPPartSpecificPlantData B0)))) A0 UNION SELECT 'wt.epm.modelitems.ModelItem' FROM (SELECT 'wt.epm.modelitems.ModelItem' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ModelItem B0)))) A0 UNION SELECT 'wt.change2.AffectedActivityData' FROM (SELECT 'wt.change2.AffectedActivityData' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AffectedActivityData B0)))) A0 UNION SELECT 'wt.change2.ChangeRecord2' FROM (SELECT 'wt.change2.ChangeRecord2' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ChangeRecord2 B0)))) A0 UNION SELECT 'wt.change2.RelevantRequestData2' FROM (SELECT 'wt.change2.RelevantRequestData2' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RelevantRequestData2 B0)))) A0 UNION SELECT 'wt.change2.ReportedAgainst' FROM (SELECT 'wt.change2.ReportedAgainst' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ReportedAgainst B0)))) A0 UNION SELECT 'wt.change2.ProblemProduct' FROM (SELECT 'wt.change2.ProblemProduct' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProblemProduct B0)))) A0 UNION SELECT 'wt.change2.SubjectProduct' FROM (SELECT 'wt.change2.SubjectProduct' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM SubjectProduct B0)))) A0 UNION SELECT 'wt.change2.SupportingDataFor' FROM (SELECT 'wt.change2.SupportingDataFor' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM SupportingDataFor B0)))) A0 UNION SELECT 'wt.part.WTProductInstanceMaster' FROM (SELECT 'wt.part.WTProductInstanceMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTProductInstanceMaster B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMSepFamilyTable' FROM (SELECT 'wt.epm.familytable.EPMSepFamilyTable' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMSepFamilyTable B0)))) A0 UNION SELECT 'wt.meeting.MeetingDeliverable' FROM (SELECT 'wt.meeting.MeetingDeliverable' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM MeetingDeliverable B0)))) A0 UNION SELECT 'wt.org.electronicIdentity.ElectronicSignature' FROM (SELECT 'wt.org.electronicIdentity.ElectronicSignature' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ElectronicSignature B0)))) A0 UNION SELECT 'wt.workflow.definer.WfProcessTemplate' FROM (SELECT 'wt.workflow.definer.WfProcessTemplate' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WfProcessTemplate B0)))) A0 UNION SELECT 'wt.ixb.conflictFramework.ImportSession' FROM (SELECT 'wt.ixb.conflictFramework.ImportSession' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ImportSession B0)))) A0 UNION SELECT 'com.ptc.windchill.ixb.importer.ImportJob' FROM (SELECT 'com.ptc.windchill.ixb.importer.ImportJob' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ImportJob B0)))) A0 UNION SELECT 'wt.effectivity.engine.EffectivityConfigurationHolder' FROM (SELECT 'wt.effectivity.engine.EffectivityConfigurationHolder' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EffectivityConfigurationHolder B0)))) A0 UNION SELECT 'wt.inf.template.DefaultWTContainerTemplate' FROM (SELECT 'wt.inf.template.DefaultWTContainerTemplate' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DefaultWTContainerTemplate B0)))) A0 UNION SELECT 'wt.viewmarkup.WVSConfigurationTemplate' FROM (SELECT 'wt.viewmarkup.WVSConfigurationTemplate' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WVSConfigurationTemplate B0)))) A0 UNION SELECT 'wt.workflow.engine.WfProcess' FROM (SELECT 'wt.workflow.engine.WfProcess' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WfProcess B0)))) A0 UNION SELECT 'wt.projmgmt.execution.ProjectPlan' FROM (SELECT 'wt.projmgmt.execution.ProjectPlan' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProjectPlan B0)))) A0 UNION SELECT 'wt.workflow.forum.DiscussionPosting' FROM (SELECT 'wt.workflow.forum.DiscussionPosting' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DiscussionPosting B0)))) A0 UNION SELECT 'wt.workflow.notebook.ImportedBookmark' FROM (SELECT 'wt.workflow.notebook.ImportedBookmark' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ImportedBookmark B0)))) A0 UNION SELECT 'wt.workflow.templates.TaskFormTemplate' FROM (SELECT 'wt.workflow.templates.TaskFormTemplate' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM TaskFormTemplate B0)))) A0 UNION SELECT 'wt.dataops.archive.ArchiveRecord' FROM (SELECT 'wt.dataops.archive.ArchiveRecord' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ArchiveRecord B0)))) A0 UNION SELECT 'wt.dataops.archive.RestoreRecord' FROM (SELECT 'wt.dataops.archive.RestoreRecord' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RestoreRecord B0)))) A0 UNION SELECT 'wt.dataops.purge.PurgeRecord' FROM (SELECT 'wt.dataops.purge.PurgeRecord' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PurgeRecord B0)))) A0 UNION SELECT 'wt.dataops.purge.PurgeSchedule' FROM (SELECT 'wt.dataops.purge.PurgeSchedule' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PurgeSchedule B0)))) A0 UNION SELECT 'wt.dataops.replication.ContentReplSchedule' FROM (SELECT 'wt.dataops.replication.ContentReplSchedule' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ContentReplSchedule B0)))) A0 UNION SELECT 'com.ptc.windchill.dpimpl.core.DPImplSchedule' FROM (SELECT 'com.ptc.windchill.dpimpl.core.DPImplSchedule' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DPImplSchedule B0)))) A0 UNION SELECT 'wt.dataops.replication.ContentReplRecord' FROM (SELECT 'wt.dataops.replication.ContentReplRecord' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ContentReplRecord B0)))) A0 UNION SELECT 'com.ptc.windchill.dpimpl.core.DPImplJob' FROM (SELECT 'com.ptc.windchill.dpimpl.core.DPImplJob' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DPImplJob B0)))) A0 UNION SELECT 'com.ptc.windchill.wp.imp.IncomingDeliveryRecord' FROM (SELECT 'com.ptc.windchill.wp.imp.IncomingDeliveryRecord' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM IncomingDeliveryRecord B0)))) A0 UNION SELECT 'com.ptc.windchill.sync.wpsync.ExportRecord' FROM (SELECT 'com.ptc.windchill.sync.wpsync.ExportRecord' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ExportRecord B0)))) A0 UNION SELECT 'wt.dataops.archive.Archive' FROM (SELECT 'wt.dataops.archive.Archive' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM Archive B0)))) A0 UNION SELECT 'wt.replication.export.UnitExportRecord' FROM (SELECT 'wt.replication.export.UnitExportRecord' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM UnitExportRecord B0)))) A0 UNION SELECT 'wt.replication.imp.UnitImportRecord' FROM (SELECT 'wt.replication.imp.UnitImportRecord' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM UnitImportRecord B0)))) A0 UNION SELECT 'wt.replication.receiver.UnitReceiveRecord' FROM (SELECT 'wt.replication.receiver.UnitReceiveRecord' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM UnitReceiveRecord B0)))) A0 UNION SELECT 'com.ptc.windchill.dpimpl.core.WTProcessStepInstance' FROM (SELECT 'com.ptc.windchill.dpimpl.core.WTProcessStepInstance' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTProcessStepInstance B0)))) A0 UNION SELECT 'com.ptc.windchill.sync.wpsync.SyncInfo' FROM (SELECT 'com.ptc.windchill.sync.wpsync.SyncInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM SyncInfo B0)))) A0 UNION SELECT 'wt.content.QuarantinedDescription' FROM (SELECT 'wt.content.QuarantinedDescription' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM QuarantinedDescription B0)))) A0 UNION SELECT 'wt.content.StreamData' FROM (SELECT 'wt.content.StreamData' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM StreamData B0)))) A0 UNION SELECT 'wt.fv.FvItem' FROM (SELECT 'wt.fv.FvItem' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM FvItem B0)))) A0 UNION SELECT 'wt.fv.master.MasteredOnReplicaItem' FROM (SELECT 'wt.fv.master.MasteredOnReplicaItem' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM MasteredOnReplicaItem B0)))) A0 UNION SELECT 'wt.eff.EffChangeAudit' FROM (SELECT 'wt.eff.EffChangeAudit' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EffChangeAudit B0)))) A0 UNION SELECT 'wt.part.WTPartUsageLink' FROM (SELECT 'wt.part.WTPartUsageLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTPartUsageLink B0)))) A0 UNION SELECT 'wt.change2.ChangeAction' FROM (SELECT 'wt.change2.ChangeAction' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ChangeAction B0)))) A0 UNION SELECT 'wt.change2.VarianceBlockEffectivity' FROM (SELECT 'wt.change2.VarianceBlockEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM VarianceBlockEffectivity B0)))) A0 UNION SELECT 'wt.change2.VarianceDateEffectivity' FROM (SELECT 'wt.change2.VarianceDateEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM VarianceDateEffectivity B0)))) A0 UNION SELECT 'wt.change2.VarianceLotNumberEffectivity' FROM (SELECT 'wt.change2.VarianceLotNumberEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM VarianceLNEffectivity B0)))) A0 UNION SELECT 'wt.change2.VarianceMSNEffectivity' FROM (SELECT 'wt.change2.VarianceMSNEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM VarianceMSNEffectivity B0)))) A0 UNION SELECT 'wt.change2.VarianceSerialNumberEffectivity' FROM (SELECT 'wt.change2.VarianceSerialNumberEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM VarianceSNEffectivity B0)))) A0 UNION SELECT 'wt.eff.CalculatedMSNEffectivity' FROM (SELECT 'wt.eff.CalculatedMSNEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM CalculatedMSNEffectivity B0)))) A0 UNION SELECT 'wt.effectivity.WTIncorporationDate' FROM (SELECT 'wt.effectivity.WTIncorporationDate' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTIncorporationDate B0)))) A0 UNION SELECT 'wt.effectivity.WTLotEffectivity' FROM (SELECT 'wt.effectivity.WTLotEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTLotEffectivity B0)))) A0 UNION SELECT 'wt.effectivity.WTSerialNumberedEffectivity' FROM (SELECT 'wt.effectivity.WTSerialNumberedEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTSerialNumberedEffectivity B0)))) A0 UNION SELECT 'wt.effectivity.WTDatedEffectivity' FROM (SELECT 'wt.effectivity.WTDatedEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTDatedEffectivity B0)))) A0 UNION SELECT 'wt.part.ProductBlockEffectivity' FROM (SELECT 'wt.part.ProductBlockEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProductBlockEffectivity B0)))) A0 UNION SELECT 'wt.part.ProductDateEffectivity' FROM (SELECT 'wt.part.ProductDateEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProductDateEffectivity B0)))) A0 UNION SELECT 'wt.part.ProductLotNumberEffectivity' FROM (SELECT 'wt.part.ProductLotNumberEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProductLNEffectivity B0)))) A0 UNION SELECT 'wt.part.ProductMSNEffectivity' FROM (SELECT 'wt.part.ProductMSNEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProductMSNEffectivity B0)))) A0 UNION SELECT 'wt.part.ProductSerialNumberEffectivity' FROM (SELECT 'wt.part.ProductSerialNumberEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProductSNEffectivity B0)))) A0 UNION SELECT 'wt.eff.PendingBlockEffectivity' FROM (SELECT 'wt.eff.PendingBlockEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PendingBlockEffectivity B0)))) A0 UNION SELECT 'wt.eff.PendingDateEffectivity' FROM (SELECT 'wt.eff.PendingDateEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PendingDateEffectivity B0)))) A0 UNION SELECT 'wt.eff.PendingLotNumberEffectivity' FROM (SELECT 'wt.eff.PendingLotNumberEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PendingLNEffectivity B0)))) A0 UNION SELECT 'wt.eff.PendingMSNEffectivity' FROM (SELECT 'wt.eff.PendingMSNEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PendingMSNEffectivity B0)))) A0 UNION SELECT 'wt.eff.PendingSerialNumberEffectivity' FROM (SELECT 'wt.eff.PendingSerialNumberEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PendingSNEffectivity B0)))) A0 UNION SELECT 'wt.epm.EPMAuthoringAppVersion' FROM (SELECT 'wt.epm.EPMAuthoringAppVersion' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMAuthoringAppVersion B0)))) A0 UNION SELECT 'wt.epm.EPMCADNamespace' FROM (SELECT 'wt.epm.EPMCADNamespace' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMCADNamespace B0)))) A0 UNION SELECT 'wt.epm.alternaterep.EPMResultRule' FROM (SELECT 'wt.epm.alternaterep.EPMResultRule' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMResultRule B0)))) A0 UNION SELECT 'wt.epm.structure.EPMMemberLink' FROM (SELECT 'wt.epm.structure.EPMMemberLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMMemberLink B0)))) A0 UNION SELECT 'wt.epm.annotation.EPMStructureAnnotation' FROM (SELECT 'wt.epm.annotation.EPMStructureAnnotation' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMStructureAnnotation B0)))) A0 UNION SELECT 'wt.epm.annotation.EPMStructAnnotationAddMatchingData' FROM (SELECT 'wt.epm.annotation.EPMStructAnnotationAddMatchingData' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMStructAnnAddMatchingData B0)))) A0 UNION SELECT 'wt.epm.annotation.EPMStructAnnotationReplaceData' FROM (SELECT 'wt.epm.annotation.EPMStructAnnotationReplaceData' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMStructAnnotationReplaceData B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMFamilyTableCell' FROM (SELECT 'wt.epm.familytable.EPMFamilyTableCell' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMFamilyTableCell B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMFamilyTableCellDependency' FROM (SELECT 'wt.epm.familytable.EPMFamilyTableCellDependency' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMFamilyTableCellDep B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMFamilyTableAttribute' FROM (SELECT 'wt.epm.familytable.EPMFamilyTableAttribute' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMFamilyTableAttribute B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMFamilyTableFeature' FROM (SELECT 'wt.epm.familytable.EPMFamilyTableFeature' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMFamilyTableFeature B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMFamilyTableMember' FROM (SELECT 'wt.epm.familytable.EPMFamilyTableMember' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMFamilyTableMember B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMFamilyTableParameter' FROM (SELECT 'wt.epm.familytable.EPMFamilyTableParameter' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMFamilyTableParameter B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMFamilyTableReference' FROM (SELECT 'wt.epm.familytable.EPMFamilyTableReference' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMFamilyTableReference B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMFeatureDefinition' FROM (SELECT 'wt.epm.familytable.EPMFeatureDefinition' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMFeatureDefinition B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMSepFamilyTableMaster' FROM (SELECT 'wt.epm.familytable.EPMSepFamilyTableMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMSepFamilyTableMaster B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMParameterDefinition' FROM (SELECT 'wt.epm.familytable.EPMParameterDefinition' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMParameterDefinition B0)))) A0 UNION SELECT 'wt.epm.workspaces.EPMCheckpoint' FROM (SELECT 'wt.epm.workspaces.EPMCheckpoint' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMCheckpoint B0)))) A0 UNION SELECT 'wt.epm.occurrence.EPMOccurrenceTable' FROM (SELECT 'wt.epm.occurrence.EPMOccurrenceTable' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMOccurrenceTable B0)))) A0 UNION SELECT 'wt.epm.supportingdata.EPMSupportingData' FROM (SELECT 'wt.epm.supportingdata.EPMSupportingData' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMSupportingData B0)))) A0 UNION SELECT 'wt.epm.workspaces.EPMWorkspace' FROM (SELECT 'wt.epm.workspaces.EPMWorkspace' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspace B0)))) A0 UNION SELECT 'wt.epm.workspaces.ClientCacheState' FROM (SELECT 'wt.epm.workspaces.ClientCacheState' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ClientCacheState B0)))) A0 UNION SELECT 'wt.epm.workspaces.EPMInitialCheckinData' FROM (SELECT 'wt.epm.workspaces.EPMInitialCheckinData' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMInitialCheckinData B0)))) A0 UNION SELECT 'wt.epm.workspaces.EPMUpdateCounter' FROM (SELECT 'wt.epm.workspaces.EPMUpdateCounter' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMUpdateCounter B0)))) A0 UNION SELECT 'wt.epm.workspaces.EPMWorkspaceNamespace' FROM (SELECT 'wt.epm.workspaces.EPMWorkspaceNamespace' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspaceNamespace B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspaceMemberStatus' FROM (SELECT 'wt.epm.workspaces.WorkspaceMemberStatus' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WorkspaceMemberStatus B0)))) A0 UNION SELECT 'wt.epm.build.EPMBuildHistory' FROM (SELECT 'wt.epm.build.EPMBuildHistory' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMBuildHistory B0)))) A0 UNION SELECT 