XML Code file changed
SJ_11027292
2-Explorer
I am using Windchill PDM Essentials Release 11.2 and Datecode with CPS 11.2.0.1
The WT Booking XML Code file replaced and need to restore WT Initiation code file for Titagarah Server.
Link: https://titagarh-wc-prd2.ptcmscloud.com/Windchill/app/#ptc1/homepage
More Information
Earlier WT Number booking was 10 Digit and now its changed to 9 Digit.
Earlier WT Number booking was 10 Digit and now its changed to 9 Digit., So New WT coming with 9 Digit and its not required,
Earlier 10 Digit Number is required for Project.
HelesicPetr
(To:SJ_11027292)
Hi @SJ_11027292
Check OIR rules how the number generation is set.
PetrH
Hello @SJ_11027292
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Community Moderation Team.
