I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.3
Windchill admin login Utility menu not display
You may want to try testing your authentication using the wt.auth.Authentication utility. Instructions in the ticket:.
Is this a new install or an upgrade? Could be a license issue with the admin user. Send more info.
Hello PC_10366408,
I'm Charles from PTC Technical Support in Europe: Was the information provided helpful somehow?
KR,
Charles.