'wt.epm.build.EPMBuildRuleAssociationLink' FROM (SELECT 'wt.epm.build.EPMBuildRuleAssociationLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMBuildRuleAssociationLink B0)))) A0 UNION SELECT 'wt.epm.structure.EPMDescribeLink' FROM (SELECT 'wt.epm.structure.EPMDescribeLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMDescribeLink B0)))) A0 UNION SELECT 'wt.esi.ERPMaterialDocumentDescribeLink' FROM (SELECT 'wt.esi.ERPMaterialDocumentDescribeLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ERPMATERIALDOCDESCRIBELINK B0)))) A0 UNION SELECT 'wt.esi.ERPMaterialDocumentReferenceLink' FROM (SELECT 'wt.esi.ERPMaterialDocumentReferenceLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ERPMATERIALDOCREFERENCELINK B0)))) A0 UNION SELECT 'wt.esi.ERPMaterialEPMDocumentDescribeLink' FROM (SELECT 'wt.esi.ERPMaterialEPMDocumentDescribeLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ERPMATERIALEPMDOCDESCRIBELINK B0)))) A0 UNION SELECT 'wt.part.WTPartDescribeLink' FROM (SELECT 'wt.part.WTPartDescribeLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTPartDescribeLink B0)))) A0 UNION SELECT 'wt.part.WTPartReferenceLink' FROM (SELECT 'wt.part.WTPartReferenceLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTPartReferenceLink B0)))) A0 UNION SELECT 'wt.esi.ERPMaterial' FROM (SELECT 'wt.esi.ERPMaterial' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ERPMaterial B0)))) A0 UNION SELECT 'wt.part.PartUsesOccurrence' FROM (SELECT 'wt.part.PartUsesOccurrence' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PartUsesOccurrence B0)))) A0 UNION SELECT 'wt.change2.workset.WTWorkSetComponentLink' FROM (SELECT 'wt.change2.workset.WTWorkSetComponentLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTWorkSetComponentLink B0)))) A0 UNION SELECT 'wt.change2.workset.WTWorkSetReferenceLink' FROM (SELECT 'wt.change2.workset.WTWorkSetReferenceLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTWorkSetReferenceLink B0)))) A0 UNION SELECT 'com.ptc.windchill.wp.WorkPackageMaster' FROM (SELECT 'com.ptc.windchill.wp.WorkPackageMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WorkPackageMaster B0)))) A0 UNION SELECT 'com.ptc.windchill.wp.tdp.TechnicalDataPackageMaster' FROM (SELECT 'com.ptc.windchill.wp.tdp.TechnicalDataPackageMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM TechnicalDataPackageMaster B0)))) A0 UNION SELECT 'wt.fv.master.ReplicaVault' FROM (SELECT 'wt.fv.master.ReplicaVault' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ReplicaVault B0)))) A0 UNION SELECT 'com.ptc.core.percol.PersistedCollectionTombstone' FROM (SELECT 'com.ptc.core.percol.PersistedCollectionTombstone' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PersistedCollectionTombstone B0)))) A0 UNION SELECT 'com.ptc.core.percol.PersistedCollectionTombstoneHolder' FROM (SELECT 'com.ptc.core.percol.PersistedCollectionTombstoneHolder' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PersistedCollectionTombHolder B0)))) A0 UNION SELECT 'com.ptc.core.percol.SimpleNestedCollectionImpl' FROM (SELECT 'com.ptc.core.percol.SimpleNestedCollectionImpl' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM SimpleNestedCollection B0)))) A0 UNION SELECT 'wt.content.DataFormat' FROM (SELECT 'wt.content.DataFormat' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DataFormat B0)))) A0 UNION SELECT 'wt.access.agreement.AuthorizationAgreementMaster' FROM (SELECT 'wt.access.agreement.AuthorizationAgreementMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AuthorizationAgreementMaster B0)))) A0 UNION SELECT 'wt.doc.WTDocumentMaster' FROM (SELECT 'wt.doc.WTDocumentMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTDocumentMaster B0)))) A0 UNION SELECT 'wt.federation.ProxyDocumentMaster' FROM (SELECT 'wt.federation.ProxyDocumentMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProxyDocumentMaster B0)))) A0 UNION SELECT 'wt.epm.EPMDocumentMaster' FROM (SELECT 'wt.epm.EPMDocumentMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMDocumentMaster B0)))) A0 UNION SELECT 'wt.inf.template.WTContainerTemplateMaster' FROM (SELECT 'wt.inf.template.WTContainerTemplateMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTContainerTemplateMaster B0)))) A0 UNION SELECT 'wt.lifecycle.LifeCycleTemplateMaster' FROM (SELECT 'wt.lifecycle.LifeCycleTemplateMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM LifeCycleTemplateMaster B0)))) A0 UNION SELECT 'wt.workflow.definer.WfProcessTemplateMaster' FROM (SELECT 'wt.workflow.definer.WfProcessTemplateMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WfProcessTemplateMaster B0)))) A0 UNION SELECT 'wt.workflow.templates.TaskFormTemplateMaster' FROM (SELECT 'wt.workflow.templates.TaskFormTemplateMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM TaskFormTemplateMaster B0)))) A0 UNION SELECT 'com.ptc.windchill.option.model.ChoiceMaster' FROM (SELECT 'com.ptc.windchill.option.model.ChoiceMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ATOChoiceMaster B0)))) A0 UNION SELECT 'com.ptc.windchill.option.model.ChoiceConstraintMaster' FROM (SELECT 'com.ptc.windchill.option.model.ChoiceConstraintMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ChoiceConstraintMaster B0)))) A0 UNION SELECT 'com.ptc.windchill.option.model.ChoiceMappingMaster' FROM (SELECT 'com.ptc.windchill.option.model.ChoiceMappingMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ChoiceMappingMaster B0)))) A0 UNION SELECT 'com.ptc.windchill.option.model.OptionSetMaster' FROM (SELECT 'com.ptc.windchill.option.model.OptionSetMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM OptionSetMaster B0)))) A0 UNION SELECT 'wt.dataops.objectcol.BaseCriterionDefMaster' FROM (SELECT 'wt.dataops.objectcol.BaseCriterionDefMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM BaseCriterionDefMaster B0)))) A0 UNION SELECT 'wt.dataops.objectcol.CollectionCriterionDefMaster' FROM (SELECT 'wt.dataops.objectcol.CollectionCriterionDefMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM CollectionCriterionDefMaster B0)))) A0 UNION SELECT 'wt.dataops.objectcol.AttrCriterionDefMaster' FROM (SELECT 'wt.dataops.objectcol.AttrCriterionDefMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AttrCriterionDefMaster B0)))) A0 UNION SELECT 'wt.dataops.objectcol.ObjTypeCriterionDefMaster' FROM (SELECT 'wt.dataops.objectcol.ObjTypeCriterionDefMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ObjTypeCriterionDefMaster B0)))) A0 UNION SELECT 'wt.dataops.objectcol.RelationshipDefMaster' FROM (SELECT 'wt.dataops.objectcol.RelationshipDefMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RelationshipDefMaster B0)))) A0 UNION SELECT 'wt.dataops.objectcol.FilterCriterionDefMaster' FROM (SELECT 'wt.dataops.objectcol.FilterCriterionDefMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM FilterCriterionDefMaster B0)))) A0 UNION SELECT 'wt.dataops.objectcol.MethodDefMaster' FROM (SELECT 'wt.dataops.objectcol.MethodDefMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM MethodDefMaster B0)))) A0 UNION SELECT 'wt.dataops.objectcol.RelationshipMapDefMaster' FROM (SELECT 'wt.dataops.objectcol.RelationshipMapDefMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RelationshipMapDefMaster B0)))) A0 UNION SELECT 'wt.dataops.objectcol.CollectionCriteriaMaster' FROM (SELECT 'wt.dataops.objectcol.CollectionCriteriaMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM CollectionCriteriaMaster B0)))) A0 UNION SELECT 'wt.replication.unit.WTUnitMaster' FROM (SELECT 'wt.replication.unit.WTUnitMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTUnitMaster B0)))) A0 UNION SELECT 'com.ptc.wpcfg.doc.VariantSpecMaster' FROM (SELECT 'com.ptc.wpcfg.doc.VariantSpecMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM VariantSpecMaster B0)))) A0 UNION SELECT 'wt.folder.SubFolderLink' FROM (SELECT 'wt.folder.SubFolderLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM SubFolderLink B0)))) A0 UNION SELECT 'wt.change2.WTAnalysisActivityMaster' FROM (SELECT 'wt.change2.WTAnalysisActivityMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTAnalysisActivityMaster B0)))) A0 UNION SELECT 'wt.change2.WTChangeActivity2Master' FROM (SELECT 'wt.change2.WTChangeActivity2Master' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTChangeActivity2Master B0)))) A0 UNION SELECT 'wt.change2.WTChangeInvestigationMaster' FROM (SELECT 'wt.change2.WTChangeInvestigationMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTChangeInvestigationMaster B0)))) A0 UNION SELECT 'wt.change2.WTChangeIssueMaster' FROM (SELECT 'wt.change2.WTChangeIssueMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTChangeIssueMaster B0)))) A0 UNION SELECT 'wt.change2.WTChangeOrder2Master' FROM (SELECT 'wt.change2.WTChangeOrder2Master' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTChangeOrder2Master B0)))) A0 UNION SELECT 'wt.change2.WTChangeProposalMaster' FROM (SELECT 'wt.change2.WTChangeProposalMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTChangeProposalMaster B0)))) A0 UNION SELECT 'wt.change2.WTChangeRequest2Master' FROM (SELECT 'wt.change2.WTChangeRequest2Master' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTChangeRequest2Master B0)))) A0 UNION SELECT 'wt.change2.WTVarianceMaster' FROM (SELECT 'wt.change2.WTVarianceMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTVarianceMaster B0)))) A0 UNION SELECT 'wt.effectivity.WTProductInstance' FROM (SELECT 'wt.effectivity.WTProductInstance' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTProductInstance B0)))) A0 UNION SELECT 'wt.change2.workset.WTWorkSetMaster' FROM (SELECT 'wt.change2.workset.WTWorkSetMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTWorkSetMaster B0)))) A0 UNION SELECT 'wt.part.alternaterep.WTPartAlternateRepMaster' FROM (SELECT 'wt.part.alternaterep.WTPartAlternateRepMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTPartAlternateRepMaster B0)))) A0 UNION SELECT 'wt.query.template.ReportTemplate' FROM (SELECT 'wt.query.template.ReportTemplate' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ReportTemplate B0)))) A0 UNION SELECT 'wt.fc.IdentityChangeHistory' FROM (SELECT 'wt.fc.IdentityChangeHistory' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM IdentityChangeHistory B0)))) A0 UNION SELECT 'wt.epm.build.EPMBuildRule' FROM (SELECT 'wt.epm.build.EPMBuildRule' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMBuildRule B0)))) A0 UNION SELECT 'wt.epm.build.EPMDerivedRepRule' FROM (SELECT 'wt.epm.build.EPMDerivedRepRule' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMDerivedRepRule B0)))) A0 UNION SELECT 'wt.change2.AcceptedStrategy' FROM (SELECT 'wt.change2.AcceptedStrategy' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AcceptedStrategy B0)))) A0 UNION SELECT 'wt.change2.AddressedBy2' FROM (SELECT 'wt.change2.AddressedBy2' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AddressedBy2 B0)))) A0 UNION SELECT 'wt.change2.DetailedBy' FROM (SELECT 'wt.change2.DetailedBy' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DetailedBy B0)))) A0 UNION SELECT 'wt.change2.FormalizedBy' FROM (SELECT 'wt.change2.FormalizedBy' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM FormalizedBy B0)))) A0 UNION SELECT 'wt.change2.IncludedIn2' FROM (SELECT 'wt.change2.IncludedIn2' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM IncludedIn2 B0)))) A0 UNION SELECT 'wt.change2.IssueImplementedBy' FROM (SELECT 'wt.change2.IssueImplementedBy' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM IssueImplementedBy B0)))) A0 UNION SELECT 'wt.change2.ResearchedBy' FROM (SELECT 'wt.change2.ResearchedBy' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ResearchedBy B0)))) A0 UNION SELECT 'wt.access.agreement.AgreementPrincipalLink' FROM (SELECT 'wt.access.agreement.AgreementPrincipalLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AgreementPrincipalLink B0)))) A0 UNION SELECT 'wt.associativity.ConsumptionLink' FROM (SELECT 'wt.associativity.ConsumptionLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ConsumptionLink B0)))) A0 UNION SELECT 'wt.associativity.EquivalenceLink' FROM (SELECT 'wt.associativity.EquivalenceLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EquivalenceLink B0)))) A0 UNION SELECT 'wt.aum.AlternateUnitLink' FROM (SELECT 'wt.aum.AlternateUnitLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AlternateUnitLink B0)))) A0 UNION SELECT 'wt.build.BuildHistory' FROM (SELECT 'wt.build.BuildHistory' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM BuildHistory B0)))) A0 UNION SELECT 'wt.epm.build.EPMDerivedRepHistory' FROM (SELECT 'wt.epm.build.EPMDerivedRepHistory' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMDerivedRepHistory B0)))) A0 UNION SELECT 'wt.calendar.ComponentLink' FROM (SELECT 'wt.calendar.ComponentLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ComponentLink B0)))) A0 UNION SELECT 'wt.change2.ChangesForAnnotations' FROM (SELECT 'wt.change2.ChangesForAnnotations' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ChangesForAnnotations B0)))) A0 UNION SELECT 'wt.change2.ChangesForMarkups' FROM (SELECT 'wt.change2.ChangesForMarkups' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ChangesForMarkups B0)))) A0 UNION SELECT 'wt.change2.CreatedFromVersion' FROM (SELECT 'wt.change2.CreatedFromVersion' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM CreatedFromVersion B0)))) A0 UNION SELECT 'wt.change2.Impacts' FROM (SELECT 'wt.change2.Impacts' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM Impacts B0)))) A0 UNION SELECT 'wt.configurablelink.ConfigurableMastersLink' FROM (SELECT 'wt.configurablelink.ConfigurableMastersLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ConfigurableMastersLink B0)))) A0 UNION SELECT 'wt.content.AggToContentItem' FROM (SELECT 'wt.content.AggToContentItem' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AggToContentItem B0)))) A0 UNION SELECT 'wt.content.HolderToContent' FROM (SELECT 'wt.content.HolderToContent' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM HolderToContent B0)))) A0 UNION SELECT 'wt.content.HttpOperationItem' FROM (SELECT 'wt.content.HttpOperationItem' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM HttpOperationItem B0)))) A0 UNION SELECT 'wt.content.OpLink' FROM (SELECT 'wt.content.OpLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM OpLink B0)))) A0 UNION SELECT 'wt.effectivity.engine.CIEffConfigHolderLink' FROM (SELECT 'wt.effectivity.engine.CIEffConfigHolderLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM CIEffConfigHolderLink B0)))) A0 UNION SELECT 'wt.enterprise.MadeFromLink' FROM (SELECT 'wt.enterprise.MadeFromLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM MadeFromLink B0)))) A0 UNION SELECT 'wt.epm.alternaterep.AlternateRepContainerLink' FROM (SELECT 'wt.epm.alternaterep.AlternateRepContainerLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AlternateRepContainerLink B0)))) A0 UNION SELECT 'wt.epm.modelitems.ModelItemContainedIn' FROM (SELECT 'wt.epm.modelitems.ModelItemContainedIn' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ModelItemContainedIn B0)))) A0 UNION SELECT 'wt.epm.modelitems.ModelItemLink' FROM (SELECT 'wt.epm.modelitems.ModelItemLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ModelItemLink B0)))) A0 UNION SELECT 'wt.epm.structure.EPMContainedIn' FROM (SELECT 'wt.epm.structure.EPMContainedIn' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMContainedIn B0)))) A0 UNION SELECT 'wt.epm.structure.EPMReferenceLink' FROM (SELECT 'wt.epm.structure.EPMReferenceLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMReferenceLink B0)))) A0 UNION SELECT 'wt.epm.structure.EPMVariantLink' FROM (SELECT 'wt.epm.structure.EPMVariantLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMVariantLink B0)))) A0 UNION SELECT 'wt.esi.ERPMaterialLink' FROM (SELECT 'wt.esi.ERPMaterialLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ERPMaterialLink B0)))) A0 UNION SELECT 'wt.esi.ERPPartSpecificPlantDataLink' FROM (SELECT 'wt.esi.ERPPartSpecificPlantDataLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ERPPartSpecificPlantDataLink B0)))) A0 UNION SELECT 'wt.workflow.templates.MasterIteration' FROM (SELECT 'wt.workflow.templates.MasterIteration' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM TaskFormTemplate B0)))) A0 UNION SELECT 'wt.workflow.notebook.WfFolderedBookmarkObjectLink' FROM (SELECT 'wt.workflow.notebook.WfFolderedBookmarkObjectLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WfFolderedBookmark B0)))) A0 UNION SELECT 'wt.workflow.notebook.WfBookmarkObjectLink' FROM (SELECT 'wt.workflow.notebook.WfBookmarkObjectLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WfBookmark B0)))) A0 UNION SELECT 'wt.workflow.notebook.FolderSubFolderLink' FROM (SELECT 'wt.workflow.notebook.FolderSubFolderLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM NotebookFolder B0)))) A0 UNION SELECT 'wt.workflow.notebook.NotebookFolderLink' FROM (SELECT 'wt.workflow.notebook.NotebookFolderLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM NotebookFolder B0)))) A0 UNION SELECT 'wt.workflow.notebook.NotebookBookmarkLink' FROM (SELECT 'wt.workflow.notebook.NotebookBookmarkLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM Bookmark B0)))) A0 UNION SELECT 'wt.workflow.notebook.FolderBookmarkLink' FROM (SELECT 'wt.workflow.notebook.FolderBookmarkLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM Bookmark B0)))) A0 UNION SELECT 'wt.workflow.forum.ForumCookieLink' FROM (SELECT 'wt.workflow.forum.ForumCookieLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ForumCookie B0)))) A0 UNION SELECT 'wt.workflow.forum.ForumTopicLink' FROM (SELECT 'wt.workflow.forum.ForumTopicLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DiscussionTopic B0)))) A0 UNION SELECT 'wt.workflow.forum.TopicSubtopicLink' FROM (SELECT 'wt.workflow.forum.TopicSubtopicLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DiscussionTopic B0)))) A0 UNION SELECT 'wt.workflow.forum.PostingSubpostingLink' FROM (SELECT 'wt.workflow.forum.PostingSubpostingLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DiscussionPosting B0)))) A0 UNION SELECT 'wt.workflow.forum.TopicPostingLink' FROM (SELECT 'wt.workflow.forum.TopicPostingLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DiscussionPosting B0)))) A0 UNION SELECT 'wt.workflow.forum.ForumDefInstanceLink' FROM (SELECT 'wt.workflow.forum.ForumDefInstanceLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DiscussionForum B0)))) A0 UNION SELECT 'wt.workflow.engine.TheWorkItemTheWfVotingEventAudit' FROM (SELECT 'wt.workflow.engine.TheWorkItemTheWfVotingEventAudit' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WfVotingEventAudit B0)))) A0 UNION SELECT 'wt.workflow.definer.ProxyProcessDefinitionLink' FROM (SELECT 'wt.workflow.definer.ProxyProcessDefinitionLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WfProxyTemplate B0)))) A0 UNION SELECT 'wt.workflow.definer.MasterIteration' FROM (SELECT 'wt.workflow.definer.MasterIteration' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WfProcessTemplate B0)))) A0 UNION SELECT 'wt.viewmarkup.ThePublishingProhibitionTarget' FROM (SELECT 'wt.viewmarkup.ThePublishingProhibitionTarget' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PublishingProhibition B0)))) A0 UNION SELECT 'wt.viewmarkup.AssignedToLcmMarkUp' FROM (SELECT 'wt.viewmarkup.AssignedToLcmMarkUp' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM LifeCycleManagedWtMarkUp B0)))) A0 UNION SELECT 'wt.viewmarkup.DerivedFromTheDerivedImage' FROM (SELECT 'wt.viewmarkup.DerivedFromTheDerivedImage' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DerivedImage B0)))) A0 UNION SELECT 'wt.vc.baseline.BaselineTopObjLink' FROM (SELECT 'wt.vc.baseline.BaselineTopObjLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ManagedBaseline B0)))) A0 UNION SELECT 'wt.vc.TheControlBranchPredecessor' FROM (SELECT 'wt.vc.TheControlBranchPredecessor' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ControlBranch B0)))) A0 UNION SELECT 'wt.ufid.LocalObjectRemoteInfo' FROM (SELECT 'wt.ufid.LocalObjectRemoteInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RemoteObjectInfo B0)))) A0 UNION SELECT 'wt.team.TeamTemplateLink' FROM (SELECT 'wt.team.TeamTemplateLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM Team B0)))) A0 UNION SELECT 'wt.team.RoleRoleLink' FROM (SELECT 'wt.team.RoleRoleLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RoleRoleMap B0)))) A0 UNION SELECT 'wt.team.RolePrincipalLink' FROM (SELECT 'wt.team.RolePrincipalLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RolePrincipalMap B0)))) A0 UNION SELECT 'wt.team.RolePoolLink' FROM (SELECT 'wt.team.RolePoolLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RolePoolMap B0)))) A0 UNION SELECT 'wt.team.RoleActorRoleLink' FROM (SELECT 'wt.team.RoleActorRoleLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RoleActorRoleMap B0)))) A0 UNION SELECT 'wt.scheduler.ScheduleItemHistory' FROM (SELECT 'wt.scheduler.ScheduleItemHistory' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ScheduleHistory B0)))) A0 UNION SELECT 'wt.query.SavedQueryHistory' FROM (SELECT 'wt.query.SavedQueryHistory' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM SearchHistory B0)))) A0 UNION SELECT 'wt.projmgmt.resource.ProjectDeliverableLink' FROM (SELECT 'wt.projmgmt.resource.ProjectDeliverableLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM Deliverable B0)))) A0 UNION SELECT 'wt.projmgmt.execution.ProjectWorkItemLink' FROM (SELECT 'wt.projmgmt.execution.ProjectWorkItemLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProjectWorkItem B0)))) A0 UNION SELECT 'wt.projmgmt.execution.ProjectPlanLink' FROM (SELECT 'wt.projmgmt.execution.ProjectPlanLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProjectPlan B0)))) A0 UNION SELECT 'wt.projmgmt.execution.ProjectAssignmentLink' FROM (SELECT 'wt.projmgmt.execution.ProjectAssignmentLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProjectAssignment B0)))) A0 UNION SELECT 'wt.preference.PreferenceClientInstance' FROM (SELECT 'wt.preference.PreferenceClientInstance' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PreferenceInstance B0)))) A0 UNION SELECT 'wt.preference.TheWTContainerThePreferenceInstance' FROM (SELECT 'wt.preference.TheWTContainerThePreferenceInstance' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PreferenceInstance B0)))) A0 UNION SELECT 'wt.preference.TheWTUserThePreferenceInstance' FROM (SELECT 'wt.preference.TheWTUserThePreferenceInstance' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PreferenceInstance B0)))) A0 UNION SELECT 'wt.preference.ThePreferenceDefinitionThePreferenceInstance' FROM (SELECT 'wt.preference.ThePreferenceDefinitionThePreferenceInstance' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PreferenceInstance B0)))) A0 UNION SELECT 'wt.preference.ParentPreferenceClientChildPreferenceClient' FROM (SELECT 'wt.preference.ParentPreferenceClientChildPreferenceClient' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PreferenceClient B0)))) A0 UNION SELECT 'wt.preference.ParentPreferenceCategoryChildPreferenceCategory' FROM (SELECT 'wt.preference.ParentPreferenceCategoryChildPreferenceCategory' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PreferenceCategory B0)))) A0 UNION SELECT 'wt.preference.ThePreferenceInstanceTheMultiValuedPreferenceInstance' FROM (SELECT 'wt.preference.ThePreferenceInstanceTheMultiValuedPreferenceInstance' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM MultiValuedPreferenceInstance B0)))) A0 UNION SELECT 'wt.pdmlink.ThePDMLinkProductProduct' FROM (SELECT 'wt.pdmlink.ThePDMLinkProductProduct' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PDMLinkProduct B0)))) A0 UNION SELECT 'wt.part.build.ChildPartMasterDeletedBuildReference' FROM (SELECT 'wt.part.build.ChildPartMasterDeletedBuildReference' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DeletedBuildReference B0)))) A0 UNION SELECT 'wt.part.build.ParentAssemblyDeletedBuildReference' FROM (SELECT 'wt.part.build.ParentAssemblyDeletedBuildReference' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DeletedBuildReference B0)))) A0 UNION SELECT 'wt.part.ProductProductInstance' FROM (SELECT 'wt.part.ProductProductInstance' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTProductInstanceMaster B0)))) A0 UNION SELECT 'wt.part.ProductInstanceMasterProductInstance' FROM (SELECT 'wt.part.ProductInstanceMasterProductInstance' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTProductInstance2 B0)))) A0 UNION SELECT 'wt.part.ProductConfigForConfig' FROM (SELECT 'wt.part.ProductConfigForConfig' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTProductConfigMaster B0)))) A0 UNION SELECT 'wt.part.ConfigurationMasterConfiguration' FROM (SELECT 'wt.part.ConfigurationMasterConfiguration' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTProductConfiguration B0)))) A0 UNION SELECT 'wt.part.MasterIteration' FROM (SELECT 'wt.part.MasterIteration' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTPart B0)))) A0 UNION SELECT 'wt.part.ThePublishedLineNumberPart' FROM (SELECT 'wt.part.ThePublishedLineNumberPart' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PublishedLineNumber B0)))) A0 UNION SELECT 'wt.part.PPSerialNumberEffectivity' FROM (SELECT 'wt.part.PPSerialNumberEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProductSNEffectivity B0)))) A0 UNION SELECT 'wt.part.PPMSNEffectivity' FROM (SELECT 'wt.part.PPMSNEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProductMSNEffectivity B0)))) A0 UNION SELECT 'wt.part.PPLotNumberEffectivity' FROM (SELECT 'wt.part.PPLotNumberEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProductLNEffectivity B0)))) A0 UNION SELECT 'wt.part.PPDateEffectivity' FROM (SELECT 'wt.part.PPDateEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProductDateEffectivity B0)))) A0 UNION SELECT 'wt.part.PPBlockEffectivitiy' FROM (SELECT 'wt.part.PPBlockEffectivitiy' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProductBlockEffectivity B0)))) A0 UNION SELECT 'wt.part.TheInstanceReplacementRecordReplacement' FROM (SELECT 'wt.part.TheInstanceReplacementRecordReplacement' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM InstanceReplacementRecord B0)))) A0 UNION SELECT 'wt.notify.NotifySubscriptionTargetLink' FROM (SELECT 'wt.notify.NotifySubscriptionTargetLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM NotifySubscriptionTarget B0)))) A0 UNION SELECT 'wt.notify.NotifySubscriptnRecipntLink' FROM (SELECT 'wt.notify.NotifySubscriptnRecipntLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM NotifySubscriptionRecipient B0)))) A0 UNION SELECT 'wt.meeting.actionitem.ActionItemSourceLink' FROM (SELECT 'wt.meeting.actionitem.ActionItemSourceLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DiscreteActionItem B0)))) A0 UNION SELECT 'wt.maturity.ThePromotionNoticeCollectedBaseline' FROM (SELECT 'wt.maturity.ThePromotionNoticeCollectedBaseline' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PromotionNotice B0)))) A0 UNION SELECT 'wt.maturity.ThePromotionNoticeConfiguration' FROM (SELECT 'wt.maturity.ThePromotionNoticeConfiguration' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PromotionNotice B0)))) A0 UNION SELECT 'wt.lifecycle.PhaseWorkflow' FROM (SELECT 'wt.lifecycle.PhaseWorkflow' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PhaseTemplate B0)))) A0 UNION SELECT 'wt.lifecycle.GateWorkflow' FROM (SELECT 'wt.lifecycle.GateWorkflow' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PhaseTemplate B0)))) A0 UNION SELECT 'wt.lifecycle.MasterIteration' FROM (SELECT 'wt.lifecycle.MasterIteration' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM LifeCycleTemplate B0)))) A0 UNION SELECT 'wt.intersvrcom.SiteRepository' FROM (SELECT 'wt.intersvrcom.SiteRepository' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AbstractSite B0)))) A0 UNION SELECT 'wt.intersvrcom.SitePrincipal' FROM (SELECT 'wt.intersvrcom.SitePrincipal' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AbstractSite B0)))) A0 UNION SELECT 'wt.intersvrcom.SiteSecurityLink' FROM (SELECT 'wt.intersvrcom.SiteSecurityLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AbstractSite B0)))) A0 UNION SELECT 'wt.inf.template.MasterIteration' FROM (SELECT 'wt.inf.template.MasterIteration' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DefaultWTContainerTemplate B0)))) A0 UNION SELECT 'wt.inf.container.ContainerFilter' FROM (SELECT 'wt.inf.container.ContainerFilter' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTContainerFilter B0)))) A0 UNION SELECT 'wt.inf.container.PrivateDomainLink' FROM (SELECT 'wt.inf.container.PrivateDomainLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM OrgContainer B0)))) A0 UNION SELECT 'wt.inf.container.ClassicLink' FROM (SELECT 'wt.inf.container.ClassicLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ExchangeContainer B0)))) A0 UNION SELECT 'wt.iba.definition.UnitQOMLink' FROM (SELECT 'wt.iba.definition.UnitQOMLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM UnitDefinition B0)))) A0 UNION SELECT 'wt.fv.VaultRootFolderLink' FROM (SELECT 'wt.fv.VaultRootFolderLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RootFolder B0)))) A0 UNION SELECT 'wt.fv.RecordedObjectLink' FROM (SELECT 'wt.fv.RecordedObjectLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RecordedObjectHistory B0)))) A0 UNION SELECT 'wt.fv.ChangeHistoryLink' FROM (SELECT 'wt.fv.ChangeHistoryLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RecordedHistory B0)))) A0 UNION SELECT 'wt.fv.RecordHistotyTheRecordedHistory' FROM (SELECT 'wt.fv.RecordHistotyTheRecordedHistory' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RecordedHistory B0)))) A0 UNION SELECT 'wt.fv.VaultPolicyRuleLink' FROM (SELECT 'wt.fv.VaultPolicyRuleLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM FvPolicyRule B0)))) A0 UNION SELECT 'wt.fv.VaultPolicyItemLink' FROM (SELECT 'wt.fv.VaultPolicyItemLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM FvPolicyItem B0)))) A0 UNION SELECT 'wt.fv.SiteHostLink' FROM (SELECT 'wt.fv.SiteHostLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM FvHost B0)))) A0 UNION SELECT 'wt.folder.history.OldFolderTheLocationChangeRecord' FROM (SELECT 'wt.folder.history.OldFolderTheLocationChangeRecord' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM LocationChangeRecord B0)))) A0 UNION SELECT 'wt.folder.history.ObjectTheLocationChangeRecord' FROM (SELECT 'wt.folder.history.ObjectTheLocationChangeRecord' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM LocationChangeRecord B0)))) A0 UNION SELECT 'wt.filter.FilterTemplateTheNavigationFilter' FROM (SELECT 'wt.filter.FilterTemplateTheNavigationFilter' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM NavigationFilter B0)))) A0 UNION SELECT 'wt.filter.TheNavigationCriteriaOwner' FROM (SELECT 'wt.filter.TheNavigationCriteriaOwner' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM NavigationCriteria B0)))) A0 UNION SELECT 'wt.filter.FilterTemplateTheNavFilterConstraint' FROM (SELECT 'wt.filter.FilterTemplateTheNavFilterConstraint' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM NavFilterConstraint B0)))) A0 UNION SELECT 'wt.filter.FilterTemplateTheDesignationGroup' FROM (SELECT 'wt.filter.FilterTemplateTheDesignationGroup' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DesignationGroup B0)))) A0 UNION SELECT 'wt.federation.MasterIteration' FROM (SELECT 'wt.federation.MasterIteration' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProxyDocument B0)))) A0 UNION SELECT 'wt.fc.TheSemanticKeyTheUniquelyIdentified' FROM (SELECT 'wt.fc.TheSemanticKeyTheUniquelyIdentified' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM SemanticKey B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspaceMember' FROM (SELECT 'wt.epm.workspaces.WorkspaceMember' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WorkspaceMemberStatus B0)))) A0 UNION SELECT 'wt.epm.workspaces.TheEPMWorkspaceNamespaceNamespace' FROM (SELECT 'wt.epm.workspaces.TheEPMWorkspaceNamespaceNamespace' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspaceNamespace B0)))) A0 UNION SELECT 'wt.epm.workspaces.WsNamespaceEntryMaster' FROM (SELECT 'wt.epm.workspaces.WsNamespaceEntryMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspaceNamespace B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspaceCheckpoint' FROM (SELECT 'wt.epm.workspaces.WorkspaceCheckpoint' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspace B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspaceContainer' FROM (SELECT 'wt.epm.workspaces.WorkspaceContainer' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspace B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspaceView' FROM (SELECT 'wt.epm.workspaces.WorkspaceView' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspace B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspaceTeamTemplate' FROM (SELECT 'wt.epm.workspaces.WorkspaceTeamTemplate' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspace B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspacePartFolder' FROM (SELECT 'wt.epm.workspaces.WorkspacePartFolder' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspace B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspaceDocFolder' FROM (SELECT 'wt.epm.workspaces.WorkspaceDocFolder' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspace B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspacePartLifeCycle' FROM (SELECT 'wt.epm.workspaces.WorkspacePartLifeCycle' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspace B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspaceDocLifeCycle' FROM (SELECT 'wt.epm.workspaces.WorkspaceDocLifeCycle' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspace