Windchill 10 - loader ECR / ECN
gmaury-2
I would like to compil the file LoadECR.java (see the join file) in a windchill shell with the next command : javac LoadECR.java -d \windchill\codebase
The next errors appears :
C:\PTC\Windchill_10.0>javac Windchill\src\loadECR.java -d Windchill\codebase
C:\ptc\Windchill_10.0\Windchill\codebase\wt\type\TypeDefinitionReference.class:
warning: Cannot find annotation method 'versions()' in type 'com.ptc.windchill.a
  1. nnotations.metadata.GenAsObjectMappable': class file for com.ptc.windchill.annot
  2. ations.metadata.GenAsObjectMappable not found
warning: Cannot find annotation method 'properties()' in type 'com.ptc.windchill
.annotations.metadata.GenAsObjectMappable'
warning: Cannot find annotation method 'name()' in type 'com.ptc.windchill.annot
  1. ations.metadata.GeneratedProperty': class file for com.ptc.windchill.annotations
.metadata.GeneratedProperty not found
warning: Cannot find annotation method 'type()' in type 'com.ptc.windchill.annot
warning: Cannot find annotation method 'constraints()' in type 'com.ptc.windchil
  1. l.annotations.metadata.GeneratedProperty'
warning: Cannot find annotation method 'required()' in type 'com.ptc.windchill.a
  1. nnotations.metadata.PropertyConstraints': class file for com.ptc.windchill.annot
  2. ations.metadata.PropertyConstraints not found
C:\ptc\Windchill_10.0\Windchill\codebase\wt\pdmlink\PDMLinkProduct.class: warnin
g: Cannot find annotation method 'superClass()' in type 'com.ptc.windchill.annot
  1. ations.metadata.GenAsPersistable': class file for com.ptc.windchill.annotations.
  2. metadata.GenAsPersistable not found
g: Cannot find annotation method 'interfaces()' in type 'com.ptc.windchill.annot
g: Cannot find annotation method 'versions()' in type 'com.ptc.windchill.annotat
  1. ions.metadata.GenAsPersistable'
g: Cannot find annotation method 'properties()' in type 'com.ptc.windchill.annot
g: Cannot find annotation method 'name()' in type 'com.ptc.windchill.annotations
g: Cannot find annotation method 'type()' in type 'com.ptc.windchill.annotations
g: Cannot find annotation method 'accessors()' in type 'com.ptc.windchill.annota
  1. tions.metadata.GeneratedProperty'
g: Cannot find annotation method 'getAccess()' in type 'com.ptc.windchill.annota
  1. tions.metadata.PropertyAccessors': class file for com.ptc.windchill.annotations.
  2. metadata.PropertyAccessors not found
An exception has occurred in the compiler (1.6.0_22). Please file a bug at the J
ava Developer Connection (http://java.sun.com/webapps/bugreport) after checking
the Bug Parade for duplicates. Include your program and the following diagnosti
c in your report. Thank you.
  1. com.sun.tools.javac.code.Symbol$CompletionFailure: class file for com.ptc.windch
  2. ill.annotations.metadata.GetAccess not found
If somebody has an idea to correct the join file, I will be interested.
Thank you in advance.
same problem. i use NetBean IDE for compil.
i use windchill library and jdk 1.6 (java wich install with windhill)
An exception has occurred in the compiler (1.6.0_26). Please file a bug at the Java Developer Connection (http://java.sun.com/webapps/bugreport) after checking the Bug Parade for duplicates. Include your program and the following diagnostic in your report. Thank you.
com.sun.tools.javac.code.Symbol$CompletionFailure: class file for com.ptc.windchill.annotations.metadata.SupportedAPI not found
Hi Georges MAURY/ Andrey Golovatyuk
I have a code which workks with Windchill 9.1, and now i have to make it compatible to run with Windchill 10.1.
When i try to compile this code in Windchill shell i get similer Warning Issues which you have faced earlier.
Will you guide me to overcome these issues...
Vivek
rmk
7-Bedrock
7-Bedrock
(To:gmaury-2)
Hi Georges Maury,
it SUCCESSFULLY compiled for me,
Please follow the below steps to compile the Windchill Java File.
1. Open the windchill Shell
2. Place the file under C:\LoadECR\LoadECR.java
3.ant -f bin/tools.xml class -Dclass.includes=*.java -Dclass.source=C:\LoadECR
the above will compile and place the .class file to codebase\ext\load\
I have tested your file, It works great.
.class file is attached.
KD
(To:rmk)
it SUCCESSFULLY compiled for me too.
I compiled it using Eclipse
