Hi All,
Currently whenever we are doing deployments in windchill, we are going for a cold backup of windchill DB. Our windchill DB is 70GB in size and takes 2.5+ hrs for cold backup which is more.
I would like to know if hot backups approach or any other approach which does not require your Windchill Application to be down is used by someone during deployments. Also,if there is any data loss while we revert the hot backup dump.
Kindly share your experiences on this.
Karan
Hello Karan,
That seems to take a while.
I've just add a look at our backup time and :
Our databse size is 120 Go and rman indicates a work at 60 Mo/s
For the moment we are lucky and we can stop Windchill over night, but I don't see a difficulty switching to Hot backup.
You just have to be careful with vaults/Db sync, but EDC has published a good document on this.
Morgan
Karan,
Your email is well timed...for me at least. We are thinking about switching our backup fromcold tohot using Oracle’s RMAN. Our cold backup is taking waaayyy too long. What I can tell you is what I have been told so if anyone can confirm or refute please let us know.
RMAN can create a point-in-time image of the system then export that information out while PDMLink is still running. You also need toset your system to something called Archive mode. This mode gives you the ability to record any changes between two point-in-time images.
Upon a restore the RMAN will restore to the point-in-time image then use the Archive mode for any changes.
This seems like it will help us immensely. However, does anyone have any pros or cons of the RMAN hot backup vs. a third-party cold backup?
Steve G
Just FYI, we were in a similar situation not long ago when we were doing a cold backup of the Oracle DB across the network. It took 2+ hours to back up, although the database was about 120Gb; considerably larger than yours. We have since switched to a process where we back up the DB to a different directory on the same server using the "psexec" utility in Windows (which is then backed up by IT). This takes only about 35-40 minutes. So, we run the backup process on the Windchill app server, and it:
(1) Stops Windchill
(2) Backs up the LDAP (using the appropriate WindchillDS command line to create an LDIF file)
(3) Remotely stops the OracleServiceWIND service on the DB server using the "netsvc" utility.
(3) Initiates a remote xcopy on the DB server using psexec.
(4) Reboots the DB server (and waits for it to restart)
(5) Restarts Windchill
I prefer a cold backup because it's relatively simple and ensures that everything is synced up (except the vault, which is easily addressed as someone else pointed out). I believe psexec and netsvc are both available in the Windows resource kit from Microsoft. We also do a nightly export using the "exp" command.