B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspaceDocConfigSpec' FROM (SELECT 'wt.epm.workspaces.WorkspaceDocConfigSpec' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspace B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspacePartConfigSpec' FROM (SELECT 'wt.epm.workspaces.WorkspacePartConfigSpec' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspace B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspaceFolder' FROM (SELECT 'wt.epm.workspaces.WorkspaceFolder' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspace B0)))) A0 UNION SELECT 'wt.epm.workspaces.Checkpoint' FROM (SELECT 'wt.epm.workspaces.Checkpoint' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspace B0)))) A0 UNION SELECT 'wt.epm.workspaces.UpdateCounterTrackable' FROM (SELECT 'wt.epm.workspaces.UpdateCounterTrackable' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMUpdateCounter B0)))) A0 UNION SELECT 'wt.epm.workspaces.TargetFolderLink' FROM (SELECT 'wt.epm.workspaces.TargetFolderLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMInitialCheckinData B0)))) A0 UNION SELECT 'wt.epm.workspaces.NewObjectDataLink' FROM (SELECT 'wt.epm.workspaces.NewObjectDataLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMInitialCheckinData B0)))) A0 UNION SELECT 'wt.epm.workspaces.MasterIteration' FROM (SELECT 'wt.epm.workspaces.MasterIteration' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMCheckpoint B0)))) A0 UNION SELECT 'wt.epm.workspaces.DocumentToCacheState' FROM (SELECT 'wt.epm.workspaces.DocumentToCacheState' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ClientCacheState B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspaceToCacheState' FROM (SELECT 'wt.epm.workspaces.WorkspaceToCacheState' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ClientCacheState B0)))) A0 UNION SELECT 'wt.epm.supportingdata.AppDataVersionLink' FROM (SELECT 'wt.epm.supportingdata.AppDataVersionLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMSupportingData B0)))) A0 UNION SELECT 'wt.epm.supportingdata.HolderSupportingData' FROM (SELECT 'wt.epm.supportingdata.HolderSupportingData' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMSupportingData B0)))) A0 UNION SELECT 'wt.epm.modelitems.MasterIteration' FROM (SELECT 'wt.epm.modelitems.MasterIteration' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ModelItem B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMSepFamilyTableMasterFamilyTableLink' FROM (SELECT 'wt.epm.familytable.EPMSepFamilyTableMasterFamilyTableLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMSepFamilyTable B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMParameterValueContainerLink' FROM (SELECT 'wt.epm.familytable.EPMParameterValueContainerLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMParameterValue B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMParameterDefinitionContainerLink' FROM (SELECT 'wt.epm.familytable.EPMParameterDefinitionContainerLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMParameterDefinition B0)))) A0; Bind Parameters=[]". Database system message follows:
Fri 3/16/12 16:17:23: main: Nested exception is: java.sql.SQLException: ORA-04030: out of process memory when trying to allocate 1012 bytes (kxs-heap-c,kghsstk)
Fri 3/16/12 16:17:23: main:at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:439)
Fri 3/16/12 16:17:23: main:at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:395)
Fri 3/16/12 16:17:23: main:at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:802)
Fri 3/16/12 16:17:23: main:at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:436)
Fri 3/16/12 16:17:23: main:at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:186)
Fri 3/16/12 16:17:23: main:at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:521)
Fri 3/16/12 16:17:23: main:at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:205)
Fri 3/16/12 16:17:23: main:at oracle.jdbc.driver.T4CPreparedStatement.executeForDescribe(T4CPreparedStatement.java:861)
Fri 3/16/12 16:17:23: main:at oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(OracleStatement.java:1145)
Fri 3/16/12 16:17:23: main:at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1267)
Fri 3/16/12 16:17:23: main:at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3449)
Fri 3/16/12 16:17:23: main:at oracle.jdbc.driver.OraclePreparedStatement.executeQuery(OraclePreparedStatement.java:3493)
Fri 3/16/12 16:17:23: main:at oracle.jdbc.driver.OraclePreparedStatementWrapper.executeQuery(OraclePreparedStatementWrapper.java:1491)
Fri 3/16/12 16:17:23: main:at wt.pds.AbstractResultCursor.executeQuery(AbstractResultCursor.java:520)
Fri 3/16/12 16:17:23: main:at wt.pds.BasicResultCursor.getNextResultSet(BasicResultCursor.java:237)
Fri 3/16/12 16:17:23: main:at wt.pds.BasicResultCursor.advance(BasicResultCursor.java:192)
Fri 3/16/12 16:17:23: main:at wt.pds.BasicResultCursor.next(BasicResultCursor.java:80)
Fri 3/16/12 16:17:23: main:at wt.pds.SQLDatabasePds.query(SQLDatabasePds.java:719)
Fri 3/16/12 16:17:23: main:at wt.pom.PersistentObjectManager.query(PersistentObjectManager.java:1156)
Fri 3/16/12 16:17:23: main:at wt.pom.PersistentObjectManager.query(PersistentObjectManager.java:1059)
Fri 3/16/12 16:17:23: main:at wt.pom.EmptyTableManager.queryTables(EmptyTableManager.java:538)
Fri 3/16/12 16:17:23: main:at wt.pom.EmptyTableManager.queryTables(EmptyTableManager.java:481)
Fri 3/16/12 16:17:23: main:at wt.pom.EmptyTableManager.findEmptyTables(EmptyTableManager.java:557)
Fri 3/16/12 16:17:23: main:at wt.pom.EmptyTableManager.populateCache(EmptyTableManager.java:131)
Fri 3/16/12 16:17:23: main:at wt.pom.EmptyTableManager.access$100(EmptyTableManager.java:83)
Fri 3/16/12 16:17:23: main:at wt.pom.EmptyTableManager$AllManagersStartedEventListener.notifyVetoableEvent(EmptyTableManager.java:658)
Fri 3/16/12 16:17:23: main:at wt.events.StandardKeyedEventBranch.intDispatchEvent(StandardKeyedEventBranch.java:320)
Fri 3/16/12 16:17:23: main:at wt.events.StandardKeyedEventBranch.dispatchVetoableEvent(StandardKeyedEventBranch.java:229)
Fri 3/16/12 16:17:23: main:at wt.events.StandardKeyedEventDispatcher.intDispatchEvent(StandardKeyedEventDispatcher.java:286)
Fri 3/16/12 16:17:23: main:at wt.events.StandardKeyedEventDispatcher.dispatchVetoableEvent(StandardKeyedEventDispatcher.java:215)
Fri 3/16/12 16:17:23: main:at wt.services.StandardManagerService.intDispatchVetoableEvent(StandardManagerService.java:406)
Fri 3/16/12 16:17:23: main:at wt.services.StandardManagerService.dispatchVetoableEvent(StandardManagerService.java:302)
Fri 3/16/12 16:17:23: main:at wt.services.StandardManagerService.performStartupProcess(StandardManagerService.java:184)
Fri 3/16/12 16:17:23: main:at wt.services.StandardManager.startup(StandardManager.java:459)
Fri 3/16/12 16:17:23: main:at wt.services.StandardServicesHandler.start(StandardServicesHandler.java:44)
Fri 3/16/12 16:17:23: main:at wt.method.MethodServerMain.run(MethodServerMain.java:420)
Fri 3/16/12 16:17:23: main:at wt.method.MethodServerMain.main(MethodServerMain.java:271)
Fri 3/16/12 16:17:23: main: FATAL : wt.method.server.shutdown - Stopping services...
Fri 3/16/12 16:17:24: main: INFO : wt.method.server.shutdown.services - All managers shut down.
Fri 3/16/12 16:17:24: main: FATAL : wt.method.server.shutdown - MethodServer stopped
Fri 3/16/12 16:17:23: main:java.sql.SQLException: ORA-04030: out of process memory when trying to allocate 1012 bytes (kxs-heap-c,kghsstk)
Fri 3/16/12 16:17:23: main: Nested exception is: (wt.pom.pomResource/0) wt.pom.PersistenceException: A persistence error occurred. System message follows:
Fri 3/16/12 16:17:23: main: Nested exception is: wt.pom.DatastoreException: A SQL error has occurred for the statement "SELECT 'com.ptc.core.meta.type.mgmt.server.impl.association.DefaultAssociationConstraintItem' FROM (SELECT 'com.ptc.core.meta.type.mgmt.server.impl.association.DefaultAssociationConstraintItem' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DefaultAssociationConstraintIt B0)))) A0 UNION SELECT 'wt.access.AccessPolicyRule' FROM (SELECT 'wt.access.AccessPolicyRule' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AccessPolicyRule B0)))) A0 UNION SELECT 'wt.access.AccessControlSurrogate' FROM (SELECT 'wt.access.AccessControlSurrogate' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AccessControlSurrogate B0)))) A0 UNION SELECT 'wt.admin.AdministrativeDomain' FROM (SELECT 'wt.admin.AdministrativeDomain' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AdministrativeDomain B0)))) A0 UNION SELECT 'com.ptc.core.managedcollection.ManagedCollectionImpl' FROM (SELECT 'com.ptc.core.managedcollection.ManagedCollectionImpl' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ManagedCollection B0)))) A0 UNION SELECT 'wt.folder.Cabinet' FROM (SELECT 'wt.folder.Cabinet' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM Cabinet B0)))) A0 UNION SELECT 'wt.folder.SubFolder' FROM (SELECT 'wt.folder.SubFolder' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM SubFolder B0)))) A0 UNION SELECT 'wt.inf.container.ExchangeContainer' FROM (SELECT 'wt.inf.container.ExchangeContainer' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ExchangeContainer B0)))) A0 UNION SELECT 'wt.inf.container.OrgContainer' FROM (SELECT 'wt.inf.container.OrgContainer' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM OrgContainer B0)))) A0 UNION SELECT 'wt.inf.library.WTLibrary' FROM (SELECT 'wt.inf.library.WTLibrary' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTLibrary B0)))) A0 UNION SELECT 'wt.pdmlink.PDMLinkProduct' FROM (SELECT 'wt.pdmlink.PDMLinkProduct' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PDMLinkProduct B0)))) A0 UNION SELECT 'wt.projmgmt.admin.Project2' FROM (SELECT 'wt.projmgmt.admin.Project2' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM Project2 B0)))) A0 UNION SELECT 'wt.inf.sharing.SharedContainerMap' FROM (SELECT 'wt.inf.sharing.SharedContainerMap' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM SharedContainerMap B0)))) A0 UNION SELECT 'wt.inf.team.ContainerTeam' FROM (SELECT 'wt.inf.team.ContainerTeam' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ContainerTeam B0)))) A0 UNION SELECT 'wt.annotation.AnnotationSet' FROM (SELECT 'wt.annotation.AnnotationSet' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AnnotationSet B0)))) A0 UNION SELECT 'wt.annotation.StructuredAnnotationSet' FROM (SELECT 'wt.annotation.StructuredAnnotationSet' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM StructuredAnnotationSet B0)))) A0 UNION SELECT 'wt.change2.WTChangeDirective' FROM (SELECT 'wt.change2.WTChangeDirective' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTChangeDirective B0)))) A0 UNION SELECT 'wt.effectivity.ConfigurationItem' FROM (SELECT 'wt.effectivity.ConfigurationItem' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ConfigurationItem B0)))) A0 UNION SELECT 'wt.maturity.PromotionNotice' FROM (SELECT 'wt.maturity.PromotionNotice' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PromotionNotice B0)))) A0 UNION SELECT 'wt.vc.baseline.ManagedBaseline' FROM (SELECT 'wt.vc.baseline.ManagedBaseline' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ManagedBaseline B0)))) A0 UNION SELECT 'wt.change2.WTAnalysisActivity' FROM (SELECT 'wt.change2.WTAnalysisActivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTAnalysisActivity B0)))) A0 UNION SELECT 'wt.change2.WTChangeActivity2' FROM (SELECT 'wt.change2.WTChangeActivity2' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTChangeActivity2 B0)))) A0 UNION SELECT 'wt.change2.WTChangeInvestigation' FROM (SELECT 'wt.change2.WTChangeInvestigation' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTChangeInvestigation B0)))) A0 UNION SELECT 'wt.change2.WTChangeProposal' FROM (SELECT 'wt.change2.WTChangeProposal' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTChangeProposal B0)))) A0 UNION SELECT 'wt.change2.WTChangeIssue' FROM (SELECT 'wt.change2.WTChangeIssue' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTChangeIssue B0)))) A0 UNION SELECT 'wt.change2.WTVariance' FROM (SELECT 'wt.change2.WTVariance' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTVariance B0)))) A0 UNION SELECT 'wt.change2.WTChangeOrder2' FROM (SELECT 'wt.change2.WTChangeOrder2' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTChangeOrder2 B0)))) A0 UNION SELECT 'wt.change2.WTChangeRequest2' FROM (SELECT 'wt.change2.WTChangeRequest2' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTChangeRequest2 B0)))) A0 UNION SELECT 'wt.access.agreement.AuthorizationAgreement' FROM (SELECT 'wt.access.agreement.AuthorizationAgreement' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AuthorizationAgreement B0)))) A0 UNION SELECT 'wt.doc.WTDocument' FROM (SELECT 'wt.doc.WTDocument' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTDocument B0)))) A0 UNION SELECT 'wt.federation.ProxyDocument' FROM (SELECT 'wt.federation.ProxyDocument' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProxyDocument B0)))) A0 UNION SELECT 'wt.epm.EPMDocument' FROM (SELECT 'wt.epm.EPMDocument' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMDocument B0)))) A0 UNION SELECT 'wt.part.WTPart' FROM (SELECT 'wt.part.WTPart' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTPart B0)))) A0 UNION SELECT 'com.ptc.windchill.option.model.Choice' FROM (SELECT 'com.ptc.windchill.option.model.Choice' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ATOChoice B0)))) A0 UNION SELECT 'com.ptc.windchill.option.model.OptionSet' FROM (SELECT 'com.ptc.windchill.option.model.OptionSet' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM OptionSet B0)))) A0 UNION SELECT 'wt.part.alternaterep.WTPartAlternateRep' FROM (SELECT 'wt.part.alternaterep.WTPartAlternateRep' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTPartAlternateRep B0)))) A0 UNION SELECT 'wt.replication.unit.WTUnit' FROM (SELECT 'wt.replication.unit.WTUnit' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTUnit B0)))) A0 UNION SELECT 'com.ptc.wpcfg.doc.VariantSpec' FROM (SELECT 'com.ptc.wpcfg.doc.VariantSpec' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM VariantSpec B0)))) A0 UNION SELECT 'wt.part.WTProductConfiguration' FROM (SELECT 'wt.part.WTProductConfiguration' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTProductConfiguration B0)))) A0 UNION SELECT 'wt.part.WTProductInstance2' FROM (SELECT 'wt.part.WTProductInstance2' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTProductInstance2 B0)))) A0 UNION SELECT 'wt.change2.workset.WTWorkSet' FROM (SELECT 'wt.change2.workset.WTWorkSet' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTWorkSet B0)))) A0 UNION SELECT 'com.ptc.windchill.wp.WorkPackage' FROM (SELECT 'com.ptc.windchill.wp.WorkPackage' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WorkPackage B0)))) A0 UNION SELECT 'com.ptc.windchill.wp.tdp.TechnicalDataPackage' FROM (SELECT 'com.ptc.windchill.wp.tdp.TechnicalDataPackage' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM TechnicalDataPackage B0)))) A0 UNION SELECT 'wt.meeting.actionitem.DiscreteActionItem' FROM (SELECT 'wt.meeting.actionitem.DiscreteActionItem' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DiscreteActionItem B0)))) A0 UNION SELECT 'wt.viewmarkup.LifeCycleManagedWtMarkUp' FROM (SELECT 'wt.viewmarkup.LifeCycleManagedWtMarkUp' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM LifeCycleManagedWtMarkUp B0)))) A0 UNION SELECT 'wt.replication.sender.UnitSendRecord' FROM (SELECT 'wt.replication.sender.UnitSendRecord' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM UnitSendRecord B0)))) A0 UNION SELECT 'com.ptc.wpcfg.family.EngineState' FROM (SELECT 'com.ptc.wpcfg.family.EngineState' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EngineState B0)))) A0 UNION SELECT 'wt.meeting.MeetingCenterMeeting' FROM (SELECT 'wt.meeting.MeetingCenterMeeting' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM MeetingCenterMeeting B0)))) A0 UNION SELECT 'wt.meeting.TraditionalMeeting' FROM (SELECT 'wt.meeting.TraditionalMeeting' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM TraditionalMeeting B0)))) A0 UNION SELECT 'wt.notify.NotificationSubscription' FROM (SELECT 'wt.notify.NotificationSubscription' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM NotificationSubscription B0)))) A0 UNION SELECT 'wt.notify.ObjectSubscription' FROM (SELECT 'wt.notify.ObjectSubscription' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ObjectSubscription B0)))) A0 UNION SELECT 'wt.org.WTGroup' FROM (SELECT 'wt.org.WTGroup' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTGroup B0)))) A0 UNION SELECT 'wt.federation.ProxyGroup' FROM (SELECT 'wt.federation.ProxyGroup' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProxyGroup B0)))) A0 UNION SELECT 'wt.org.WTOrganization' FROM (SELECT 'wt.org.WTOrganization' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTOrganization