Windchill Workflow Migration
VB_9310203
Version: Windchill 12.0
Use Case: Requirement is Windchill to Windchill Data Migration. Using WBM for this migration. Client wants the Workflow processes to be migrated. Objects having WFs are Parts, Documents, Change Objects.
Description:
As the requirement is to migrate the Workflows from Source Windchill (WC 12.0) to Target (WC 12.0), but using WBM for WF Process migration has the following limitations:
i. Only the Workflows defined from latest iteration of WF Templates considered by WBM
ii. Manually populating the "mapping.xml" file with Target IDA2A2 value. This is time consuming (especially during the Production Cut-over) and also prone to manual errors.
Due to the above limitations, is it feasible to migrate the WF Processes through WBM? If so, can you please suggest some strategies to do so.
If not through WBM, please suggest alternate approaches to migrate the WF Processes.
Please provide your suggestions. @windchill
I'm highly thankful for strategies and code samples (if applicable).
Thanks.
Vinoth K Balu
Hi @VB_9310203
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina
PTC Community Moderator
PTC
It sounds like the customer wants to have the full history of all changes for the Workflow Templates?
I'm not sure if it does multiple versions easily, but you may want to look into the Business Administrative Change Utility:  https://support.ptc.com/help/windchill/r13.1.0.0/en/index.html#page/Windchill_Help_Center/busadminchgprom/BACUtility.html
