Hi All,
I make a Simple programe to which call the OOTB csv2xml functionality..
As you can see below, very simple program, it works well.. It creates xml files from csv files which are present at <WT_Home>\src\loadfiles\
but one issue is..
the csv2xml ootb utility does not exit and my remaining statements after this is not executing..
i want to executes the remaining staements after the execution of csv2xml utility..
ho i can do this..
Please help me out..
package ext.util;
public class NewCsv2Xml {
public static void main(String[] args) throws Exception{
System.out.println("Calling OOTB CSV2XML Utility");
NewCsvXML.class.desiredAssertionStatus();
wt.load.util.CSV2XML.main(args);
System.out.println("Done....");
/// out put of this programs..
Map file: C:\ptc\Windchill_10.1\Windchill\loadFiles\csvmapfile.txt
Root directory: C:\ptc\Windchill_10.1\Windchill\src\loadFiles
Input: C:\ptc\Windchill_10.1\Windchill\src\loadFiles If this is a directory, all csv files will be processed.
Expected encoding of source file(s): default
Output: C:\ptc\Windchill_10.1\Windchill\src\loadFiles
delimiter: ,
Preserve Space: No
Processing file: C:\ptc\Windchill_10.1\Windchill\src\LoadFiles\WTDocument.csv
Reading source csv file with encoding Cp1252
Processing file: C:\ptc\Windchill_10.1\Windchill\src\LoadFiles\WTPart.csv
CSV2XML.main(String[]) calls System.exit(0) so your program will not go any further.
Perhaps you could call CSV2XML as an external program?
E.g.
String command = "java -classpath <somepath> wt.load.util.CSV2XML <someargs>";
Runtime.getRuntime().exec(command);
// and so on...
I haven't tried it and there would be some details to work out.