B0)))) A0 UNION SELECT 'wt.org.WTUser' FROM (SELECT 'wt.org.WTUser' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTUser B0)))) A0 UNION SELECT 'wt.federation.ProxyUser' FROM (SELECT 'wt.federation.ProxyUser' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProxyUser B0)))) A0 UNION SELECT 'wt.project.Project' FROM (SELECT 'wt.project.Project' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM Project B0)))) A0 UNION SELECT 'wt.team.Team' FROM (SELECT 'wt.team.Team' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM Team B0)))) A0 UNION SELECT 'wt.team.TeamDistributionList' FROM (SELECT 'wt.team.TeamDistributionList' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM TeamDistributionList B0)))) A0 UNION SELECT 'wt.team.TeamTemplate' FROM (SELECT 'wt.team.TeamTemplate' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM TeamTemplate B0)))) A0 UNION SELECT 'wt.viewmarkup.DerivedImage' FROM (SELECT 'wt.viewmarkup.DerivedImage' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DerivedImage B0)))) A0 UNION SELECT 'wt.viewmarkup.WTMarkUp' FROM (SELECT 'wt.viewmarkup.WTMarkUp' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTMarkUp B0)))) A0 UNION SELECT 'com.ptc.windchill.wp.delivery.DeliveryRecord' FROM (SELECT 'com.ptc.windchill.wp.delivery.DeliveryRecord' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DeliveryRecord B0)))) A0 UNION SELECT 'com.ptc.core.percol.PersistedCollection' FROM (SELECT 'com.ptc.core.percol.PersistedCollection' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PersistedCollection B0)))) A0 UNION SELECT 'wt.access.WTAclEntry' FROM (SELECT 'wt.access.WTAclEntry' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTAclEntry B0)))) A0 UNION SELECT 'wt.access.agreement.AgreementAuthorizedObject' FROM (SELECT 'wt.access.agreement.AgreementAuthorizedObject' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AgreementAuthorizedObject B0)))) A0 UNION SELECT 'wt.access.agreement.AgreementAuthorizedProxy' FROM (SELECT 'wt.access.agreement.AgreementAuthorizedProxy' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AgreementAuthorizedProxy B0)))) A0 UNION SELECT 'wt.epm.alternaterep.EPMDefinitionRule' FROM (SELECT 'wt.epm.alternaterep.EPMDefinitionRule' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMDefinitionRule B0)))) A0 UNION SELECT 'wt.part.alternaterep.SimpleStructFilterRule' FROM (SELECT 'wt.part.alternaterep.SimpleStructFilterRule' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM SimpleStructFilterRule B0)))) A0 UNION SELECT 'wt.structfilter.rule.attribute.AttributeStructFilterRule' FROM (SELECT 'wt.structfilter.rule.attribute.AttributeStructFilterRule' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AttributeStructFilterRule B0)))) A0 UNION SELECT 'wt.spatial.SpatialStructFilterRule' FROM (SELECT 'wt.spatial.SpatialStructFilterRule' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM SpatialStructFilterRule B0)))) A0 UNION SELECT 'wt.part.WTPartMaster' FROM (SELECT 'wt.part.WTPartMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTPartMaster B0)))) A0 UNION SELECT 'wt.federation.ProxyPartMaster' FROM (SELECT 'wt.federation.ProxyPartMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProxyPartMaster B0)))) A0 UNION SELECT 'wt.audit.eventinfo.AssociateDisassociateEventInfo' FROM (SELECT 'wt.audit.eventinfo.AssociateDisassociateEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AssociateDisassociateEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.CSRFEventInfo' FROM (SELECT 'wt.audit.eventinfo.CSRFEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM CSRFEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.ChangeIdentityEventInfo' FROM (SELECT 'wt.audit.eventinfo.ChangeIdentityEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ChangeIdentityEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.ChangeLifecycleStateEventInfo' FROM (SELECT 'wt.audit.eventinfo.ChangeLifecycleStateEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ChangeLifecycleStateEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.CheckInEventInfo' FROM (SELECT 'wt.audit.eventinfo.CheckInEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM CheckInEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.CheckoutEventInfo' FROM (SELECT 'wt.audit.eventinfo.CheckoutEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM CheckoutEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.CopyEventInfo' FROM (SELECT 'wt.audit.eventinfo.CopyEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM CopyEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.DownloadEventInfo' FROM (SELECT 'wt.audit.eventinfo.DownloadEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DownloadEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.MarkupAnnotateEventInfo' FROM (SELECT 'wt.audit.eventinfo.MarkupAnnotateEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM MarkupAnnotateEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.ModifyAccessPolicyEventInfo' FROM (SELECT 'wt.audit.eventinfo.ModifyAccessPolicyEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ModifyAccessPolicyEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.ModifyContentEventInfo' FROM (SELECT 'wt.audit.eventinfo.ModifyContentEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ModifyContentEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.ModifyGroupEventInfo' FROM (SELECT 'wt.audit.eventinfo.ModifyGroupEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ModifyGroupEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.ModifyObjectAccessEventInfo' FROM (SELECT 'wt.audit.eventinfo.ModifyObjectAccessEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ModifyObjectAccessEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.ModifyOrgRoleEventInfo' FROM (SELECT 'wt.audit.eventinfo.ModifyOrgRoleEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ModifyOrgRoleEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.ModifyProdStructureEventInfo' FROM (SELECT 'wt.audit.eventinfo.ModifyProdStructureEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ModifyProdStructureEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.ModifySecurityLabelsEventInfo' FROM (SELECT 'wt.audit.eventinfo.ModifySecurityLabelsEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ModifySecurityLabelsEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.ModifyTeamEventInfo' FROM (SELECT 'wt.audit.eventinfo.ModifyTeamEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ModifyTeamEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.ModifyTeamRoleEventInfo' FROM (SELECT 'wt.audit.eventinfo.ModifyTeamRoleEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ModifyTeamRoleEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.MoveEventInfo' FROM (SELECT 'wt.audit.eventinfo.MoveEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM MoveEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.NotAuthorizedAccessEventInfo' FROM (SELECT 'wt.audit.eventinfo.NotAuthorizedAccessEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM NotAuthorizedAccessEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.SLDownloadAckEventInfo' FROM (SELECT 'wt.audit.eventinfo.SLDownloadAckEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM SLDownloadAckEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.SearchEventInfo' FROM (SELECT 'wt.audit.eventinfo.SearchEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM SearchEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.ShareEventInfo' FROM (SELECT 'wt.audit.eventinfo.ShareEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ShareEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.UserSessionEventInfo' FROM (SELECT 'wt.audit.eventinfo.UserSessionEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM UserSessionEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.VersionEventInfo' FROM (SELECT 'wt.audit.eventinfo.VersionEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM VersionEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.ViewRepresentationsEventInfo' FROM (SELECT 'wt.audit.eventinfo.ViewRepresentationsEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ViewRepresentationsEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.WorkflowVariableEventInfo' FROM (SELECT 'wt.audit.eventinfo.WorkflowVariableEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WorkflowVariableEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.CADNameChangeEventInfo' FROM (SELECT 'wt.audit.eventinfo.CADNameChangeEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM CADNameChangeEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.LocationChangeEventInfo' FROM (SELECT 'wt.audit.eventinfo.LocationChangeEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM LocationChangeEventInfo B0)))) A0 UNION SELECT 'wt.audit.eventinfo.RenameEventInfo' FROM (SELECT 'wt.audit.eventinfo.RenameEventInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RenameEventInfo B0)))) A0 UNION SELECT 'wt.esi.ERPPartSpecificPlantData' FROM (SELECT 'wt.esi.ERPPartSpecificPlantData' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ERPPartSpecificPlantData B0)))) A0 UNION SELECT 'wt.epm.modelitems.ModelItem' FROM (SELECT 'wt.epm.modelitems.ModelItem' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ModelItem B0)))) A0 UNION SELECT 'wt.change2.AffectedActivityData' FROM (SELECT 'wt.change2.AffectedActivityData' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AffectedActivityData B0)))) A0 UNION SELECT 'wt.change2.ChangeRecord2' FROM (SELECT 'wt.change2.ChangeRecord2' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ChangeRecord2 B0)))) A0 UNION SELECT 'wt.change2.RelevantRequestData2' FROM (SELECT 'wt.change2.RelevantRequestData2' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RelevantRequestData2 B0)))) A0 UNION SELECT 'wt.change2.ReportedAgainst' FROM (SELECT 'wt.change2.ReportedAgainst' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ReportedAgainst B0)))) A0 UNION SELECT 'wt.change2.ProblemProduct' FROM (SELECT 'wt.change2.ProblemProduct' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProblemProduct B0)))) A0 UNION SELECT 'wt.change2.SubjectProduct' FROM (SELECT 'wt.change2.SubjectProduct' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM SubjectProduct B0)))) A0 UNION SELECT 'wt.change2.SupportingDataFor' FROM (SELECT 'wt.change2.SupportingDataFor' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM SupportingDataFor B0)))) A0 UNION SELECT 'wt.part.WTProductInstanceMaster' FROM (SELECT 'wt.part.WTProductInstanceMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTProductInstanceMaster B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMSepFamilyTable' FROM (SELECT 'wt.epm.familytable.EPMSepFamilyTable' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMSepFamilyTable B0)))) A0 UNION SELECT 'wt.meeting.MeetingDeliverable' FROM (SELECT 'wt.meeting.MeetingDeliverable' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM MeetingDeliverable B0)))) A0 UNION SELECT 'wt.org.electronicIdentity.ElectronicSignature' FROM (SELECT 'wt.org.electronicIdentity.ElectronicSignature' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ElectronicSignature B0)))) A0 UNION SELECT 'wt.workflow.definer.WfProcessTemplate' FROM (SELECT 'wt.workflow.definer.WfProcessTemplate' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WfProcessTemplate B0)))) A0 UNION SELECT 'wt.ixb.conflictFramework.ImportSession' FROM (SELECT 'wt.ixb.conflictFramework.ImportSession' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ImportSession B0)))) A0 UNION SELECT 'com.ptc.windchill.ixb.importer.ImportJob' FROM (SELECT 'com.ptc.windchill.ixb.importer.ImportJob' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ImportJob B0)))) A0 UNION SELECT 'wt.effectivity.engine.EffectivityConfigurationHolder' FROM (SELECT 'wt.effectivity.engine.EffectivityConfigurationHolder' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EffectivityConfigurationHolder B0)))) A0 UNION SELECT 'wt.inf.template.DefaultWTContainerTemplate' FROM (SELECT 'wt.inf.template.DefaultWTContainerTemplate' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DefaultWTContainerTemplate B0)))) A0 UNION SELECT 'wt.viewmarkup.WVSConfigurationTemplate' FROM (SELECT 'wt.viewmarkup.WVSConfigurationTemplate' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WVSConfigurationTemplate B0)))) A0 UNION SELECT 'wt.workflow.engine.WfProcess' FROM (SELECT 'wt.workflow.engine.WfProcess' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WfProcess B0)))) A0 UNION SELECT 'wt.projmgmt.execution.ProjectPlan' FROM (SELECT 'wt.projmgmt.execution.ProjectPlan' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProjectPlan B0)))) A0 UNION SELECT 'wt.workflow.forum.DiscussionPosting' FROM (SELECT 'wt.workflow.forum.DiscussionPosting' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DiscussionPosting B0)))) A0 UNION SELECT 'wt.workflow.notebook.ImportedBookmark' FROM (SELECT 'wt.workflow.notebook.ImportedBookmark' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ImportedBookmark B0)))) A0 UNION SELECT 'wt.workflow.templates.TaskFormTemplate' FROM (SELECT 'wt.workflow.templates.TaskFormTemplate' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM TaskFormTemplate B0)))) A0 UNION SELECT 'wt.dataops.archive.ArchiveRecord' FROM (SELECT 'wt.dataops.archive.ArchiveRecord' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ArchiveRecord B0)))) A0 UNION SELECT 'wt.dataops.archive.RestoreRecord' FROM (SELECT 'wt.dataops.archive.RestoreRecord' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RestoreRecord B0)))) A0 UNION SELECT 'wt.dataops.purge.PurgeRecord' FROM (SELECT 'wt.dataops.purge.PurgeRecord' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PurgeRecord B0)))) A0 UNION SELECT 'wt.dataops.purge.PurgeSchedule' FROM (SELECT 'wt.dataops.purge.PurgeSchedule' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PurgeSchedule B0)))) A0 UNION SELECT 'wt.dataops.replication.ContentReplSchedule' FROM (SELECT 'wt.dataops.replication.ContentReplSchedule' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ContentReplSchedule B0)))) A0 UNION SELECT 'com.ptc.windchill.dpimpl.core.DPImplSchedule' FROM (SELECT 'com.ptc.windchill.dpimpl.core.DPImplSchedule' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DPImplSchedule B0)))) A0 UNION SELECT 'wt.dataops.replication.ContentReplRecord' FROM (SELECT 'wt.dataops.replication.ContentReplRecord' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ContentReplRecord B0)))) A0 UNION SELECT 'com.ptc.windchill.dpimpl.core.DPImplJob' FROM (SELECT 'com.ptc.windchill.dpimpl.core.DPImplJob' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DPImplJob B0)))) A0 UNION SELECT 'com.ptc.windchill.wp.imp.IncomingDeliveryRecord' FROM (SELECT 'com.ptc.windchill.wp.imp.IncomingDeliveryRecord' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM IncomingDeliveryRecord B0)))) A0 UNION SELECT 'com.ptc.windchill.sync.wpsync.ExportRecord' FROM (SELECT 'com.ptc.windchill.sync.wpsync.ExportRecord' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ExportRecord B0)))) A0 UNION SELECT 'wt.dataops.archive.Archive' FROM (SELECT 'wt.dataops.archive.Archive' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM Archive B0)))) A0 UNION SELECT 'wt.replication.export.UnitExportRecord' FROM (SELECT 'wt.replication.export.UnitExportRecord' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM UnitExportRecord B0)))) A0 UNION SELECT 'wt.replication.imp.UnitImportRecord' FROM (SELECT 'wt.replication.imp.UnitImportRecord' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM UnitImportRecord B0)))) A0 UNION SELECT 'wt.replication.receiver.UnitReceiveRecord' FROM (SELECT 'wt.replication.receiver.UnitReceiveRecord' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM UnitReceiveRecord B0)))) A0 UNION SELECT 'com.ptc.windchill.dpimpl.core.WTProcessStepInstance' FROM (SELECT 'com.ptc.windchill.dpimpl.core.WTProcessStepInstance' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTProcessStepInstance B0)))) A0 UNION SELECT 'com.ptc.windchill.sync.wpsync.SyncInfo' FROM (SELECT 'com.ptc.windchill.sync.wpsync.SyncInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM SyncInfo B0)))) A0 UNION SELECT 'wt.content.QuarantinedDescription' FROM (SELECT 'wt.content.QuarantinedDescription' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM QuarantinedDescription B0)))) A0 UNION SELECT 'wt.content.StreamData' FROM (SELECT 'wt.content.StreamData' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM StreamData B0)))) A0 UNION SELECT 'wt.fv.FvItem' FROM (SELECT 'wt.fv.FvItem' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM FvItem B0)))) A0 UNION SELECT 'wt.fv.master.MasteredOnReplicaItem' FROM (SELECT 'wt.fv.master.MasteredOnReplicaItem' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM