Hi I am working on Windchill 10.2 version. I would like to know how to install the Worgroup Manager for CATIA v5 module. Please suggest me. Thank you.
Hi
All is explained in PTC Install guide..
but a little bit more complicated (and costly) for Catia
WGM for Catia V5 need Dassault licence for compiling an abstraction .dll
regards
Manoj,
Greg is correct. You can refer to the CATIA WWGM Admin and User guide for information on how to install it. The main thing is that you will use the Windchill PSI to install the Windchill Workgroup Manage module on the server and make sure that CATIA is selected as option hen you select which CAD applications should be made available during the install. After that you will need to do as Greg mentioned and compile the abstract libraries as outlined int the CATIA WGM Admin and User guide (https://support.ptc.com/view?im_dbkey=157413).
