Windchill MSSQLServer Configuration
UmutCanCOLAK
3-Newcomer
When we configure from installation Windchill 11.0 M030 with MSSQLSERVER. We get an error.
We attached log file about the problem.
Thank you
TomU
(To:UmutCanCOLAK)
For some reason the installer can't find the file called 'CreateDB_large.sql'.
>>>> START Create SQL Server Database for Windchill <<<<
STDOUT: STDERR: Sqlcmd: 'C:\ptc\Windchill_11_4\SQLServer\Conf\CreateDB_large.sql': Invalid filename.
Probably best if you open a tech support case with PTC.
[You might want to be careful with log files like this.  They include all the passwords in plain text...]
UmutCanCOLAK
3-Newcomer
(To:TomU)
Thank you. I gave an answer from PTC. I shouldn't install Windchill 11.0 on MSSQL Server 2008.
This installation was educational purpose, so this isn't problem but I mind that passwords issue.