MasteredOnReplicaItem B0)))) A0 UNION SELECT 'wt.eff.EffChangeAudit' FROM (SELECT 'wt.eff.EffChangeAudit' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EffChangeAudit B0)))) A0 UNION SELECT 'wt.part.WTPartUsageLink' FROM (SELECT 'wt.part.WTPartUsageLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTPartUsageLink B0)))) A0 UNION SELECT 'wt.change2.ChangeAction' FROM (SELECT 'wt.change2.ChangeAction' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ChangeAction B0)))) A0 UNION SELECT 'wt.change2.VarianceBlockEffectivity' FROM (SELECT 'wt.change2.VarianceBlockEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM VarianceBlockEffectivity B0)))) A0 UNION SELECT 'wt.change2.VarianceDateEffectivity' FROM (SELECT 'wt.change2.VarianceDateEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM VarianceDateEffectivity B0)))) A0 UNION SELECT 'wt.change2.VarianceLotNumberEffectivity' FROM (SELECT 'wt.change2.VarianceLotNumberEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM VarianceLNEffectivity B0)))) A0 UNION SELECT 'wt.change2.VarianceMSNEffectivity' FROM (SELECT 'wt.change2.VarianceMSNEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM VarianceMSNEffectivity B0)))) A0 UNION SELECT 'wt.change2.VarianceSerialNumberEffectivity' FROM (SELECT 'wt.change2.VarianceSerialNumberEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM VarianceSNEffectivity B0)))) A0 UNION SELECT 'wt.eff.CalculatedMSNEffectivity' FROM (SELECT 'wt.eff.CalculatedMSNEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM CalculatedMSNEffectivity B0)))) A0 UNION SELECT 'wt.effectivity.WTIncorporationDate' FROM (SELECT 'wt.effectivity.WTIncorporationDate' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTIncorporationDate B0)))) A0 UNION SELECT 'wt.effectivity.WTLotEffectivity' FROM (SELECT 'wt.effectivity.WTLotEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTLotEffectivity B0)))) A0 UNION SELECT 'wt.effectivity.WTSerialNumberedEffectivity' FROM (SELECT 'wt.effectivity.WTSerialNumberedEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTSerialNumberedEffectivity B0)))) A0 UNION SELECT 'wt.effectivity.WTDatedEffectivity' FROM (SELECT 'wt.effectivity.WTDatedEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTDatedEffectivity B0)))) A0 UNION SELECT 'wt.part.ProductBlockEffectivity' FROM (SELECT 'wt.part.ProductBlockEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProductBlockEffectivity B0)))) A0 UNION SELECT 'wt.part.ProductDateEffectivity' FROM (SELECT 'wt.part.ProductDateEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProductDateEffectivity B0)))) A0 UNION SELECT 'wt.part.ProductLotNumberEffectivity' FROM (SELECT 'wt.part.ProductLotNumberEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProductLNEffectivity B0)))) A0 UNION SELECT 'wt.part.ProductMSNEffectivity' FROM (SELECT 'wt.part.ProductMSNEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProductMSNEffectivity B0)))) A0 UNION SELECT 'wt.part.ProductSerialNumberEffectivity' FROM (SELECT 'wt.part.ProductSerialNumberEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProductSNEffectivity B0)))) A0 UNION SELECT 'wt.eff.PendingBlockEffectivity' FROM (SELECT 'wt.eff.PendingBlockEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PendingBlockEffectivity B0)))) A0 UNION SELECT 'wt.eff.PendingDateEffectivity' FROM (SELECT 'wt.eff.PendingDateEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PendingDateEffectivity B0)))) A0 UNION SELECT 'wt.eff.PendingLotNumberEffectivity' FROM (SELECT 'wt.eff.PendingLotNumberEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PendingLNEffectivity B0)))) A0 UNION SELECT 'wt.eff.PendingMSNEffectivity' FROM (SELECT 'wt.eff.PendingMSNEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PendingMSNEffectivity B0)))) A0 UNION SELECT 'wt.eff.PendingSerialNumberEffectivity' FROM (SELECT 'wt.eff.PendingSerialNumberEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PendingSNEffectivity B0)))) A0 UNION SELECT 'wt.epm.EPMAuthoringAppVersion' FROM (SELECT 'wt.epm.EPMAuthoringAppVersion' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMAuthoringAppVersion B0)))) A0 UNION SELECT 'wt.epm.EPMCADNamespace' FROM (SELECT 'wt.epm.EPMCADNamespace' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMCADNamespace B0)))) A0 UNION SELECT 'wt.epm.alternaterep.EPMResultRule' FROM (SELECT 'wt.epm.alternaterep.EPMResultRule' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMResultRule B0)))) A0 UNION SELECT 'wt.epm.structure.EPMMemberLink' FROM (SELECT 'wt.epm.structure.EPMMemberLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMMemberLink B0)))) A0 UNION SELECT 'wt.epm.annotation.EPMStructureAnnotation' FROM (SELECT 'wt.epm.annotation.EPMStructureAnnotation' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMStructureAnnotation B0)))) A0 UNION SELECT 'wt.epm.annotation.EPMStructAnnotationAddMatchingData' FROM (SELECT 'wt.epm.annotation.EPMStructAnnotationAddMatchingData' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMStructAnnAddMatchingData B0)))) A0 UNION SELECT 'wt.epm.annotation.EPMStructAnnotationReplaceData' FROM (SELECT 'wt.epm.annotation.EPMStructAnnotationReplaceData' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMStructAnnotationReplaceData B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMFamilyTableCell' FROM (SELECT 'wt.epm.familytable.EPMFamilyTableCell' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMFamilyTableCell B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMFamilyTableCellDependency' FROM (SELECT 'wt.epm.familytable.EPMFamilyTableCellDependency' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMFamilyTableCellDep B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMFamilyTableAttribute' FROM (SELECT 'wt.epm.familytable.EPMFamilyTableAttribute' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMFamilyTableAttribute B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMFamilyTableFeature' FROM (SELECT 'wt.epm.familytable.EPMFamilyTableFeature' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMFamilyTableFeature B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMFamilyTableMember' FROM (SELECT 'wt.epm.familytable.EPMFamilyTableMember' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMFamilyTableMember B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMFamilyTableParameter' FROM (SELECT 'wt.epm.familytable.EPMFamilyTableParameter' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMFamilyTableParameter B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMFamilyTableReference' FROM (SELECT 'wt.epm.familytable.EPMFamilyTableReference' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMFamilyTableReference B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMFeatureDefinition' FROM (SELECT 'wt.epm.familytable.EPMFeatureDefinition' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMFeatureDefinition B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMSepFamilyTableMaster' FROM (SELECT 'wt.epm.familytable.EPMSepFamilyTableMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMSepFamilyTableMaster B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMParameterDefinition' FROM (SELECT 'wt.epm.familytable.EPMParameterDefinition' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMParameterDefinition B0)))) A0 UNION SELECT 'wt.epm.workspaces.EPMCheckpoint' FROM (SELECT 'wt.epm.workspaces.EPMCheckpoint' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMCheckpoint B0)))) A0 UNION SELECT 'wt.epm.occurrence.EPMOccurrenceTable' FROM (SELECT 'wt.epm.occurrence.EPMOccurrenceTable' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMOccurrenceTable B0)))) A0 UNION SELECT 'wt.epm.supportingdata.EPMSupportingData' FROM (SELECT 'wt.epm.supportingdata.EPMSupportingData' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMSupportingData B0)))) A0 UNION SELECT 'wt.epm.workspaces.EPMWorkspace' FROM (SELECT 'wt.epm.workspaces.EPMWorkspace' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspace B0)))) A0 UNION SELECT 'wt.epm.workspaces.ClientCacheState' FROM (SELECT 'wt.epm.workspaces.ClientCacheState' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ClientCacheState B0)))) A0 UNION SELECT 'wt.epm.workspaces.EPMInitialCheckinData' FROM (SELECT 'wt.epm.workspaces.EPMInitialCheckinData' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMInitialCheckinData B0)))) A0 UNION SELECT 'wt.epm.workspaces.EPMUpdateCounter' FROM (SELECT 'wt.epm.workspaces.EPMUpdateCounter' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMUpdateCounter B0)))) A0 UNION SELECT 'wt.epm.workspaces.EPMWorkspaceNamespace' FROM (SELECT 'wt.epm.workspaces.EPMWorkspaceNamespace' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspaceNamespace B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspaceMemberStatus' FROM (SELECT 'wt.epm.workspaces.WorkspaceMemberStatus' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WorkspaceMemberStatus B0)))) A0 UNION SELECT 'wt.epm.build.EPMBuildHistory' FROM (SELECT 'wt.epm.build.EPMBuildHistory' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMBuildHistory B0)))) A0 UNION SELECT 'wt.epm.build.EPMBuildRuleAssociationLink' FROM (SELECT 'wt.epm.build.EPMBuildRuleAssociationLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMBuildRuleAssociationLink B0)))) A0 UNION SELECT 'wt.epm.structure.EPMDescribeLink' FROM (SELECT 'wt.epm.structure.EPMDescribeLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMDescribeLink B0)))) A0 UNION SELECT 'wt.esi.ERPMaterialDocumentDescribeLink' FROM (SELECT 'wt.esi.ERPMaterialDocumentDescribeLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ERPMATERIALDOCDESCRIBELINK B0)))) A0 UNION SELECT 'wt.esi.ERPMaterialDocumentReferenceLink' FROM (SELECT 'wt.esi.ERPMaterialDocumentReferenceLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ERPMATERIALDOCREFERENCELINK B0)))) A0 UNION SELECT 'wt.esi.ERPMaterialEPMDocumentDescribeLink' FROM (SELECT 'wt.esi.ERPMaterialEPMDocumentDescribeLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ERPMATERIALEPMDOCDESCRIBELINK B0)))) A0 UNION SELECT 'wt.part.WTPartDescribeLink' FROM (SELECT 'wt.part.WTPartDescribeLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTPartDescribeLink B0)))) A0 UNION SELECT 'wt.part.WTPartReferenceLink' FROM (SELECT 'wt.part.WTPartReferenceLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTPartReferenceLink B0)))) A0 UNION SELECT 'wt.esi.ERPMaterial' FROM (SELECT 'wt.esi.ERPMaterial' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ERPMaterial B0)))) A0 UNION SELECT 'wt.part.PartUsesOccurrence' FROM (SELECT 'wt.part.PartUsesOccurrence' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PartUsesOccurrence B0)))) A0 UNION SELECT 'wt.change2.workset.WTWorkSetComponentLink' FROM (SELECT 'wt.change2.workset.WTWorkSetComponentLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTWorkSetComponentLink B0)))) A0 UNION SELECT 'wt.change2.workset.WTWorkSetReferenceLink' FROM (SELECT 'wt.change2.workset.WTWorkSetReferenceLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTWorkSetReferenceLink B0)))) A0 UNION SELECT 'com.ptc.windchill.wp.WorkPackageMaster' FROM (SELECT 'com.ptc.windchill.wp.WorkPackageMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WorkPackageMaster B0)))) A0 UNION SELECT 'com.ptc.windchill.wp.tdp.TechnicalDataPackageMaster' FROM (SELECT 'com.ptc.windchill.wp.tdp.TechnicalDataPackageMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM TechnicalDataPackageMaster B0)))) A0 UNION SELECT 'wt.fv.master.ReplicaVault' FROM (SELECT 'wt.fv.master.ReplicaVault' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ReplicaVault B0)))) A0 UNION SELECT 'com.ptc.core.percol.PersistedCollectionTombstone' FROM (SELECT 'com.ptc.core.percol.PersistedCollectionTombstone' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PersistedCollectionTombstone B0)))) A0 UNION SELECT 'com.ptc.core.percol.PersistedCollectionTombstoneHolder' FROM (SELECT 'com.ptc.core.percol.PersistedCollectionTombstoneHolder' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PersistedCollectionTombHolder B0)))) A0 UNION SELECT 'com.ptc.core.percol.SimpleNestedCollectionImpl' FROM (SELECT 'com.ptc.core.percol.SimpleNestedCollectionImpl' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM SimpleNestedCollection B0)))) A0 UNION SELECT 'wt.content.DataFormat' FROM (SELECT 'wt.content.DataFormat' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DataFormat B0)))) A0 UNION SELECT 'wt.access.agreement.AuthorizationAgreementMaster' FROM (SELECT 'wt.access.agreement.AuthorizationAgreementMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AuthorizationAgreementMaster B0)))) A0 UNION SELECT 'wt.doc.WTDocumentMaster' FROM (SELECT 'wt.doc.WTDocumentMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTDocumentMaster B0)))) A0 UNION SELECT 'wt.federation.ProxyDocumentMaster' FROM (SELECT 'wt.federation.ProxyDocumentMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProxyDocumentMaster B0)))) A0 UNION SELECT 'wt.epm.EPMDocumentMaster' FROM (SELECT 'wt.epm.EPMDocumentMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMDocumentMaster B0)))) A0 UNION SELECT 'wt.inf.template.WTContainerTemplateMaster' FROM (SELECT 'wt.inf.template.WTContainerTemplateMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTContainerTemplateMaster B0)))) A0 UNION SELECT 'wt.lifecycle.LifeCycleTemplateMaster' FROM (SELECT 'wt.lifecycle.LifeCycleTemplateMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM LifeCycleTemplateMaster B0)))) A0 UNION SELECT 'wt.workflow.definer.WfProcessTemplateMaster' FROM (SELECT 'wt.workflow.definer.WfProcessTemplateMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WfProcessTemplateMaster B0)))) A0 UNION SELECT 'wt.workflow.templates.TaskFormTemplateMaster' FROM (SELECT 'wt.workflow.templates.TaskFormTemplateMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM TaskFormTemplateMaster B0)))) A0 UNION SELECT 'com.ptc.windchill.option.model.ChoiceMaster' FROM (SELECT 'com.ptc.windchill.option.model.ChoiceMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ATOChoiceMaster B0)))) A0 UNION SELECT 'com.ptc.windchill.option.model.ChoiceConstraintMaster' FROM (SELECT 'com.ptc.windchill.option.model.ChoiceConstraintMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ChoiceConstraintMaster B0)))) A0 UNION SELECT 'com.ptc.windchill.option.model.ChoiceMappingMaster' FROM (SELECT 'com.ptc.windchill.option.model.ChoiceMappingMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ChoiceMappingMaster B0)))) A0 UNION SELECT 'com.ptc.windchill.option.model.OptionSetMaster' FROM (SELECT 'com.ptc.windchill.option.model.OptionSetMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM OptionSetMaster B0)))) A0 UNION SELECT 'wt.dataops.objectcol.BaseCriterionDefMaster' FROM (SELECT 'wt.dataops.objectcol.BaseCriterionDefMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM BaseCriterionDefMaster B0)))) A0 UNION SELECT 'wt.dataops.objectcol.CollectionCriterionDefMaster' FROM (SELECT 'wt.dataops.objectcol.CollectionCriterionDefMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM CollectionCriterionDefMaster B0)))) A0 UNION SELECT 'wt.dataops.objectcol.AttrCriterionDefMaster' FROM (SELECT 'wt.dataops.objectcol.AttrCriterionDefMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AttrCriterionDefMaster B0)))) A0 UNION SELECT 'wt.dataops.objectcol.ObjTypeCriterionDefMaster' FROM (SELECT 'wt.dataops.objectcol.ObjTypeCriterionDefMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ObjTypeCriterionDefMaster B0)))) A0 UNION SELECT 'wt.dataops.objectcol.RelationshipDefMaster' FROM (SELECT 'wt.dataops.objectcol.RelationshipDefMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RelationshipDefMaster B0)))) A0 UNION SELECT 'wt.dataops.objectcol.FilterCriterionDefMaster' FROM (SELECT 'wt.dataops.objectcol.FilterCriterionDefMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM FilterCriterionDefMaster B0)))) A0 UNION SELECT 'wt.dataops.objectcol.MethodDefMaster' FROM (SELECT 'wt.dataops.objectcol.MethodDefMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM MethodDefMaster B0)))) A0 UNION SELECT 'wt.dataops.objectcol.RelationshipMapDefMaster' FROM (SELECT 'wt.dataops.objectcol.RelationshipMapDefMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RelationshipMapDefMaster B0)))) A0 UNION SELECT 'wt.dataops.objectcol.CollectionCriteriaMaster' FROM (SELECT 'wt.dataops.objectcol.CollectionCriteriaMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM CollectionCriteriaMaster B0)))) A0 UNION SELECT 'wt.replication.unit.WTUnitMaster' FROM (SELECT 'wt.replication.unit.WTUnitMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTUnitMaster B0)))) A0 UNION SELECT 'com.ptc.wpcfg.doc.VariantSpecMaster' FROM (SELECT 'com.ptc.wpcfg.doc.VariantSpecMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM VariantSpecMaster