Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
file posted: intralink script for quickly increasing the proi revision of multiple items
My earlier question about pro/I revisions reminded me to post a file on the members portal website. It is the java code for an intralink script that takes the selected items and increases the revision.
Multiple selections are ok.
It was written for a revision scheme where the initial revision is "-", and subsequent revisions are alphabetic. Other revision schemes will require modifications to the code.
