Hello all,
I need to listen a JMS queue and to read the data from the JMS queue to create objects in Windchill .I have no idea about this funtionality. Have anyone has done this kind of work in Windchill?
Can you share your experience?
Windchill queue will work out on this requirement?
Thanks in advance
Selvam
hi bob,
thanks for your reply.
I will get some message queue from Jave Messaging Server (JMS server), which willl have the details about the objects (attribute values, attachements, workflow names, lifecycle names ..etc). I will get that information in winchill and will create a new object or will update the existing object.
I will work in Java only, i prefer to do in Java only.
I want to know ,how canI link JMS server and Windchill to collect the information?
Can I use Service Listener in Windchill? or OOTB Queue service?
I tried service listener , but i do not know how can i listen the JMS queue.
Am i explained well, Bob?
--Selvam
thank you jesse.
1. I tried with listeners but not able to listen anything apart from windchill services.- so this is ruled out .
2.I dint try queues but had a discussion with people on this - not enough information i got. As you said I can conclude from my research / understanding this is not possible
3. I have no idea about Info *Engine . I have to explore that also.
4. Plain Java APIs - How can I push the messages from JMS to Windchill using plain java? - I have to explore this also.
Probably a Utility to listen JMS messages.
Anybody has any more idea?
Selvam
thanks a lot Jesse,
I guess I can try Info *Engine because some of my friends also told about it. So I will try that option also
Now I get the JMSmessage and store it some txt files and then read that information in Windchill utility(run from Windchill shell) and then I create objects in windchill.
selvam
hi bob,
can you tell me the step by step connectivity methods in TIBCO and Windchill.
Will TIBCO push the JMS messages to the Windchill?
selvam
hi sudeep,
yes you are correct. ESI needs separate license to use it. So I am going to use Info *Engine only.
Using Info engine we can subscribe to the JMs queues. But we need some adapters like TIBCO or WMB.
Thanks for your info.Windchill does have the Info Engine documentation.
selvam
hi all
I started working on Info *Engine. It seems that there isa way to connect the WMB and Info *Engine through Ldap DS.
could anyone tell me how can link the Ldap with WMB? I put an entry in jmsconfig.config file in WMB but still it is not working.
I do not knowif I gave thecorrect Ldap details.
selvam