B0)))) A0 UNION SELECT 'wt.folder.SubFolderLink' FROM (SELECT 'wt.folder.SubFolderLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM SubFolderLink B0)))) A0 UNION SELECT 'wt.change2.WTAnalysisActivityMaster' FROM (SELECT 'wt.change2.WTAnalysisActivityMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTAnalysisActivityMaster B0)))) A0 UNION SELECT 'wt.change2.WTChangeActivity2Master' FROM (SELECT 'wt.change2.WTChangeActivity2Master' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTChangeActivity2Master B0)))) A0 UNION SELECT 'wt.change2.WTChangeInvestigationMaster' FROM (SELECT 'wt.change2.WTChangeInvestigationMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTChangeInvestigationMaster B0)))) A0 UNION SELECT 'wt.change2.WTChangeIssueMaster' FROM (SELECT 'wt.change2.WTChangeIssueMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTChangeIssueMaster B0)))) A0 UNION SELECT 'wt.change2.WTChangeOrder2Master' FROM (SELECT 'wt.change2.WTChangeOrder2Master' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTChangeOrder2Master B0)))) A0 UNION SELECT 'wt.change2.WTChangeProposalMaster' FROM (SELECT 'wt.change2.WTChangeProposalMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTChangeProposalMaster B0)))) A0 UNION SELECT 'wt.change2.WTChangeRequest2Master' FROM (SELECT 'wt.change2.WTChangeRequest2Master' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTChangeRequest2Master B0)))) A0 UNION SELECT 'wt.change2.WTVarianceMaster' FROM (SELECT 'wt.change2.WTVarianceMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTVarianceMaster B0)))) A0 UNION SELECT 'wt.effectivity.WTProductInstance' FROM (SELECT 'wt.effectivity.WTProductInstance' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTProductInstance B0)))) A0 UNION SELECT 'wt.change2.workset.WTWorkSetMaster' FROM (SELECT 'wt.change2.workset.WTWorkSetMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTWorkSetMaster B0)))) A0 UNION SELECT 'wt.part.alternaterep.WTPartAlternateRepMaster' FROM (SELECT 'wt.part.alternaterep.WTPartAlternateRepMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTPartAlternateRepMaster B0)))) A0 UNION SELECT 'wt.query.template.ReportTemplate' FROM (SELECT 'wt.query.template.ReportTemplate' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ReportTemplate B0)))) A0 UNION SELECT 'wt.fc.IdentityChangeHistory' FROM (SELECT 'wt.fc.IdentityChangeHistory' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM IdentityChangeHistory B0)))) A0 UNION SELECT 'wt.epm.build.EPMBuildRule' FROM (SELECT 'wt.epm.build.EPMBuildRule' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMBuildRule B0)))) A0 UNION SELECT 'wt.epm.build.EPMDerivedRepRule' FROM (SELECT 'wt.epm.build.EPMDerivedRepRule' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMDerivedRepRule B0)))) A0 UNION SELECT 'wt.change2.AcceptedStrategy' FROM (SELECT 'wt.change2.AcceptedStrategy' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AcceptedStrategy B0)))) A0 UNION SELECT 'wt.change2.AddressedBy2' FROM (SELECT 'wt.change2.AddressedBy2' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AddressedBy2 B0)))) A0 UNION SELECT 'wt.change2.DetailedBy' FROM (SELECT 'wt.change2.DetailedBy' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DetailedBy B0)))) A0 UNION SELECT 'wt.change2.FormalizedBy' FROM (SELECT 'wt.change2.FormalizedBy' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM FormalizedBy B0)))) A0 UNION SELECT 'wt.change2.IncludedIn2' FROM (SELECT 'wt.change2.IncludedIn2' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM IncludedIn2 B0)))) A0 UNION SELECT 'wt.change2.IssueImplementedBy' FROM (SELECT 'wt.change2.IssueImplementedBy' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM IssueImplementedBy B0)))) A0 UNION SELECT 'wt.change2.ResearchedBy' FROM (SELECT 'wt.change2.ResearchedBy' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ResearchedBy B0)))) A0 UNION SELECT 'wt.access.agreement.AgreementPrincipalLink' FROM (SELECT 'wt.access.agreement.AgreementPrincipalLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AgreementPrincipalLink B0)))) A0 UNION SELECT 'wt.associativity.ConsumptionLink' FROM (SELECT 'wt.associativity.ConsumptionLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ConsumptionLink B0)))) A0 UNION SELECT 'wt.associativity.EquivalenceLink' FROM (SELECT 'wt.associativity.EquivalenceLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EquivalenceLink B0)))) A0 UNION SELECT 'wt.aum.AlternateUnitLink' FROM (SELECT 'wt.aum.AlternateUnitLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AlternateUnitLink B0)))) A0 UNION SELECT 'wt.build.BuildHistory' FROM (SELECT 'wt.build.BuildHistory' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM BuildHistory B0)))) A0 UNION SELECT 'wt.epm.build.EPMDerivedRepHistory' FROM (SELECT 'wt.epm.build.EPMDerivedRepHistory' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMDerivedRepHistory B0)))) A0 UNION SELECT 'wt.calendar.ComponentLink' FROM (SELECT 'wt.calendar.ComponentLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ComponentLink B0)))) A0 UNION SELECT 'wt.change2.ChangesForAnnotations' FROM (SELECT 'wt.change2.ChangesForAnnotations' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ChangesForAnnotations B0)))) A0 UNION SELECT 'wt.change2.ChangesForMarkups' FROM (SELECT 'wt.change2.ChangesForMarkups' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ChangesForMarkups B0)))) A0 UNION SELECT 'wt.change2.CreatedFromVersion' FROM (SELECT 'wt.change2.CreatedFromVersion' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM CreatedFromVersion B0)))) A0 UNION SELECT 'wt.change2.Impacts' FROM (SELECT 'wt.change2.Impacts' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM Impacts B0)))) A0 UNION SELECT 'wt.configurablelink.ConfigurableMastersLink' FROM (SELECT 'wt.configurablelink.ConfigurableMastersLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ConfigurableMastersLink B0)))) A0 UNION SELECT 'wt.content.AggToContentItem' FROM (SELECT 'wt.content.AggToContentItem' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AggToContentItem B0)))) A0 UNION SELECT 'wt.content.HolderToContent' FROM (SELECT 'wt.content.HolderToContent' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM HolderToContent B0)))) A0 UNION SELECT 'wt.content.HttpOperationItem' FROM (SELECT 'wt.content.HttpOperationItem' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM HttpOperationItem B0)))) A0 UNION SELECT 'wt.content.OpLink' FROM (SELECT 'wt.content.OpLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM OpLink B0)))) A0 UNION SELECT 'wt.effectivity.engine.CIEffConfigHolderLink' FROM (SELECT 'wt.effectivity.engine.CIEffConfigHolderLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM CIEffConfigHolderLink B0)))) A0 UNION SELECT 'wt.enterprise.MadeFromLink' FROM (SELECT 'wt.enterprise.MadeFromLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM MadeFromLink B0)))) A0 UNION SELECT 'wt.epm.alternaterep.AlternateRepContainerLink' FROM (SELECT 'wt.epm.alternaterep.AlternateRepContainerLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AlternateRepContainerLink B0)))) A0 UNION SELECT 'wt.epm.modelitems.ModelItemContainedIn' FROM (SELECT 'wt.epm.modelitems.ModelItemContainedIn' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ModelItemContainedIn B0)))) A0 UNION SELECT 'wt.epm.modelitems.ModelItemLink' FROM (SELECT 'wt.epm.modelitems.ModelItemLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ModelItemLink B0)))) A0 UNION SELECT 'wt.epm.structure.EPMContainedIn' FROM (SELECT 'wt.epm.structure.EPMContainedIn' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMContainedIn B0)))) A0 UNION SELECT 'wt.epm.structure.EPMReferenceLink' FROM (SELECT 'wt.epm.structure.EPMReferenceLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMReferenceLink B0)))) A0 UNION SELECT 'wt.epm.structure.EPMVariantLink' FROM (SELECT 'wt.epm.structure.EPMVariantLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMVariantLink B0)))) A0 UNION SELECT 'wt.esi.ERPMaterialLink' FROM (SELECT 'wt.esi.ERPMaterialLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ERPMaterialLink B0)))) A0 UNION SELECT 'wt.esi.ERPPartSpecificPlantDataLink' FROM (SELECT 'wt.esi.ERPPartSpecificPlantDataLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ERPPartSpecificPlantDataLink B0)))) A0 UNION SELECT 'wt.workflow.templates.MasterIteration' FROM (SELECT 'wt.workflow.templates.MasterIteration' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM TaskFormTemplate B0)))) A0 UNION SELECT 'wt.workflow.notebook.WfFolderedBookmarkObjectLink' FROM (SELECT 'wt.workflow.notebook.WfFolderedBookmarkObjectLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WfFolderedBookmark B0)))) A0 UNION SELECT 'wt.workflow.notebook.WfBookmarkObjectLink' FROM (SELECT 'wt.workflow.notebook.WfBookmarkObjectLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WfBookmark B0)))) A0 UNION SELECT 'wt.workflow.notebook.FolderSubFolderLink' FROM (SELECT 'wt.workflow.notebook.FolderSubFolderLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM NotebookFolder B0)))) A0 UNION SELECT 'wt.workflow.notebook.NotebookFolderLink' FROM (SELECT 'wt.workflow.notebook.NotebookFolderLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM NotebookFolder B0)))) A0 UNION SELECT 'wt.workflow.notebook.NotebookBookmarkLink' FROM (SELECT 'wt.workflow.notebook.NotebookBookmarkLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM Bookmark B0)))) A0 UNION SELECT 'wt.workflow.notebook.FolderBookmarkLink' FROM (SELECT 'wt.workflow.notebook.FolderBookmarkLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM Bookmark B0)))) A0 UNION SELECT 'wt.workflow.forum.ForumCookieLink' FROM (SELECT 'wt.workflow.forum.ForumCookieLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ForumCookie B0)))) A0 UNION SELECT 'wt.workflow.forum.ForumTopicLink' FROM (SELECT 'wt.workflow.forum.ForumTopicLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DiscussionTopic B0)))) A0 UNION SELECT 'wt.workflow.forum.TopicSubtopicLink' FROM (SELECT 'wt.workflow.forum.TopicSubtopicLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DiscussionTopic B0)))) A0 UNION SELECT 'wt.workflow.forum.PostingSubpostingLink' FROM (SELECT 'wt.workflow.forum.PostingSubpostingLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DiscussionPosting B0)))) A0 UNION SELECT 'wt.workflow.forum.TopicPostingLink' FROM (SELECT 'wt.workflow.forum.TopicPostingLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DiscussionPosting B0)))) A0 UNION SELECT 'wt.workflow.forum.ForumDefInstanceLink' FROM (SELECT 'wt.workflow.forum.ForumDefInstanceLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DiscussionForum B0)))) A0 UNION SELECT 'wt.workflow.engine.TheWorkItemTheWfVotingEventAudit' FROM (SELECT 'wt.workflow.engine.TheWorkItemTheWfVotingEventAudit' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WfVotingEventAudit B0)))) A0 UNION SELECT 'wt.workflow.definer.ProxyProcessDefinitionLink' FROM (SELECT 'wt.workflow.definer.ProxyProcessDefinitionLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WfProxyTemplate B0)))) A0 UNION SELECT 'wt.workflow.definer.MasterIteration' FROM (SELECT 'wt.workflow.definer.MasterIteration' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WfProcessTemplate B0)))) A0 UNION SELECT 'wt.viewmarkup.ThePublishingProhibitionTarget' FROM (SELECT 'wt.viewmarkup.ThePublishingProhibitionTarget' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PublishingProhibition B0)))) A0 UNION SELECT 'wt.viewmarkup.AssignedToLcmMarkUp' FROM (SELECT 'wt.viewmarkup.AssignedToLcmMarkUp' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM LifeCycleManagedWtMarkUp B0)))) A0 UNION SELECT 'wt.viewmarkup.DerivedFromTheDerivedImage' FROM (SELECT 'wt.viewmarkup.DerivedFromTheDerivedImage' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DerivedImage B0)))) A0 UNION SELECT 'wt.vc.baseline.BaselineTopObjLink' FROM (SELECT 'wt.vc.baseline.BaselineTopObjLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ManagedBaseline B0)))) A0 UNION SELECT 'wt.vc.TheControlBranchPredecessor' FROM (SELECT 'wt.vc.TheControlBranchPredecessor' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ControlBranch B0)))) A0 UNION SELECT 'wt.ufid.LocalObjectRemoteInfo' FROM (SELECT 'wt.ufid.LocalObjectRemoteInfo' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RemoteObjectInfo B0)))) A0 UNION SELECT 'wt.team.TeamTemplateLink' FROM (SELECT 'wt.team.TeamTemplateLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM Team B0)))) A0 UNION SELECT 'wt.team.RoleRoleLink' FROM (SELECT 'wt.team.RoleRoleLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RoleRoleMap B0)))) A0 UNION SELECT 'wt.team.RolePrincipalLink' FROM (SELECT 'wt.team.RolePrincipalLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RolePrincipalMap B0)))) A0 UNION SELECT 'wt.team.RolePoolLink' FROM (SELECT 'wt.team.RolePoolLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RolePoolMap B0)))) A0 UNION SELECT 'wt.team.RoleActorRoleLink' FROM (SELECT 'wt.team.RoleActorRoleLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RoleActorRoleMap B0)))) A0 UNION SELECT 'wt.scheduler.ScheduleItemHistory' FROM (SELECT 'wt.scheduler.ScheduleItemHistory' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ScheduleHistory B0)))) A0 UNION SELECT 'wt.query.SavedQueryHistory' FROM (SELECT 'wt.query.SavedQueryHistory' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM SearchHistory B0)))) A0 UNION SELECT 'wt.projmgmt.resource.ProjectDeliverableLink' FROM (SELECT 'wt.projmgmt.resource.ProjectDeliverableLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM Deliverable B0)))) A0 UNION SELECT 'wt.projmgmt.execution.ProjectWorkItemLink' FROM (SELECT 'wt.projmgmt.execution.ProjectWorkItemLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProjectWorkItem B0)))) A0 UNION SELECT 'wt.projmgmt.execution.ProjectPlanLink' FROM (SELECT 'wt.projmgmt.execution.ProjectPlanLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProjectPlan B0)))) A0 UNION SELECT 'wt.projmgmt.execution.ProjectAssignmentLink' FROM (SELECT 'wt.projmgmt.execution.ProjectAssignmentLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProjectAssignment B0)))) A0 UNION SELECT 'wt.preference.PreferenceClientInstance' FROM (SELECT 'wt.preference.PreferenceClientInstance' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PreferenceInstance B0)))) A0 UNION SELECT 'wt.preference.TheWTContainerThePreferenceInstance' FROM (SELECT 'wt.preference.TheWTContainerThePreferenceInstance' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PreferenceInstance B0)))) A0 UNION SELECT 'wt.preference.TheWTUserThePreferenceInstance' FROM (SELECT 'wt.preference.TheWTUserThePreferenceInstance' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PreferenceInstance B0)))) A0 UNION SELECT 'wt.preference.ThePreferenceDefinitionThePreferenceInstance' FROM (SELECT 'wt.preference.ThePreferenceDefinitionThePreferenceInstance' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PreferenceInstance B0)))) A0 UNION SELECT 'wt.preference.ParentPreferenceClientChildPreferenceClient' FROM (SELECT 'wt.preference.ParentPreferenceClientChildPreferenceClient' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PreferenceClient B0)))) A0 UNION SELECT 'wt.preference.ParentPreferenceCategoryChildPreferenceCategory' FROM (SELECT 'wt.preference.ParentPreferenceCategoryChildPreferenceCategory' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PreferenceCategory B0)))) A0 UNION SELECT 'wt.preference.ThePreferenceInstanceTheMultiValuedPreferenceInstance' FROM (SELECT 'wt.preference.ThePreferenceInstanceTheMultiValuedPreferenceInstance' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM MultiValuedPreferenceInstance B0)))) A0 UNION SELECT 'wt.pdmlink.ThePDMLinkProductProduct' FROM (SELECT 'wt.pdmlink.ThePDMLinkProductProduct' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PDMLinkProduct B0)))) A0 UNION SELECT 'wt.part.build.ChildPartMasterDeletedBuildReference' FROM (SELECT 'wt.part.build.ChildPartMasterDeletedBuildReference' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DeletedBuildReference B0)))) A0 UNION SELECT 'wt.part.build.ParentAssemblyDeletedBuildReference' FROM (SELECT 'wt.part.build.ParentAssemblyDeletedBuildReference' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DeletedBuildReference B0)))) A0 UNION SELECT 'wt.part.ProductProductInstance' FROM (SELECT 'wt.part.ProductProductInstance' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTProductInstanceMaster B0)))) A0 UNION SELECT 'wt.part.ProductInstanceMasterProductInstance' FROM (SELECT 'wt.part.ProductInstanceMasterProductInstance' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTProductInstance2 B0)))) A0 UNION SELECT 'wt.part.ProductConfigForConfig' FROM (SELECT 'wt.part.ProductConfigForConfig' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTProductConfigMaster