What options are available for publishing to PDF in the Publish Rules XML file?
I want the JPG images to be displayed in the PDF generated by the worker.
Thank you.
Publishing Rules for generation of additional file formats like PDF varies with adapters. All available options are documented in "Creo View MCAD Adapters Installation and Configuration Guide" with respective adapter.
Can you provide more details on use case or problem that you are trying to address here.
when I publish a Drawing (catia) with an image view (BMP) it does not appear in the PDF.
