I 'am trying to link a wtpart to vendor part using this loader :
<?xml version='1.0' encoding='UTF-8'?>
<!DOCTYPE NmLoader SYSTEM 'standardX10.dtd'>
<NmLoader>
<csvAddAVL handler='com.ptc.windchill.suma.axl.LoadAXL.addAVL'>
<csvOEMPartNumber>P00756220</csvOEMPartNumber>
<csvOEMVersion/>
<csvOEMIteration/>
<csvOEMView/>
<csvOEMOrganizationID/>
<csvOEMOrganizationName/>
<csvsourcingContext>DEFAULT</csvsourcingContext>
<csvvendorPartNumber>5ABC010</csvvendorPartNumber>
<csvvendorName>BMW</csvvendorName>
<csvvendorID>0141$322431</csvvendorID>
<csvvendorPartContainer>/wt.inf.container.OrgContainer=LeoniUBB/wt.inf.library.WTLibrary=IntBOMmgmttest</csvvendorPartContainer>
<csvvendorSourcingStatus>approved</csvvendorSourcingStatus>
<csvmanufacturerPartNumber></csvmanufacturerPartNumber>
<csvmanufacturerName></csvmanufacturerName>
<csvmanufacturerID></csvmanufacturerID>
<csvmanufacturerPartContainer></csvmanufacturerPartContainer>
</csvAddAVL>
</NmLoader>
but alwyes having this error :
addAVL failed.
Loader method com.ptc.windchill.suma.axl.LoadAXL.addAVL reported a failure
No objects were imported due to the error.
found exception:wt.util.WTException: error to create AVL and AML: Message: Resource bundle/Message key = wt.ixb.publicforhandlers.ixbResource/8
at ext.leoni.util.LeoPartsHelper.linkLEONIPart2Partner(LeoPartsHelper.java:5083)
at ext.leoni.util.LeoPartsHelper.linkLEONIPart2Partner(LeoPartsHelper.java:4922)
at com.infoengine.compiledTasks.file.opt.wt111.windchill.tasks.ext.leoni.interfaces.repairKit.repair_kit_creation.invoke(repair_kit_creation.java:244)
at com.infoengine.SAK.Task.invoke(Task.java:1806)
at com.infoengine.SAK.Task.invokeAndCheckExternalAccess(Task.java:1703)
at wt.method.WTAdapterImpl.processTask(WTAdapterImpl.java:750)
at wt.method.WTAdapterImpl.processRequest(WTAdapterImpl.java:523)
at com.infoengine.procunit.adapter.Adapter.send(Adapter.java:199)
at com.infoengine.SAK.Task.executeTaskRemotely(Task.java:2083)
at com.infoengine.SAK.Task.invoke(Task.java:1740)
at com.infoengine.SAK.Task.invoke(Task.java:1714)
at ext.tools.ToolUtils.callTask(ToolUtils.java:1113)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at wt.method.MethodResultWriter.writeExternal(MethodResultWriter.java:165)
at wt.method.MethodResult.writeExternal(MethodResult.java:226)
at java.io.ObjectOutputStream.writeExternalData(ObjectOutputStream.java:1456)
at java.io.ObjectOutputStream.writeOrdinaryObject(ObjectOutputStream.java:1430)
at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1178)
at java.io.ObjectOutputStream.writeObject(ObjectOutputStream.java:348)
at sun.rmi.server.UnicastRef.marshalValue(UnicastRef.java:290)
at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:367)
at sun.rmi.transport.Transport$1.run(Transport.java:200)
at sun.rmi.transport.Transport$1.run(Transport.java:197)
at java.security.AccessController.doPrivileged(Native Method)
at sun.rmi.transport.Transport.serviceCall(Transport.java:196)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:573)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:834)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.lambda$run$0(TCPTransport.java:688)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:687)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
GROUP SUCCESS: ERROR
any hints to make this link work
I would recommend using Import from Spreadsheet to do these type of imports. Much easier than with CSV2xML.