B0)))) A0 UNION SELECT 'wt.part.ConfigurationMasterConfiguration' FROM (SELECT 'wt.part.ConfigurationMasterConfiguration' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTProductConfiguration B0)))) A0 UNION SELECT 'wt.part.MasterIteration' FROM (SELECT 'wt.part.MasterIteration' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTPart B0)))) A0 UNION SELECT 'wt.part.ThePublishedLineNumberPart' FROM (SELECT 'wt.part.ThePublishedLineNumberPart' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PublishedLineNumber B0)))) A0 UNION SELECT 'wt.part.PPSerialNumberEffectivity' FROM (SELECT 'wt.part.PPSerialNumberEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProductSNEffectivity B0)))) A0 UNION SELECT 'wt.part.PPMSNEffectivity' FROM (SELECT 'wt.part.PPMSNEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProductMSNEffectivity B0)))) A0 UNION SELECT 'wt.part.PPLotNumberEffectivity' FROM (SELECT 'wt.part.PPLotNumberEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProductLNEffectivity B0)))) A0 UNION SELECT 'wt.part.PPDateEffectivity' FROM (SELECT 'wt.part.PPDateEffectivity' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProductDateEffectivity B0)))) A0 UNION SELECT 'wt.part.PPBlockEffectivitiy' FROM (SELECT 'wt.part.PPBlockEffectivitiy' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProductBlockEffectivity B0)))) A0 UNION SELECT 'wt.part.TheInstanceReplacementRecordReplacement' FROM (SELECT 'wt.part.TheInstanceReplacementRecordReplacement' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM InstanceReplacementRecord B0)))) A0 UNION SELECT 'wt.notify.NotifySubscriptionTargetLink' FROM (SELECT 'wt.notify.NotifySubscriptionTargetLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM NotifySubscriptionTarget B0)))) A0 UNION SELECT 'wt.notify.NotifySubscriptnRecipntLink' FROM (SELECT 'wt.notify.NotifySubscriptnRecipntLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM NotifySubscriptionRecipient B0)))) A0 UNION SELECT 'wt.meeting.actionitem.ActionItemSourceLink' FROM (SELECT 'wt.meeting.actionitem.ActionItemSourceLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DiscreteActionItem B0)))) A0 UNION SELECT 'wt.maturity.ThePromotionNoticeCollectedBaseline' FROM (SELECT 'wt.maturity.ThePromotionNoticeCollectedBaseline' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PromotionNotice B0)))) A0 UNION SELECT 'wt.maturity.ThePromotionNoticeConfiguration' FROM (SELECT 'wt.maturity.ThePromotionNoticeConfiguration' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PromotionNotice B0)))) A0 UNION SELECT 'wt.lifecycle.PhaseWorkflow' FROM (SELECT 'wt.lifecycle.PhaseWorkflow' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PhaseTemplate B0)))) A0 UNION SELECT 'wt.lifecycle.GateWorkflow' FROM (SELECT 'wt.lifecycle.GateWorkflow' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM PhaseTemplate B0)))) A0 UNION SELECT 'wt.lifecycle.MasterIteration' FROM (SELECT 'wt.lifecycle.MasterIteration' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM LifeCycleTemplate B0)))) A0 UNION SELECT 'wt.intersvrcom.SiteRepository' FROM (SELECT 'wt.intersvrcom.SiteRepository' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AbstractSite B0)))) A0 UNION SELECT 'wt.intersvrcom.SitePrincipal' FROM (SELECT 'wt.intersvrcom.SitePrincipal' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AbstractSite B0)))) A0 UNION SELECT 'wt.intersvrcom.SiteSecurityLink' FROM (SELECT 'wt.intersvrcom.SiteSecurityLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM AbstractSite B0)))) A0 UNION SELECT 'wt.inf.template.MasterIteration' FROM (SELECT 'wt.inf.template.MasterIteration' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DefaultWTContainerTemplate B0)))) A0 UNION SELECT 'wt.inf.container.ContainerFilter' FROM (SELECT 'wt.inf.container.ContainerFilter' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WTContainerFilter B0)))) A0 UNION SELECT 'wt.inf.container.PrivateDomainLink' FROM (SELECT 'wt.inf.container.PrivateDomainLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM OrgContainer B0)))) A0 UNION SELECT 'wt.inf.container.ClassicLink' FROM (SELECT 'wt.inf.container.ClassicLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ExchangeContainer B0)))) A0 UNION SELECT 'wt.iba.definition.UnitQOMLink' FROM (SELECT 'wt.iba.definition.UnitQOMLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM UnitDefinition B0)))) A0 UNION SELECT 'wt.fv.VaultRootFolderLink' FROM (SELECT 'wt.fv.VaultRootFolderLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RootFolder B0)))) A0 UNION SELECT 'wt.fv.RecordedObjectLink' FROM (SELECT 'wt.fv.RecordedObjectLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RecordedObjectHistory B0)))) A0 UNION SELECT 'wt.fv.ChangeHistoryLink' FROM (SELECT 'wt.fv.ChangeHistoryLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RecordedHistory B0)))) A0 UNION SELECT 'wt.fv.RecordHistotyTheRecordedHistory' FROM (SELECT 'wt.fv.RecordHistotyTheRecordedHistory' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM RecordedHistory B0)))) A0 UNION SELECT 'wt.fv.VaultPolicyRuleLink' FROM (SELECT 'wt.fv.VaultPolicyRuleLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM FvPolicyRule B0)))) A0 UNION SELECT 'wt.fv.VaultPolicyItemLink' FROM (SELECT 'wt.fv.VaultPolicyItemLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM FvPolicyItem B0)))) A0 UNION SELECT 'wt.fv.SiteHostLink' FROM (SELECT 'wt.fv.SiteHostLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM FvHost B0)))) A0 UNION SELECT 'wt.folder.history.OldFolderTheLocationChangeRecord' FROM (SELECT 'wt.folder.history.OldFolderTheLocationChangeRecord' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM LocationChangeRecord B0)))) A0 UNION SELECT 'wt.folder.history.ObjectTheLocationChangeRecord' FROM (SELECT 'wt.folder.history.ObjectTheLocationChangeRecord' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM LocationChangeRecord B0)))) A0 UNION SELECT 'wt.filter.FilterTemplateTheNavigationFilter' FROM (SELECT 'wt.filter.FilterTemplateTheNavigationFilter' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM NavigationFilter B0)))) A0 UNION SELECT 'wt.filter.TheNavigationCriteriaOwner' FROM (SELECT 'wt.filter.TheNavigationCriteriaOwner' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM NavigationCriteria B0)))) A0 UNION SELECT 'wt.filter.FilterTemplateTheNavFilterConstraint' FROM (SELECT 'wt.filter.FilterTemplateTheNavFilterConstraint' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM NavFilterConstraint B0)))) A0 UNION SELECT 'wt.filter.FilterTemplateTheDesignationGroup' FROM (SELECT 'wt.filter.FilterTemplateTheDesignationGroup' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM DesignationGroup B0)))) A0 UNION SELECT 'wt.federation.MasterIteration' FROM (SELECT 'wt.federation.MasterIteration' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ProxyDocument B0)))) A0 UNION SELECT 'wt.fc.TheSemanticKeyTheUniquelyIdentified' FROM (SELECT 'wt.fc.TheSemanticKeyTheUniquelyIdentified' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM SemanticKey B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspaceMember' FROM (SELECT 'wt.epm.workspaces.WorkspaceMember' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM WorkspaceMemberStatus B0)))) A0 UNION SELECT 'wt.epm.workspaces.TheEPMWorkspaceNamespaceNamespace' FROM (SELECT 'wt.epm.workspaces.TheEPMWorkspaceNamespaceNamespace' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspaceNamespace B0)))) A0 UNION SELECT 'wt.epm.workspaces.WsNamespaceEntryMaster' FROM (SELECT 'wt.epm.workspaces.WsNamespaceEntryMaster' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspaceNamespace B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspaceCheckpoint' FROM (SELECT 'wt.epm.workspaces.WorkspaceCheckpoint' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspace B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspaceContainer' FROM (SELECT 'wt.epm.workspaces.WorkspaceContainer' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspace B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspaceView' FROM (SELECT 'wt.epm.workspaces.WorkspaceView' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspace B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspaceTeamTemplate' FROM (SELECT 'wt.epm.workspaces.WorkspaceTeamTemplate' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspace B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspacePartFolder' FROM (SELECT 'wt.epm.workspaces.WorkspacePartFolder' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspace B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspaceDocFolder' FROM (SELECT 'wt.epm.workspaces.WorkspaceDocFolder' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspace B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspacePartLifeCycle' FROM (SELECT 'wt.epm.workspaces.WorkspacePartLifeCycle' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspace B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspaceDocLifeCycle' FROM (SELECT 'wt.epm.workspaces.WorkspaceDocLifeCycle' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspace B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspaceDocConfigSpec' FROM (SELECT 'wt.epm.workspaces.WorkspaceDocConfigSpec' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspace B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspacePartConfigSpec' FROM (SELECT 'wt.epm.workspaces.WorkspacePartConfigSpec' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspace B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspaceFolder' FROM (SELECT 'wt.epm.workspaces.WorkspaceFolder' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspace B0)))) A0 UNION SELECT 'wt.epm.workspaces.Checkpoint' FROM (SELECT 'wt.epm.workspaces.Checkpoint' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMWorkspace B0)))) A0 UNION SELECT 'wt.epm.workspaces.UpdateCounterTrackable' FROM (SELECT 'wt.epm.workspaces.UpdateCounterTrackable' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMUpdateCounter B0)))) A0 UNION SELECT 'wt.epm.workspaces.TargetFolderLink' FROM (SELECT 'wt.epm.workspaces.TargetFolderLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMInitialCheckinData B0)))) A0 UNION SELECT 'wt.epm.workspaces.NewObjectDataLink' FROM (SELECT 'wt.epm.workspaces.NewObjectDataLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMInitialCheckinData B0)))) A0 UNION SELECT 'wt.epm.workspaces.MasterIteration' FROM (SELECT 'wt.epm.workspaces.MasterIteration' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMCheckpoint B0)))) A0 UNION SELECT 'wt.epm.workspaces.DocumentToCacheState' FROM (SELECT 'wt.epm.workspaces.DocumentToCacheState' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ClientCacheState B0)))) A0 UNION SELECT 'wt.epm.workspaces.WorkspaceToCacheState' FROM (SELECT 'wt.epm.workspaces.WorkspaceToCacheState' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ClientCacheState B0)))) A0 UNION SELECT 'wt.epm.supportingdata.AppDataVersionLink' FROM (SELECT 'wt.epm.supportingdata.AppDataVersionLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMSupportingData B0)))) A0 UNION SELECT 'wt.epm.supportingdata.HolderSupportingData' FROM (SELECT 'wt.epm.supportingdata.HolderSupportingData' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMSupportingData B0)))) A0 UNION SELECT 'wt.epm.modelitems.MasterIteration' FROM (SELECT 'wt.epm.modelitems.MasterIteration' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM ModelItem B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMSepFamilyTableMasterFamilyTableLink' FROM (SELECT 'wt.epm.familytable.EPMSepFamilyTableMasterFamilyTableLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMSepFamilyTable B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMParameterValueContainerLink' FROM (SELECT 'wt.epm.familytable.EPMParameterValueContainerLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMParameterValue B0)))) A0 UNION SELECT 'wt.epm.familytable.EPMParameterDefinitionContainerLink' FROM (SELECT 'wt.epm.familytable.EPMParameterDefinitionContainerLink' classname FROM DUAL WHERE ( NOT (EXISTS (SELECT B0.idA2A2 FROM EPMParameterDefinition B0)))) A0; Bind Parameters=[]". Database system message follows:
Fri 3/16/12 16:17:23: main: Nested exception is: java.sql.SQLException: ORA-04030: out of process memory when trying to allocate 1012 bytes (kxs-heap-c,kghsstk)
Fri 3/16/12 16:17:23: main:at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:439)
Fri 3/16/12 16:17:23: main:at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:395)
Fri 3/16/12 16:17:23: main:at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:802)
Fri 3/16/12 16:17:23: main:at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:436)
Fri 3/16/12 16:17:23: main:at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:186)
Fri 3/16/12 16:17:23: main:at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:521)
Fri 3/16/12 16:17:23: main:at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:205)
Fri 3/16/12 16:17:23: main:at oracle.jdbc.driver.T4CPreparedStatement.executeForDescribe(T4CPreparedStatement.java:861)
Fri 3/16/12 16:17:23: main:at oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(OracleStatement.java:1145)
Fri 3/16/12 16:17:23: main:at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1267)
Fri 3/16/12 16:17:23: main:at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3449)
Fri 3/16/12 16:17:23: main:at oracle.jdbc.driver.OraclePreparedStatement.executeQuery(OraclePreparedStatement.java:3493)
Fri 3/16/12 16:17:23: main:at oracle.jdbc.driver.OraclePreparedStatementWrapper.executeQuery(OraclePreparedStatementWrapper.java:1491)
Fri 3/16/12 16:17:23: main:at wt.pds.AbstractResultCursor.executeQuery(AbstractResultCursor.java:520)
Fri 3/16/12 16:17:23: main:at wt.pds.BasicResultCursor.getNextResultSet(BasicResultCursor.java:237)
Fri 3/16/12 16:17:23: main:at wt.pds.BasicResultCursor.advance(BasicResultCursor.java:192)
Fri 3/16/12 16:17:23: main:at wt.pds.BasicResultCursor.next(BasicResultCursor.java:80)
Fri 3/16/12 16:17:23: main:at wt.pds.SQLDatabasePds.query(SQLDatabasePds.java:719)
Fri 3/16/12 16:17:23: main:at wt.pom.PersistentObjectManager.query(PersistentObjectManager.java:1156)
Fri 3/16/12 16:17:23: main:at wt.pom.PersistentObjectManager.query(PersistentObjectManager.java:1059)
Fri 3/16/12 16:17:23: main:at wt.pom.EmptyTableManager.queryTables(EmptyTableManager.java:538)
Fri 3/16/12 16:17:23: main:at wt.pom.EmptyTableManager.queryTables(EmptyTableManager.java:481)
Fri 3/16/12 16:17:23: main:at wt.pom.EmptyTableManager.findEmptyTables(EmptyTableManager.java:557)
Fri 3/16/12 16:17:23: main:at wt.pom.EmptyTableManager.populateCache(EmptyTableManager.java:131)
Fri 3/16/12 16:17:23: main:at wt.pom.EmptyTableManager.access$100(EmptyTableManager.java:83)
Fri 3/16/12 16:17:23: main:at wt.pom.EmptyTableManager$AllManagersStartedEventListener.notifyVetoableEvent(EmptyTableManager.java:658)
Fri 3/16/12 16:17:23: main:at wt.events.StandardKeyedEventBranch.intDispatchEvent(StandardKeyedEventBranch.java:320)
Fri 3/16/12 16:17:23: main:at wt.events.StandardKeyedEventBranch.dispatchVetoableEvent(StandardKeyedEventBranch.java:229)
Fri 3/16/12 16:17:23: main:at wt.events.StandardKeyedEventDispatcher.intDispatchEvent(StandardKeyedEventDispatcher.java:286)
Fri 3/16/12 16:17:23: main:at wt.events.StandardKeyedEventDispatcher.dispatchVetoableEvent(StandardKeyedEventDispatcher.java:215)
Fri 3/16/12 16:17:23: main:at wt.services.StandardManagerService.intDispatchVetoableEvent(StandardManagerService.java:406)
Fri 3/16/12 16:17:23: main:at wt.services.StandardManagerService.dispatchVetoableEvent(StandardManagerService.java:302)
Fri 3/16/12 16:17:23: main:at wt.services.StandardManagerService.performStartupProcess(StandardManagerService.java:184)
Fri 3/16/12 16:17:23: main:at wt.services.StandardManager.startup(StandardManager.java:459)
Fri 3/16/12 16:17:23: main:at wt.services.StandardServicesHandler.start(StandardServicesHandler.java:44)
Fri 3/16/12 16:17:23: main:at wt.method.MethodServerMain.run(MethodServerMain.java:420)
Fri 3/16/12 16:17:23: main:at wt.method.MethodServerMain.main(MethodServerMain.java:271)
Fri 3/16/12 16:17:23: main: FATAL : wt.method.server.shutdown - Stopping services...
Fri 3/16/12 16:17:24: main: INFO : wt.method.server.shutdown.services - All managers shut down.
Fri 3/16/12 16:17:24: main: FATAL : wt.method.server.shutdown - MethodServer stopped
Vivek
you got this issue because you installed Windchill 10 on a 32-bit system.
Because a 32bit system cannot manage more than 1.7GB memory for Oracle 11.2.0.1 or higher. You have to fix the /3GB issue for Oracle. Then you can load data.
I installed Windchill 10M030 on a Windows XP 32bit VMWare system (4GMemory). After i loaded the demo data and try to loginto Windchill, it took very very long time.
