In Arbortext Editor 6.1 M060 (new patch) I do not get a "change workspace" prompt when changing from one context to another. Our process is this...locate the object in Windchill (10.1) and open in AE. AE 6.1 is launched and the user is asked to log in to Windchill and choose a workspace. This is fine initially, however, if the user then decides to check out an object from a completely different context (using the same process above) the user is not prompted to choose a new workspace. The object is dumped into the workspace from the previous context. I inserted the parameter, below, in the userprefs file.
PromptForWorkspaceChange yes It helped in the previous version of AE but doesn't seem to make a difference with 6.1 M060. Perhaps I'm missing something...Does AE 6.1 and Windchill 10.1 not require different workspaces for different contexts?
