I have a query that I created using Query Builder that is integrated with MS Excel that uses one of the available XSL templates (templates/reports/excel2000WebQuery.xsl).
When I run the query from Excel, the part number column is truncating a leading zero, and no matter how I format column A (general, text, number, etc.) the zero is always truncated from the results.
Anyone have any suggestions or experience with this? We may have to make a change to the .xsl file.
Brian,
you can have the query builder output a ' befrore the part number, excel will then understand it is a string when importing.
See attached qml.
Vincent
In Reply to Brian Beard:
