I have a workflow for a document. I want to check for a variable and if it reports back "N" to open a popup window telling the user what needs to be done. Is this possible inside of the workflow under the "Complete" transition? If it is, does anyone have any code for opening the popup? Or do I have to write code outside of Windchill and reference it from the transition area?
![]() | Iker Mendiola - Prambanan IT Services |
