Hello All,
i am trying to rehost our Windchill 8.0 M040 from our souce system ""testplm.ttrpune.com" to new Target system "tatatoyoplm.tacogroup.com".
Source System: testplm.ttrpune.com
Target System : tatatoyoplm.tacogroup.com
For doing this i fallow these steps:
1. Copy ptc folder from source to target with same folder structure.
2. Install Aphelion on "Tatatoyoplm.tacogroup.com"
3. Install Apache, Tomcat on target System which runs fine.
4. Export target root.ldif and import it on Target LDAP.
5. Export oracle dump from source and import it to Target System.
Replace all occurrences of the source hostname with that of the target system in the following files in <APACHE_HOME>/conf.
App-Windchill-Auth.conf
App-Windchill.properties
Start Apache Server. Ensure that it comes up fine.
Apache Server Working fine.
SQL> select hostname from fvhost;
HOSTNAME
testplm.ttrpune.com
SQL> update fvhost set hostname='tatatoyoplm.tacogroup.com';
1 row updated.
SQL> update repository set lastknowndomain='tatatoyoplm.tacogroup.com' where lastknowndomain='testplm.ttrpune.com';
SQL> select url from site;
http://testplm.ttrpune.com/Windchill/servlet/WindchillGW
SQL> update site set url='http://tatatoyoplm.tacogroup.com/Windchill/servlet/WindchillGW';
SQL>Update remoteobjectinfo set remoteobjectid = replace(remoteobjectid, 'cn=testplm','cn=tatatoyoplm');
16022 row updated
alter package baselinepk compile body;
alter package epmworkspacepk compile body;
After doing all these syncronization steps we start the Windchill then it gives the bellow errors as attched in mehod server log.
I also call with PTC but as per ptc this is not supported method.
Please help us
Thank you.
Vivek
Hello Vivek,
I would like to upgrade and rehost my Windchill 8.0 M050 system to Windchill 10.0 M040.
Source host name: cad.snt.hu
LDAP: Aphelion
Target host name would be: cadwch.snt.hu
Target LDAP would be: WindchillDS
You look professional, I am a new and inexperienced this topic. What steps do you suggest me?
Klara
Isn't like this for updating Repository table
SQL> Update Repository set lastknowndomain='ldap-pending.tatatoyoplm.tacogroup.com',guid='ldap-pending.tatatoyoplm.tacogroup.com' where lastknowndomain='ldap-pending.testplm.ttrpune.com';
