Windchill API call that gets only the direct drawing Referenced By?
Hi All,
We are in the process of having some CAD verification software developed
and are running into an issue. Part of the requirements are that the tool
be able to traverse an objects (typically .prt or .asm) configuration and
check to see if any of the dependents are directly represented in a
drawing. The solution as delivered uses a call that returns ALL drawings
that the a dependent object appears in the structure above it. That is all
the way up the assembly structure, whether the object is a direct dependent
or not. This may be many in the case of a small piece part used in a large
assembly.
Is there a Windchill API call that only returns the Drawings that directly
reference an object?
Benjamin A Bailey
Department Manager
Information Technology
Engineering Data Systems/PDM
Missile Systems
Raytheon Company
+1 520.545.6579 (office)
+1 520-403-1842 (cell)
6221 S Palo Verde Rd
Tucson, AZ 85706-5093 USA
www.raytheon.com
Raytheon Sustainability
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
