Since the update to Wildchill 10 we have been completely cripped because we can't pull anything off of our servers.
Has anyone else had this problem?
Using Wildfire 5.0
datacode m060
Windows 7
Ungraded to Java 6.
Changed default windows browser to Firefox (IE 10 is not supported)
Renamed .wf folder to r91.wf
Better check the software matrix. I'm pretty sure WF5 M060 is NOT compatible with WC 10.1.
Yeah, M130 or later is required.
See http://www.ptc.com/WCMS/files/67180/en/Creo_Data_Management_Compatibility_Roadmap.pdf
Hi Tom,
Thanks for jumping in. I think M060 is the latest Wildfire 5.0 Datecode available on the site...
do you know where I can get M130?
There was a name change. Look under Creo Elements Pro
Thanks Tom. You got to the core problem 3 days faster than PTC support.![]()
