Hi All,
Recently I have worked on creating the part substitutes and alternates using windchill load from file utility in windchill 12.0.2.18. Since the REST end points were not present in my windchill version need to go with load from file utility. I hope it will be useful for some one looking for a solution to automate these tasks.
Following is the xml template for the same:
Load Alternates:
<?xml version="1.0" ?><!DOCTYPE NmLoader SYSTEM "standard12_0.dtd">
<NmLoader>
<csvBeginCreateUpdateAlternateLink handler="wt.replacement.LoadReplacement.beginCreateUpdateAlternateLink" >
<csvalternatePartNumber>AI-00003</csvalternatePartNumber>
<csvalternatePartName>component2</csvalternatePartName>
<csvalternatePartOrganizationName>DemoOrg</csvalternatePartOrganizationName>
<csvalternatePartOrganizationID></csvalternatePartOrganizationID>
<csvalternateForPartNumber>AI-00002</csvalternateForPartNumber>
<csvalternateForPartName>component1</csvalternateForPartName>
<csvalternateForPartOrganizationName>DemoOrg</csvalternateForPartOrganizationName>
<csvalternateForPartOrganizationID></csvalternateForPartOrganizationID>
<csvtwoWayStatus></csvtwoWayStatus>
<csvreplacementType></csvreplacementType>
</csvBeginCreateUpdateAlternateLink>
<csvEndCreateUpdateAlternateLink handler="wt.replacement.LoadReplacement.endCreateUpdateAlternateLink" />
</NmLoader>
LoadCommand:
windchill wt.load.LoadFromFile -d <Path of the xml load file> -u <UserName> -p <Password> -CONT_PATH \"/wt.inf.container.OrgContainer=DemoOrg/wt.pdmlink.PDMLinkProduct=<Your Product Name>\"
XML Template for the creating substitutes:
<NmLoader>
<csvBeginCreateUpdateAssemblySubstitute handler="wt.replacement.LoadReplacement.beginCreateUpdateAssemblySubstitute" >
<csvpartNumber>AI-00001</csvpartNumber>
<csvpartName>TopLevelPart</csvpartName>
<csvorganizationName>DemoOrg</csvorganizationName>
<csvorganizationID></csvorganizationID>
<csvversion>A</csvversion>
<csvview>Design</csvview>
</csvBeginCreateUpdateAssemblySubstitute>
<csvBeginCreateUpdateSubstituteLink handler="wt.replacement.LoadReplacement.beginCreateUpdateSubstituteLink" >
<csvsubstituteForPartNumber>AI-00004</csvsubstituteForPartNumber>
<csvsubstituteForPartName>component3</csvsubstituteForPartName>
<csvsubstituteForPartOrganizationName>DemoOrg</csvsubstituteForPartOrganizationName>
<csvsubstituteForPartOrganizationID></csvsubstituteForPartOrganizationID>
<csvsubstituteForLineNumber></csvsubstituteForLineNumber>
<csvsubstitutePartNumber>AI-00005</csvsubstitutePartNumber>
<csvsubstitutePartName>component4</csvsubstitutePartName>
<csvsubstitutePartOrganizationName>DemoOrg</csvsubstitutePartOrganizationName>
<csvsubstitutePartOrganizationID></csvsubstitutePartOrganizationID>
<csvsubstitutePartReferenceDesignator></csvsubstitutePartReferenceDesignator>
<csvsubstitutePartUnit></csvsubstitutePartUnit>
<csvsubstitutePartAmount></csvsubstitutePartAmount>
</csvBeginCreateUpdateSubstituteLink>
<csvEndCreateUpdateSubstituteLink handler="wt.replacement.LoadReplacement.endCreateUpdateSubstituteLink" />
<csvEndCreateUpdateAssemblySubstitute handler="wt.replacement.LoadReplacement.endCreateUpdateAssemblySubstitute" />
</NmLoader>
LoadCommand:
This was documented here as well: https://www.ptc.com/en/support/article/CS432175?source=search
