Is there a way to see a visualization of a Where Used report through all levels of a product structure, similar to Pro/E's Ref Viewer?
For example, I'm needing to do a rename to a part FT instance; I want to list all assemblies and all drawings that call up this part in the bom, since they will update (and no doubt balloon numbers will change as the parts will reorder in the bom repeat region) and so will need revising. At the moment the Where Used only lists parent assemblies; I then need to select each assembly in turn and select Related Objects > CAD/DynamicDocuments to list the drawings. Very tedious, time consuming and open to errors.
Using WF4, PDMLink 9.1
Dave Tate,
McCoy Trailers, Penticton, BC
