Windchill PDMLink with cluster setup
  • January 22, 2014
  • 3420 views
I had installed windchill ppdmlink on monolithic environment but really no idea on how to do with cluster option. could you please support me to host windchill pdmlink with cluster support. I do not have any document at all. If any customized document available, please share with us and help to complete the setup.
Thank you in Advance.
One suggestion here if at all possible:
Use Windchill 10.2.
It simplifies and improves Windchill clustering as compared to previous releases.
KGH1-VisitorAuthor
Is this tricker with Windchill 10.1.
Also few queries like Is this windchill is cluster aware or unaware application. Is this works on active / active or active / passive node setup. I mean, just as failover cluster or load balancer cluster.
Any steps to follow while installation. If any simple document shared will really be helpful.
We have 2-node failover microsoft cluster setup.
Please help.
Windchill clustering is normally active/active, though active/passive arrangements have been used for the master node prior.
As of 10.2 the master node dynamically fails over as well, removing such complications. For this and other reasons cluster configuration is simpler with 10.2 than with previous releases.
As for further help, I'm afraid I'm neither a support engineer, nor the best person to help with production deployment of clusters,
