Workflow expression compile error
rbhoraskar
Following code as in https://www.ptc.com/en/support/article?n=CS260605&source=Case%20Viewer
To set the state of a Change Notice's Resulting Objects in Windchill
I am on WC  11.1 M020-CPS03
using the following Code in expression Robot:
wt.lifecycle.State state = wt.lifecycle.State.toState("ISSUED");
wt.fc.QueryResult resulting = wt.change2.ChangeHelper2.service.getChangeablesAfter((wt.change2.ChangeOrderIfc) primaryBusinessObject);
while(resulting.hasMoreElements())
wt.fc.Persistable persistable = (wt.fc.Persistable) resulting.nextElement();
if (persistable instanceof wt.doc.WTDocument && !wt.vc.wip.WorkInProgressHelper.isCheckedOut((wt.vc.wip.Workable) persistable))
wt.lifecycle.LifeCycleHelper.service.setLifeCycleState((LifeCycleManaged)persistable, state);
Here is the error in Compile window >> Check Syntax
Error: MS Logs
2019-07-24 12:06:44,107 ERROR [ajp-nio-127.0.0.1-8010-exec-6] WF_EXEC_EXPR Administrator -    compile - OUT: warning: Supported source version 'RELEASE_7' from annotation processor 'com.microsoft.azure.management.apigeneration.LangDefinitionProcessor' less than -source '1.8'
C:\ptc\Windchill_11.1\Windchill\temp\WfExpression_11.java:46: error: cannot find symbol
      if (persistable instanceof UNDERREVIEW && !wt.vc.wip.WorkInProgressHelper.isCheckedOut((wt.vc.wip.Workable) persistable))
  symbol:   class UNDERREVIEW
C:\ptc\Windchill_11.1\Windchill\temp\WfExpression_11.java:48: error: cannot find symbol
  symbol:   class LifeCycleManaged
Note: C:\ptc\Windchill_11.1\Windchill\temp\WfExpression_11.java uses unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
2 errors
1 warning
Looking for valuable help!
Kindly ignore previous comment. I saw that you are doing it from workflow robot. If you are trying it from Workflow, use below code:
wt.lifecycle.LifeCycleHelper.service.setLifeCycleState((wt.lifecycle.LifeCycleManaged)persistable, state);
Copy it in notepad first and then Paste it in robot. it should work.
7 REPLIES 7
Hi Rahul
What is the java version on the Windchill server? I have seen this error in the past where I had Java 1.7 which was not compatible with Windchill 11.1. You may need to check the same.
Abhijeet
rbhoraskar
(To:AbhijeetMule)
Hi Abhijeet,
Do you mean system JRE or windchill java home ?
Rahul
rbhoraskar
(To:AbhijeetMule)
Hi Abhijeet,
I will definitely try that when I am back on server. I wonder if you can help in this expression.
This expression is basically for WTDocument, how should I make it more generic so that it should work for all resulting objects independent of object type like epm or wtpart too?
Looking forward for yours suggestions.
Rahul
You can try:
Approach 1: Just removing Document type from condition considering CA resulting items allows only WTDocument, WTPart or EPMDocument types in your environment.
if (!wt.vc.wip.WorkInProgressHelper.isCheckedOut((wt.vc.wip.Workable) persistable))
Condition
Approach 2: Tweaking if condition to check if the resulting items is any of types WTDocument, WTPart or EPMDocument and not checked out.
if ((persistable instanceof wt.doc.WTDocument||persistable instanceof wt.epm.EPMDocument||persistable instanceof wt.part.WTPart) && !wt.vc.wip.WorkInProgressHelper.isCheckedOut((wt.vc.wip.Workable) persistable))
Condition...
Try it on test server and make the necessary changes...
rbhoraskar
(To:AbhijeetMule)
Thanks for suggestions Abhijeet.
Br,
Rahul
rbhoraskar
(To:rbhoraskar)
Hi Abhijeet,
this code works for all types of Object in Resulting table.
Cheers
Rahul
