I would like to compil the file LoadECR.java (see the join file) in a windchill shell with the next command : javac LoadECR.java -d \windchill\codebase
The next errors appears :
C:\PTC\Windchill_10.0>javac Windchill\src\loadECR.java -d Windchill\codebase
C:\ptc\Windchill_10.0\Windchill\codebase\wt\type\TypeDefinitionReference.class:
warning: Cannot find annotation method 'versions()' in type 'com.ptc.windchill.a
warning: Cannot find annotation method 'properties()' in type 'com.ptc.windchill
.annotations.metadata.GenAsObjectMappable'
warning: Cannot find annotation method 'name()' in type 'com.ptc.windchill.annot
.metadata.GeneratedProperty not found
warning: Cannot find annotation method 'type()' in type 'com.ptc.windchill.annot
warning: Cannot find annotation method 'constraints()' in type 'com.ptc.windchil
warning: Cannot find annotation method 'required()' in type 'com.ptc.windchill.a
C:\ptc\Windchill_10.0\Windchill\codebase\wt\pdmlink\PDMLinkProduct.class: warnin
g: Cannot find annotation method 'superClass()' in type 'com.ptc.windchill.annot
g: Cannot find annotation method 'interfaces()' in type 'com.ptc.windchill.annot
g: Cannot find annotation method 'versions()' in type 'com.ptc.windchill.annotat
g: Cannot find annotation method 'properties()' in type 'com.ptc.windchill.annot
g: Cannot find annotation method 'name()' in type 'com.ptc.windchill.annotations
.metadata.GeneratedProperty'
g: Cannot find annotation method 'type()' in type 'com.ptc.windchill.annotations
g: Cannot find annotation method 'accessors()' in type 'com.ptc.windchill.annota
g: Cannot find annotation method 'getAccess()' in type 'com.ptc.windchill.annota
An exception has occurred in the compiler (1.6.0_22). Please file a bug at the J
ava Developer Connection (http://java.sun.com/webapps/bugreport) after checking
the Bug Parade for duplicates. Include your program and the following diagnosti
c in your report. Thank you.
If somebody has an idea to correct the join file, I will be interested.
Thank you in advance.
same problem. i use NetBean IDE for compil.
i use windchill library and jdk 1.6 (java wich install with windhill)
An exception has occurred in the compiler (1.6.0_26). Please file a bug at the Java Developer Connection (http://java.sun.com/webapps/bugreport) after checking the Bug Parade for duplicates. Include your program and the following diagnostic in your report. Thank you.
com.sun.tools.javac.code.Symbol$CompletionFailure: class file for com.ptc.windchill.annotations.metadata.SupportedAPI not found
Hi Georges MAURY/ Andrey Golovatyuk
I have a code which workks with Windchill 9.1, and now i have to make it compatible to run with Windchill 10.1.
When i try to compile this code in Windchill shell i get similer Warning Issues which you have faced earlier.
Will you guide me to overcome these issues...
Vivek
Hi Georges Maury,
it SUCCESSFULLY compiled for me,
Please follow the below steps to compile the Windchill Java File.
1. Open the windchill Shell
2. Place the file under C:\LoadECR\LoadECR.java
3.ant -f bin/tools.xml class -Dclass.includes=*.java -Dclass.source=C:\LoadECR
the above will compile and place the .class file to codebase\ext\load\
I have tested your file, It works great.
.class file is attached.
it SUCCESSFULLY compiled for me too.
I compiled it using Eclipse
