attribute is used in objects or not
JohnDavid
7-Bedrock
How to find if soft attribute is used in objects or not.
I followed the below method.
Tried to detelte that attribute
1. if it is used, it will throw an excepton that " attribute is used in objects"
2.if i can delete it successfully, means attribute is not used any where.
But it is takiing more time and i need toc capture the details for more thn 100 attributes
Do you have any other way to achieve this?
John D.
0 REPLIES 0
